Car wont start after code erase
Car started missing. i replaced #3 and 4 coil ran fine but noticed a miss every once in awhile so i hooked up vag to see what was going on but it showed alot of codes so i deleted to rerun but car would start for about a hour and then it was hard to keep started and then ran fine. i thought it was a anomaly so i did it again the same result.
Saturday,18,February,2017,01:27:06:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1F 25 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E75N016371 Mileage: 247710km/153919miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Cannot be reached 1100
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1F-Sat. Tuner -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E2760745
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2855E6799BE83A9
10 Faults Found:
18308 - Coolant Fan Control 2
P1900 - 004 - Open or Short to Ground
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean
16555 - Fuel Trim; Bank 1
P0171 - 001 - System Too Lean - MIL ON
16558 - Fuel Trim; Bank 2
P0174 - 001 - System Too Lean - MIL ON
17546 - Fuel Trim: Bank 2 (Add)
P1138 - 001 - System too Lean
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 001 - System too Lean
16891 - Idle Control System RPM
P0507 - 001 - Higher than Expected.
16485 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal - Intermittent
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Readiness: 0010 1001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0051293
Coding: 0000002
VCID: 32610411AD34409
2 Faults Found:
18290 - Powertrain Data Bus
P1882 - 000 - Missing Message from Electric Parking Brake Controller
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 247099 km
Time Indication: 0
Date: 2017.02.15
Time: 17:32:02
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 78.0
Temperature: 61.0°C
T.B. Angle: 0.0°
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 34
Mileage: 247105 km
Time Indication: 0
Date: 2017.02.16
Time: 01:20:24
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2241F451FDD4D09
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E2760745
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 194
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:22
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346GX067516183
Coding: 0000103
Shop #: WSC 00000 000 00000
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000063835
Coding: 1052993
VCID: 1C3DCAA9DFB0E69
1 Fault Found:
00003 - Control Module
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 11
Reset counter: 194
Mileage: 247099 km
Time Indication: 0
Date: 2017.02.15
Time: 17:09:09
Freeze Frame:
Temperature: 22.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0123123
VCID: 31630B1DA8327B1
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7130813
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D2021507
VCID: 2B5F19758A1E111
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 244DF249E7C0DE9
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: E5CB2F4D2C7A671
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Revision: D05 Serial number: AUDID3E2004104
Coding: 0016203
Shop #: WSC 03055 067 57207
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003052280042
Coding: FCFE7BDD1B7906
Shop #: WSC 03303 444 84210
VCID: 2757E54596F6351
3 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:22:30
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:22:34
02218 - Satellite Radio (R146)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:29
Address 1F: Sat. Tuner
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 194
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:22
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 4
Fault Frequency: 0
Reset counter: 194
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:28
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015511
Address 36: Seat Mem. Drvr Labels: None
VCID: 55AB9F8DBC1A771
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378C-057519268
VCID: 387536394B48AA9
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000504600114
Coding: 0003477
VCID: 1D3BC7ADC4AAEF1
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0060
Coding: 0032364
VCID: 2045FE59F3D8C29
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 187
Mileage: 247088 km
Time Indication: 0
Date: 2017.02.15
Time: 17:32:28
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 234
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:34
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503160127
Coding: 0065150
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 8
Mileage: 184428 km
Time Indication: 0
Date: 2004.03.25
Time: 03:21:24
Freeze Frame:
Fault Priority: 3
Reset counter: 8
Mileage: 184428 km
Time Indication: 0
Date: 2004.03.25
Time: 03:21:24
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000012451
Coding: 0000016
VCID: 2A511C7185E4089
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000058486
Coding: 0010111
VCID: 1E39C0A1C9ACF49
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0060
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 187
Mileage: 247088 km
Time Indication: 0
Date: 2017.02.15
Time: 17:32:28
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C134513D54109
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 247704 km
Time Indication: 0
Date: 2017.02.18
Time: 01:22:32
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396CP057506306
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000003808
Shop #: WSC 03303 444 85895
Subsystem 1 - Part No: 4E0 915 105 A
Component: von TU3 1503140242
Coding: 344530393135313035412054553331353033313430323432
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700031161
Coding: 0202125
VCID: DFC73DA50E263D1
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 52
Reset counter: 194
Mileage: 247099 km
Time Indication: 0
Date: 2017.02.15
Time: 17:12:06
Freeze Frame:
Speed: 0.0 km/h
Temperature: -2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 188
Mileage: 247113 km
Time Indication: 0
Date: 2017.02.16
Time: 01:25:46
Freeze Frame:
Speed: 89.0 km/h
Temperature: -1.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000503100147
Shop #: WSC 12336 024 394758
VCID: 346D020957204E9
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720506401744
Coding: 0001208
VCID: 2143FB5DF8D2CB1
3 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:41
01548 - Sensor for Parking Aid; Rear Right (G206)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:41
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:41
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007518798
Coding: 0010970
End ---------------------------------------------------------------------
Chassis Type: 4E0
Coding: 0007773
10 Faults Found:
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 247099 km
Time Indication: 0
Date: 2017.02.15
Time: 17:32:02
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 78.0
Temperature: 61.0°C
T.B. Angle: 0.0°
18265 - Load Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 34
Mileage: 247105 km
Time Indication: 0
Date: 2017.02.16
Time: 01:20:24
Coding: 0007597
1 Fault Found:
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 194
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:22
Cannot be reached
Coding: 0000103
Coding: 1052993
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 194
Mileage: 247099 km
Time Indication: 0
Date: 2017.02.15
Time: 17:09:09
Freeze Frame:
Temperature: 22.0°C
Coding: 0123123
Coding: 00000037
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0530707
Coding: 0012241
Coding: 0016203
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:22:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:22:34
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:29
Cannot be reached
Coding: 0410624
Component: ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 194
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:22
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 194
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:28
Coding: 0015511
No Faults Found
Coding: 0003477
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 187
Mileage: 247088 km
Time Indication: 0
Date: 2017.02.15
Time: 17:32:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 234
Mileage: 247696 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:34
Coding: 0065150
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 8
Mileage: 184428 km
Time Indication: 0
Date: 2004.03.25
Time: 03:21:24
Freeze Frame:
Fault Priority: 3
Reset counter: 8
Mileage: 184428 km
Time Indication: 0
Date: 2004.03.25
Time: 03:21:24
Coding: 0000016
Coding: 0010111
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 187
Mileage: 247088 km
Time Indication: 0
Date: 2017.02.15
Time: 17:32:28
Cannot be reached
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 247704 km
Time Indication: 0
Date: 2017.02.18
Time: 01:22:32
Coding: 0000002
Coding: 0032364
Coding: 0202125
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 52
Reset counter: 194
Mileage: 247099 km
Time Indication: 0
Date: 2017.02.15
Time: 17:12:06
Freeze Frame:
Speed: 0.0 km/h
Temperature: -2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 188
Mileage: 247113 km
Time Indication: 0
Date: 2017.02.16
Time: 01:25:46
Freeze Frame:
Speed: 89.0 km/h
Temperature: -1.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0032364
Coding: 0001208
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 247710 km
Time Indication: 0
Date: 2017.02.18
Time: 01:23:41
Coding: 0010970
Definite major issues for running, but should be resolvable. First two minute read of your description and the codes says to suspect fuel pumps. Notice it is on both sides too (Bank 1 and Bank 2), not just one side where you were poking at plugs. Your better case $ and labor wise would be some big vacuum leak, or MAF took a powder or something. Thus open hood and do thorough visual check for anything loose for vacuum, intake connections, clamps, etc. Listen for the typical audible sucks, hisses, etc. Maybe also try unplugging MAF too--which forces it into the default open loop mode where it just relies on canned default settings. If it smooths out, figure MAF is dubious. If no change, think big vacuum or fuel issues. If you reach a point it won't start and then spray some ether (starting fluid) in an it kicks over easily--even if it dies a few seconds later after the ether hit passes--yet another pointer back to fuel pumps.
Did the starting issue come up before or after you replaced the coils? If new symptoms appeared after the work, something touched during the work is the likely cause.
No starting only after code erase. Repaced the coils because thats what the scan tool read and i was out of town. So i didnt delete the codes till after i returned. Look for vacuum leak will try the maf test after work. Thanks
ceroberts75
07-16-2016 09:20 AM
