car wont start, starter wont even crank!
Monday,05,January,2015,17:50:10:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4E23N005504 License Plate:
Mileage: 268320km-166726mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 65 67 72 76
VIN: WAUZZZ4E23N005504 Mileage: 268320km/166726miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 1010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 1010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 1010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Sporadic communication error 1000
65-Tire Pressure -- Status: Sporadic communication error 1000
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 D HW: 4E0 907 560
Component: 3.7L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0BD306787
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 224B0C03FD3A2A0EA27-8077
1 Fault Found:
19510 - Starter Will Not Turn
P3054 - 001 - Jammed or Electrical Malfunction
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 A HW: 09E 927 156
Component: AG6 09E 3,7L5V RdW 0100
Coding: 0000001
Shop #: WSC 02802 177 16337
VCID: 204F060BF336381EB43-8075
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 52201 000 00000
VCID: 2149030FF83C3116BBD-8074
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0BD306787
Coding: 0410624
Shop #: WSC 26921 136 00231
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 0
Reset counter: 5
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:21:00
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:31:44
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 B HW: 4E0 959 760
Component: Sitzmemory BFS H05 0020
Revision: 00000000 Serial number: 5DS 008 795-02
Coding: 4063232
2 Faults Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:41
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:42
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300II027509452
Coding: 0000002
Shop #: WSC 00000 000 08192
VCID: 3A7BD46375AA42CE9A7-806F
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 317AH037508109
Subsystem 3 - Serial number: ˙˙10.01.03˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙
Subsystem 4 - Serial number: ˙˙˙˙˙˙˙
3 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:11:31
02003 - Driver Identification Control Module (J589)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:11:47
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:23:11
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 011 0240
Revision: 00000011 Serial number: 00000000008815
Coding: 0266443
Shop #: WSC 02447 823 57139
VCID: DABBF4E315EA22CE3A7-808F
4 Faults Found:
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: 0.0°C
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: -6.0°C
01087 - Basic Setting Not Performed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 A HW: 4E0 907 279 A
Component: ILM Fahrer H11 0070
Coding: 0011102
VCID: 264310139112D62ECEF-8073
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000255
Shop #: WSC 02313
5 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
01336 - Data Bus for Comfort System
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:53
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
VCID: E3C5C90722A0E306691-80B6
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H08 0020
Coding: 0012041
Shop #: WSC 02311 785 00200
VCID: E5C1D71F2C949D36875-80B0
Component: Lenkradmodul H06 0050
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H40 0060
Revision: D05 Serial number: AUDID3C0010172
Coding: 0000003
Shop #: WSC 80152 462 20586
VCID: DCB7F2FB1FDEDCFE28B-8089
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 265909 km
Time Indication: 0
Date: 2003.03.03
Time: 20:42:25
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H06 0070
Revision: 06 Serial number: 0000302C19026E
Coding: FCFE7BDF2B6504
Shop #: WSC 52201 522 96019
9 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:43
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:44
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:44
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBC1020682
Shop #: WSC 00000 000 00000
VCID: 1C3732FBDF5E1CFE68B-8049
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
4 Faults Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 5
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:21:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:31:44
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 C HW: 4E0 907 553 C
Component: LUFTFDR.-CDC H03 4190
Coding: 0015500
Shop #: WSC 32727 134 80397
VCID: 23450907E2202306A91-8076
1 Fault Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:24:20
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H05 0020
Coding: 4063242
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 C
Component: MNS ECE H41 1030
Revision: 00000000 Serial number: 305BI037522908
VCID: 3E73D87369826EEEA6F-806B
2 Faults Found:
02445 - Disk Drive Initialization Error
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:10
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x5852
Hex Value: 0x3A72
Hex Value: 0x0000
02927 - DVD Read Error
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:11
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x91A9
Hex Value: 0x0A01
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0100
Serial number: 00000234600053
Coding: 0003606
VCID: 1D313FFFC44415F69F5-8048
5 Faults Found:
02104 - Light Detection Sensor (G399)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 15
Reset counter: 220
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0060
Coding: 0028449
VCID: DEB3F8F309C2CEEE46F-808B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 HW: 4E0 907 289
Component: Komfortgeraet H02 0050
Coding: 0000600
VCID: E6C3D013D192962E8EF-80B3
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H01 0020
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:45
Freeze Frame:
Raw, Form. N/A: 000 000 000
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:45
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:46
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:46
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:46
Freeze Frame:
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H12 0460
Revision: PROD_01O Serial number: 00000000018384
Coding: 0000026
VCID: 2A5BE423850AF24EEA7-807F
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 6
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:43
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000038271
Coding: 0010101
Shop #: WSC 20346 133 80621
VCID: 1E3338F3C9420EEE86F-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028449
1 Fault Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:52
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Shop #: WSC 02976 202 82039
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 134
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 10.25 V
Count: 61
Address 55: Xenon Range Labels: None
Part No SW: 4E5 910 357 % HW: 4@0 907 352
Component: Pre-DFS % H04 0030
Revision: 00000051 Serial number: % %
Coding: 0000002
Shop #: WSC 67847 787 00200
VCID: 0C1742BB6FBE8C7EF8B-8059
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304E9037523302
Coding: 0000001
VCID: 3169F34FA8DC81962BD-8064
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H11 0300
Revision: 00000015 Serial number: 00000000000000
Coding: 0001001
VCID: 2541171FEC14DD36C75-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000016120
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1403150017
Coding: 303030393135313035414B56413031343033313530303137
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:39
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028449
VCID: DDB1FFFF04C4D5F65F5-8088
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0190
Coding: 0212127
VCID: DFCDC5F70EC8C7E64D9-808A
1 Fault Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 23
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:59
Freeze Frame:
Speed: 0.0 km/h
Temperature: -6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 753 F HW: 4E0 035 753
Component: SDS 3500 DE H42 0380
Revision: 00000000 Serial number: 00000211270367
Shop #: WSC 12336 024 394758
VCID: 285F1E2B9B06C05EFC3-807D
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0060
Coding: 0028449
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: E0CFC60B33B6F81E743-80B5
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
End ---------------------------------------------------------------------
Coding: 0011773
1 Fault Found:
Coding: 0000001
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 5
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:21:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:31:44
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Coding: 4063232
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:41
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:42
Coding: 0000002
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:11:31
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:11:47
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:23:11
Coding: 0266443
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: 0.0°C
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: -6.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
Coding: 0011102
Coding: 00000255
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Coding: 0431707
Coding: 0012041
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Coding: 0000003
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 265909 km
Time Indication: 0
Date: 2003.03.03
Time: 20:42:25
Cannot be reached
9 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:44
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 5
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:21:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:31:44
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:36:38
Coding: 0015500
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:24:20
Coding: 4063242
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:10
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x5852
Hex Value: 0x3A72
Hex Value: 0x0000
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:11
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x91A9
Hex Value: 0x0A01
Hex Value: 0x0000
Coding: 0003606
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 220
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:00
Coding: 0028449
Coding: 0000600
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:45
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:45
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:46
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:46
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:46
Freeze Frame:
Coding: 0000026
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 6
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:43
Coding: 0010101
Coding: 0028449
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:52
Revision: AV1C1010
Coding: 0000531
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 134
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
No Faults Found
Coding: 0001001
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:39
Coding: 0028449
Coding: 0212127
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 23
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:59
Freeze Frame:
Speed: 0.0 km/h
Temperature: -6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
1 Fault Found:
000 - -
Coding: 0028449
Coding: 0001008
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
AudiWorld Wiseguy
Dead battery
Given virtually every system has logged a random seemingly unrelated fault and the voltage is showing only 10.25V, you just have a dead battery and need to charge or replace it.
I charged my battery and I got new log, I measured the battery and it showed 12v but the MMI showes me only 10%.
Thursday,22,January,2015,15:16:57:62939
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Coding: 0011773
Coding: 0000001
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:41:34
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:56:30
Coding: 4063232
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:26
Coding: 0000002
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:22
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 17:56:10
Coding: 0266443
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: 0.0°C
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: -6.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.14
Time: 07:33:06
Freeze Frame:
Voltage: 10.60 V
Temperature: 0.0°C
(no units): 195.0
(no units): 77.0
Temperature: -78.0°C
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.14
Time: 07:33:06
Coding: 0011102
Coding: 00000255
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Coding: 0431707
Cannot be reached
Coding: 0000003
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 265909 km
Time Indication: 0
Date: 2003.03.03
Time: 20:42:25
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 105 D
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000111
Shop #: WSC 20346 133 61029
VCID: 1A3B34E3D56A62CE7A7-804F
1 Fault Found:
01414 - Combustion-Air Blower (V6)
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:21
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:21
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 4
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:02:06
Freeze Frame:
Text: 00000000
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:41:34
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:56:30
Coding: 0015500
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:10:33
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:11:00
Coding: 4063242
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:26
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:12
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x979C
Hex Value: 0x386D
Hex Value: 0x0000
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:13
Freeze Frame:
Hex Value: 0x3E72
Hex Value: 0x8B87
Hex Value: 0x0A01
Hex Value: 0x0000
Coding: 0003606
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 220
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
01370 - Alarm triggered by Interior Monitoring
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 0 km
Time Indication: 0
Date: 2003.02.27
Time: 03:21:00
Freeze Frame:
Bin. Bits: 10000000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:00
Coding: 0028449
Coding: 0000600
Coding: 0000026
Coding: 0010101
Coding: 0028449
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:52
Revision: AV1C1010
Coding: 0000531
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 134
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 10.25 V
Count: 61
Cannot be reached
Coding: 0000001
Coding: 0001001
Coding: 0028449
Coding: 0212127
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:10:19
Freeze Frame:
Speed: 0.0 km/h
Temperature: -9.0°C
Error Code: 2048
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 69
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:59
Freeze Frame:
Speed: 0.0 km/h
Temperature: -6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: None
VCID: 55A167DFBCF48DB6975
No Faults Found
Coding: 0028449
Coding: 0001008
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Coding: 0011773
Coding: 0000001
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:41:34
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:56:30
Coding: 4063232
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:26
Coding: 0000002
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:22
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 17:56:10
Coding: 0266443
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: 0.0°C
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: -6.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.14
Time: 07:33:06
Freeze Frame:
Voltage: 10.60 V
Temperature: 0.0°C
(no units): 195.0
(no units): 77.0
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.14
Time: 07:33:06
Coding: 0011102
Coding: 00000255
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Coding: 0431707
Cannot be reached
Coding: 0000003
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 265909 km
Time Indication: 0
Date: 2003.03.03
Time: 20:42:25
Coding: 0000111
1 Fault Found:
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:21
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:21
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:02:06
Freeze Frame:
Text: 00000000
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:41:34
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:56:30
Coding: 0015500
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:10:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:11:00
Coding: 4063242
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:26
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:12
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x979C
Hex Value: 0x386D
Hex Value: 0x0000
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:13
Freeze Frame:
Hex Value: 0x3E72
Hex Value: 0x8B87
Hex Value: 0x0A01
Hex Value: 0x0000
Coding: 0003606
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 220
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 0 km
Time Indication: 0
Date: 2003.02.27
Time: 03:21:00
Freeze Frame:
Bin. Bits: 10000000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:00
Coding: 0028449
Coding: 0000600
Coding: 0000026
Coding: 0010101
Coding: 0028449
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:52
Revision: AV1C1010
Coding: 0000531
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 134
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 10.25 V
Count: 61
Cannot be reached
Coding: 0000001
Coding: 0001001
Coding: 0028449
Coding: 0212127
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:10:19
Freeze Frame:
Speed: 0.0 km/h
Temperature: -9.0°C
Error Code: 2048
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 69
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:59
Freeze Frame:
Speed: 0.0 km/h
Temperature: -6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
No Faults Found
Coding: 0028449
Coding: 0001008
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Welcome to the board! Have you read sticky tread? Many good advises there.
How old is your battery? Where did you connect negative cable while charging?
Save that scan and than clear all DTC's, one at the time, and perform a new scan. It will show what is wrong (or not) now. This one is all history.
I also believe you need a new battery.
the battery is from 09.12, this might be the reason, and this is the latest log I made. When I always open the doors the lights are flashing in interior, so is it a battery or something else? recharging helps? or some components to be replaced?
You have to delete all faulty codes before you perform a fresh scan. Otherwise you will have all old codes.
If the battery measured 12.2-12.7V it's good - The thing that
concerns me is the MMI only shows 10%. Even when my battery terminal is 12.2V, my MMI still shows 100%. I think the problem is more with Electronics than the power of the battery itself.
Why don't you jump the battery to see if it cranks, make sure the negative is to the POST.
I would remove the battery terminals - charge it fully and reconnect - just like putting in a new battery and try again. The MMI should show 100%.
My battery is still original.
Cheers,
Louis
Cheers,
Louis
+1 on Misha's comments, and emphasizing...
You need to clear codes module by module. You cannot rely on a simple global clear; it misses many, including the really key modules. I also can't really make sense of the scans, but candidly lost interest quickly when I could see they were unreliable. In first scan, jammed starter in ECU 1 seemed like low hanging fruit, but also a really odd one I have never seen before. But then, I see code faults that literally still have 2003--makes me doubt the value of the data.
Net, get battery charge to good state. Clear all codes, module by module as needed and then see what sticks. Don't get too hung up on discrepancy between MMI display and battery voltage reading. Can be variously just the way you hooked a charger to the car (battery instead of metal ground terminal on negative side), or a real battery failure. Also, just read the voltage by looking t measuring blocks. Many of the modules show you the voltage as one of the first measuring blocks, like ECU right off the bat.
charged my battery to 12.64v, before was 11.8v, but it back and tried to ignite but nothing, screen showed me " energy management ", then I connected vag-com and started to erase fault codes module by module, meanwhile MMI showed me that I must start the engine or the system shut down in 3 minutes, so I tried again and the engine started, but the MMI showed still 10%, so I drove until I got 100%, measured alternator and it showed 14.6v, but the lights are still flashing I dont know why. I decided to buy a new battery maybe it fix the problem. But thanks a lot guys for your help!
