Sponsored by:
Sponsored by:
Cigarette lighter/power adapter doesn't work. Blown Fuse?
Old 02-29-2008, 02:13 PM
pistol22pete's Avatar
Default Cigarette lighter/power adapter doesn't work. Blown Fuse?
I have a 2004 A8L and seem to have blown a fuse. Both front and rear cigarette lighters don't work. I went into the fuse panel and couldn't find a blow fuse or which fuse corresponded to the cigarette lighters for that matter. I need to use an Ipod and cell phone charger soon. I can't stand just using the one in the trunk. Can someone help? Which fuse? Where located?
Thanks for the help.
Pete
Old 02-29-2008, 02:46 PM
PAC
PAC's Avatar
Default 20 amp Fuse for front #36 and 20 amp Fuse for rear #37 located
in the fuse panel to the right of the glove box. Open the glove box which will allow you to pull open the fuse panel cover to the right. (with the passenger door open) The fuse #'s and location are listed on the cover when removed. These two 20 amp fuses are in the center row at the bottom of the block.....
Old 03-05-2008, 02:00 PM
Default Re: 20 amp Fuse for front #36 and 20 amp Fuse for rear #37 located
Thanks for the info...I was looking at the wrong fuse panel on the drivers side.
Old 08-15-2016, 09:30 PM
1FatJ's Avatar
Default D2 model
Do you happen to know if this is the same for the D2 model?
Old 08-16-2016, 06:30 AM
the_duke's Avatar
Fuse locations will be different between D2 and D3.
Old 08-16-2016, 08:00 AM
ltooz_a6_a8_q7's Avatar
Default If the fuses are ok... I fixed mine on D2
<a href="http://www.dognmonkey.com/audi/cigarette-lighters-suddenly-have-no-power.html" target="_blank">Cigarette Lighters have no power</a>
Cheers,
Louis
Old 08-16-2016, 12:00 PM
richard-tx's Avatar
There is one possibility and that someone used a cheap chinese cig lighter plug and bent the hell out of the contacts. If that is the case, then pull the fuse and carefully bend the contacts back into place.
fpjl
12
04-21-2021 07:01 AM
4lane
A4 (B8 Platform) Discussion
05-23-2018 12:36 AM
Khalizzel
12-08-2017 01:45 PM
ivans A8
05-26-2006 06:31 AM
05A4
08-31-2004 08:01 PM
Quick Reply: Cigarette lighter/power adapter doesn't work. Blown Fuse?
