Sponsored by:
Sponsored by:
Take a look at this engine
Old 06-02-2014, 09:24 AM
Mike141's Avatar
Default Take a look at this engine
Took a look at this D3 the other day...car has about 80K, VCDS scanned showed 00908 for control module for wiper motor, 2 parking sensor codes (001549), and battery management codes. Car sounded and drove fine, but take a look at the attached pics and tell me what you think other than the previous owner never cleaning the engine compartment, what is the deal with all of those white spots? Look like corrosion and when rubbed with finger, they come off. Also, the large pulley in center front of engine appeared rusty. If I buy I intend to take a look beneath the belly pan for any leaks. Thanks
Old 06-02-2014, 09:51 AM
krazzz's Avatar
Looks completely normal to me but I am from MI and that is what happens to cars driven in the winter.
Old 06-02-2014, 10:00 AM
aTOMic's Avatar
LP gas conversion?
Old 06-02-2014, 10:51 AM
1Wasserwerks's Avatar
My guess is normal erosion from the elements.
Old 06-02-2014, 05:14 PM
Mister Bally's Avatar
And the front cover missing...
Old 06-02-2014, 05:38 PM
Mike141's Avatar
Just checking to see if this was normal. I'm used to a clean engine compartment because I keep the rest of my car clean, why not under the hood? I guess some people just either don't have time or don't care.
Old 06-02-2014, 11:03 PM
everwake's Avatar
If, like me you live in a country with subzero temperatures part of the year and where salt is used to remove ice and snow from the roads, you would think that engine is fairly clean.
in the climate I live it most "experts" have agreed upon that washing the engine is worse than letting is stay dirty, apparently dust on the outside has very little effect, modern engines are sealed well enough that outside air only gets in through the intake, water on the other hand, especially mixed with road salt, is a bigger issue.
to me that sounds reasonable, so I only dry brush my engine compartment clean, and avoid using water at all.
But I have to say I prefer the look of a clean engine department to match the rest of the car, but the number of microfibre towels it takes when not using water is fairly high...
Old 06-03-2014, 04:58 AM
nathanwind's Avatar
Is it really that bad to do a low-pressure rinse on the engine bay (if you stay away from the air intakes & electronics)?
cogginscl
Audi A5 / S5 / RS 5 Coupe & Cabrio
05-23-2019 06:36 AM
ShaddowBlade
4.2 V8 Discussion
02-24-2014 08:21 PM
AudiTX87
A4 (B8 Platform) Discussion
16
08-31-2009 03:51 AM
rocketaudi
09-29-2002 02:20 PM
WJM
03-16-2001 04:42 AM
Quick Reply: Take a look at this engine
