Converted to coil springs
Recently switched to conventional suspension, using Strutmasters kits. Does anyone know exactly how to deactivate air suspension through VCDS so I can get rid of the yellow light on my dash. Thanks.
Use LCH to subtract 00064 from channel 001 of module 0x07
Remove 0x34 from GW install list, and unplug/loop out module 0x34.
Edit: Not sure how/if this will affect Distance Regulation (ACC) and RVC if you have them...
Yeah its eibach springs at all four corners with bilstein shocks up front and kyb in the back, I don't know why they went with two different manufacturer, maybe to keep cost done? The ride is pretty much equivalent to dynamic and I don't know if there is a way to make it softer.
but when a Strutmasters website there is a note saying--currently no solution for errors and error lights due to conversion.
you detailed approach seems to go against that.
