D3 2003 4.2 Introduction and some (retrofit) questions
Hello everybody,
I am the proud owner of an Audi D3 4.2 2003, and have been driving the car for almost one year now. Still loving every minute of it.
I have lowered the car a bit with VCDS, installed a Dension 500 for USB/iPhone connectivity, and fixed some small issues in the time I've owned it. Have been looking at more then one A8 and this one was by far the best looking and well maintained A8 I'd seen.
This forum has been more than helpful so far, and saved me a lot of trips to the stealership. Since I drive the car a lot, and petrol isn't cheap in the Netherlands (6,87eur/gallon) I had an LPG conversion done when I bought the car and very happy with it, no noticable difference with driving on petrol.
I have driven over 30k (km's) with the car now, without any real issues.
Here are some pictures (noticed my lense is dirty ).
Now for the questions.. I have retrofitted both a bluetooth module (coming from an A6, but partnumbers match and should work if i am informed correct), and a (new) rain/lightsensor.
The bluetooth module can be reached by VCDS:
But the MMI (even after restart) will give me 'no telephone installed', and getting a coding error on 07-Control head:
When adapting the module in 07, VCDS won't show me bluetooth, only the following:
Now, I cannot get the module to work and the coding error to go away. When I start my car, I can see the module with my iPhone and pair, so I know it's working. My MMI is on the latest in Europe, 5570.
How can I fix this? Should a module from an A6 work in an A8?
Here are the module details:
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 0700
Revision: 00000000 Serial number: 00000007510590
Coding: 0010900
Shop #: WSC 98765 666 38033
VCID: 275D061296686426FA7-8072
Also, the rain/light sensor is working (just need to get a new windshield), but sometimes gives me an error in the cluster saying it's defective. When this happens my sidemirrors go black (dimmed). My guess is the power from the roof eletrics is gone sometimes and then the sensor isn't powered either.
I've had my sidemirrors go (and stay) black before, and then had to disconnect my battery before they would be ok again. It seems since i've had the sensor installed it's happening more often. VCDS scan sometimes shows 'button for reading light stuck' but not always.
I have done an optical bus scan with VCDS and it comes out clean.
Does anybody have any ideas on what to replace/change to keep my mirrors from going black? I don't know if the sensor retrofit has anything to do with it, but it's happening more often since I have fitted it. Power issue (battery) maybe?
I can't seem to find the fuse for the dimming function either, anyone?
And one more question, I have had my 20 inch imitation S8 wheels refurbished, and missing one chrome ring as you can see on the pictures (rear right). I've been cheking out Ebay and local shops, but no luck so far. Anyone knows where I can get these? Will OEM S8 rings fit?
Here are some pictures of the wheel:
Thanks, and hope my English is ok
Edit: Sorry for the long post
Coding: 0010900
Code:
Tuesday,16,September,2014,19:39:27:34160 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.3.0 (x64) Data version: 20140822 VIN: WAUZZZ4EX3N006979 License Plate: Mileage: 200430km-124541mi Repair Order: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 69 72 76 77 VIN: WAUZZZ4EX3N006979 Mileage: 200430km/124541miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 E HW: 4E0 907 560 Component: 4.2L V8/5V G01 0040 Revision: 00000000 Serial number: AUX3Z0C0108379 Coding: 0011773 Shop #: WSC 00114 211 55090 VCID: 23451202E2508806A6F-8076 1 Fault Found: 17979 - Left Engine Mount Solenoid Valve (N144) P1571 - 001 - Short to Plus Readiness: 0010 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 HW: 09E 927 156 Component: AG6 09E 4,2L5V RdW 0080 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: DFCDDEF20EB86CE6427-808A No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0420 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 2149180AF84C9A16B43-8074 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0110 Revision: 01103501 Serial number: AUX3Z0C0108379 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: D8BFF5EE6B969BDE03D-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H06 0030 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063232 Shop #: WSC 02312 785 00200 VCID: 23451202E2508806A6F-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 P HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 343B8037511403 Coding: 0000010 Shop #: WSC 50792 001 104857 VCID: 3979D06A70DCE2D69C3-806C Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 301GX047580899 Subsystem 3 - Serial number: 7428.07.040000000000010009ÿ Subsystem 4 - Serial number: 010009ÿ 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 3 Mileage: 200433 km Time Indication: 0 Date: 2014.09.16 Time: 19:25:24 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 015 0190 Revision: 00000013 Serial number: 00000000010866 Coding: 0004097 Shop #: WSC 02311 785 00200 VCID: DABBEFE6159A89CE359-808F 1 Fault Found: 01855 - Temperature Sensor for Heated Seat; Left Front (G344) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 3 Mileage: 200433 km Time Indication: 0 Date: 2014.09.16 Time: 19:20:51 Freeze Frame: Temperature: 29.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H14 0230 Coding: 0123001 Shop #: WSC 02313 785 00200 VCID: 3663DB5641C20DAE711-8063 Subsystem 1 - Part No: 4E1 910 113 Component: Wischer WWS D3 H30 0310 Coding: 00000030 Shop #: WSC 02313 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00141886 Shop #: WSC 02313 1 Fault Found: 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 43 Mileage: 200433 km Time Indication: 0 Date: 2014.09.16 Time: 19:31:13 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H08 0840 Coding: 0430707 Shop #: WSC 02313 785 00200 VCID: E3C5D20222D0480666F-80B6 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H08 0020 Coding: 0012141 Shop #: WSC 02311 785 00200 VCID: E5C1CC1A2CE4363688B-80B0 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0050 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 900 E Component: KOMBIINSTR. VDO H40 0020 Revision: S992703 Serial number: AUDID3C1011753 Coding: 0000103 Shop #: WSC 99916 211 187238 VCID: DCB7E9FE1FAE77FE275-8089 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H06 0040 Revision: 06 Serial number: 0000303126079C Coding: FDFE7BDC3B3104 Shop #: WSC 00000 000 00289 VCID: E5C1CC1A2CE4363688B-80B0 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000501 Serial number: AUZ5ZBC1009999 Shop #: WSC 00000 000 00000 VCID: 1C3729FEDF2EB7FE675-8049 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0110 Revision: 01103501 Serial number: AUX3Z0C0108379 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: D8BFF5EE6B969BDE03D-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 C HW: 4E0 907 553 C Component: LUFTFDR.-CDC H04 4190 Coding: 0011300 Shop #: WSC 00000 000 00000 VCID: 23451202E2508806A6F-8076 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H06 0030 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063234 Shop #: WSC 02312 785 00200 VCID: 23451202E2508806A6F-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H52 1060 Revision: 00000000 Serial number: 353JP057645125 Shop #: WSC 00000 000 00000 VCID: 3B75CA627AE0D0C68EF-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0070 Serial number: 00000302400037 Coding: 0003201 Shop #: WSC 02312 785 00200 VCID: 1D3124FAC434BEF690B-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E1 959 801 Component: Türsteuer.FS BRM004 0080 Coding: 0028448 Shop #: WSC 02311 785 00200 VCID: DEB3E3F609B265EE491-808B No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 HW: 4E0 907 289 Component: Komfortgeraet H02 0050 Coding: 0000088 Shop #: WSC 02311 785 00200 VCID: E6C3CB16D1E23D2E811-80B3 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H12 0460 Revision: PROD_01O Serial number: 00000000103430 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 2A5BFF26857A594EE59-807F No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 HW: 4E0 907 280 A Component: ILM Beifahrer H06 0060 Revision: Serial number: 00000000009353 Coding: 0010101 Shop #: WSC 02311 785 00200 VCID: DDB1E4FA04B47EF650B-8088 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E1 959 802 Component: Türsteuer.BF BRM004 0080 Coding: 0028448 Shop #: WSC 02311 785 00200 VCID: DEB3E3F609B265EE491-808B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000531 Shop #: WSC 80093 222 183701 VCID: 1D3124FAC434BEF690B-8048 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0030 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 02311 785 00200 VCID: E2CBD7063DCA410E6D9-80B7 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304BH037517481 Coding: 0000001 Shop #: WSC 02312 785 00200 VCID: 3169E84AA8AC2A96243-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0510 Revision: 00000000 Serial number: 00000000001867 Shop #: WSC 00114 211 56803 VCID: 204F1D0EF346931EBBD-8075 Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 1301220502 Coding: 303030393135313035414B56413031333031323230353032 Shop #: WSC 00114 211 56803 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM004 0080 Coding: 0028448 Shop #: WSC 02311 785 00200 VCID: DDB1E4FA04B47EF650B-8088 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Labels: 4E0-910-383.lbl Part No SW: 4E0 910 383 A HW: 4E0 907 383 A Component: ANHAENGERELEKTR H01 0010 Coding: 0000001 Shop #: WSC 00114 211 13521 VCID: 224B1706FD4A810EAD9-8077 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM004 0080 Coding: 0028448 Shop #: WSC 02311 785 00200 VCID: DDB1E4FA04B47EF650B-8088 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0011008 Shop #: WSC 02312 785 00200 VCID: E0CFDD0E33C6531E7BD-80B5 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H11 0700 Revision: 00000000 Serial number: 00000007510590 Coding: 0010900 Shop #: WSC 98765 666 38033 VCID: 275D061296686426FA7-8072 No fault code found. End ---------------------------------------------------------------------
Engine mount is being replaced next week, heated seat I'm still looking into.
Did you have the Motorola phone in your A8?
I did and I simply did the pin swap for the Bluetooth connection and it worked without any coding. As long as you have a telephone installed it should be ok to work without coding.
Another possibility is, if you have the proper full voice control installed, the phone module voice control must be turned off. Only one can work at one time.
Full voice control means you can tell the car to change a disc or tell it navigation addresses. Phone voice control is only the phone.
Mike
Mike
Mike
Mike
My car did indeed come with the Motorola phone. First tried it without coding, after I found it didn't work I changed the coding.
And I do not have voice control, this too is something I want to retrofit.
Maybe check your pins connections. Perhaps you have a faulty Bluetooth unit.
Voice control is easy as it just plugs into the radio K box. As long as you get one you can get a dealer to put CD's in for the language and remove the component protection.
Mine came with it already so I was good.
Tip - (look on ebay for an entire K box, with the SDS module in it. Often cheaper than buying the SDS module solo)
Try this: Setup + Car buttons for ~5 sec > Hidden Menu > MMI >APK 0X01, 0X0B, oX0C > Telephone Make check: UHV/BTA if it is not already checked.
0x07 is coded incorrectly.
Try 0000003 or whatever language you desire per the wiki.
The implausible signal on 0x09 usually means wiring.
I'm not convinced it is coded properly either...
Edit: When you install SDS don't code a language there or on module 77
When unplugging the sensor it gives a permanent error code.
I'm thinking this may be because it's not factory build and added afterwards?
Can anyone that has successfully retrofited the sensor confirm if this error message is 'normal' after this retrofit?
And 07 actually is correctly coded I think:
If I change it to something like English (2/3), it changes the spoken navigation language to English. If I set it back to 10 it's on Dutch again.
It was always set to Dutch before and never gave me coding errors, and changing it now does not make my coding error go away.
I will scan my car's coding and upload it tomorrow. I do not have it with me today.
Thank you all for the input, appreciate it.
The implausible signal on 0x09 message is only created once (and everytime) on startup of the car.I can delete it in VCDS and stays away until started again. The wiring should be ok, checked it on both ends. The sensing of light/rain also works.
SVM would still require coding as it would set the module to 'as delivered'
My RLS was 4E0 910 557 but that has probably been superseded,
but it's coding was 00139548
You might have to wait for a retrofit scan from someone.
Ah... I was off a digit thinking you had mute-wire active.
Worst case if you can't find an answer you might want to ask here.
