D4 wheels fit on a D3 with no adapter ?
Sort of. Same bolt pattern but center hole is larger. You need center hole adapter rings. Some guys here run them. Aluminum/metal ones preferred. Big picture, with D4, C7, B8, A/S/RS7, A/S5, Q5 Audi upped the center hole size. So you can run later wheels on earlier ones with the rings. But you can't run earlier wheels on later design vehicles, at least not without a full on spacer adapter.
Took this picture on a Naval base in Virginia while I was there for a wedding back in March. It was the first weekend I had the wheels on. I've gotten a ton of looks & compliments since then. Mishar has these same wheels on his D3 & they look great on his car as well.
Hey awdinut, I tried to respond to your PM but your box is full so I'll post it here.
I'm using aluminum hub centric rings, the size is 57.10 to 66.56 mm. Here is the link to where I bought them on Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Good luck,
Scott
Originally Posted by awdinut
hello
Thanks for the post to my thread about D4 wheels. Dsing metal or plastic adapters and where did you get them and what size does one need ?
Regards
awdinut (Ed)
Regards
awdinut (Ed)
Good luck,
Scott
