Dealership errors what can I do?
So I was replacing my compressor yesterday and I noticed the 3 front belly panel screws were missing. I get my oil change done at the dealership only. I never go anywhere else even for repairs, unless I do them myself (and sometimes for a diagnostic).
Last year while I was driving on a newely paved highway, the front of my belly pan dropped while going about 80mph. It was 1 month after I got an oil change done at the dealership. I called the dealership, zip tied the panel and brought the car in. They told me I must have hit a bump and that there was no way their mechanics couls have forgotten to put in the screws. I told them I didn't hit a bump but they wouldn't replace the belly panel for free. I ended up using my mechanic friends AAA number to buy one at reduced price from them.
So basically is there anything I can do this time? I noticed about half of the wheel liner clips were missing as well. Usually they only forget to put in 1 or 2 but there was only 1 clip on the drivers side.
Unless you find these missing fixing before leaving you have little chance of getting anything out of them.
Upon getting my car, I was missing all but three belly pan screws. The bottom wheel well ones were also gone.
Friend recently came across them and linked me. Compared to the rest of the sites, these prices hit me as very reasonable.
Wheel well
Belly Pan
Got them in the last couple of days and so far the fit and finish looks the same as the three I had originally.
Wheel well
Belly Pan
Amazon.com: 5xSet Under Engine Cover Undertray Kit Screw Metal Clips For Audi VW Skoda 8D0805121: Automotive
I have a small coffee can with these various bit parts in it. They break over time, and some are sort of sacrificial/quasi single use like the fender plastic push pins. The four plastic square shaped receiver pieces on the two ends of the belly pan tend to break over time, and then the screw doesn't seat firmly in them. They can be replaced as long as the square punched hole into which they lock is not broken out. The metal ones used at the front and back of the pan tend to be long lasting, but having the rubber retaining washer originally installed helps both snug them and avoid having something loose fall on road. The side ones use a flexible plastic washer with a similar retaining function.
Net, replace the missing ones and keep a few extra if you plan to own the car longer term.
Flag Route
I've moved to using stainless steel blots, washers and nylon nuts to secure the front of my bell shield. As stated in previous posts, the plastic fasteners will fail.
The night before an oil change, I'll remove the stainless hardware so my mechanic doesn't have to deal with them. When I get the car back, I re-install them. Resting assured that the belly shield is secured and not going anywhere.
Good luck.
Good luck.
You Could Contact AoA
Audi Customer Service - Contact Audi | Audi USA
IMHO, the answer is to find a good independent you trust. It'll be cheaper and better than the dealer. Dealer's are for warranty work only.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
08-11-2022 06:51 AM
lmariorod
10-26-2017 11:39 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
Able89
09-28-2015 05:35 PM
