Disabling TPMS - Page 2 - AudiWorld Forums
Disabling TPMS
Old 06-30-2011, 08:23 AM   #11
Default 2005 A8 TPMS Disabling
This should work on D3s from beginning of 2004 to mid year 2006. I believe 2007 and on may be a little more work?
Step One:
Pop out rear lower bench seat, by grabbing underneath the front of the seat at center of the right seat and center of the left seat. Lift in a popping motion.
Step Two:
Disconnect TPMS Control Module (J502) which is located underneath the left side of the rear bench seat. The module has a part number like 4E0 907 273 and said BERU on it.
Step Three:
Hook up VCDS (VagCOM) and go into address word 19 (CAN-Gateway) and go into Installation List and uncheck 65 Tire Pressure and save. You just recoded the Gateway.
Step Four:
While still in VCDS, go to address word 17 (Instrument Cluster) and go into coding, you are going to remove the TPMS from the long code.
My vehicle's original coding was 0016238.
By subtracting the 16 from 00XX238, we removed the tpms for the clusters coding.
Final Coding 0000238.
TPMS warning is gone!!!!
Any questions, please let me know.
4ringking is offline   Reply With Quote
Old 06-30-2011, 09:53 AM   #12
mishar's Avatar
Why would you disconnect TPMS module? VAG-COM intervention is enough.
mishar is offline   Reply With Quote
Old 07-01-2011, 12:38 PM   #13
Brozee's Avatar
Quote:
Originally Posted by 05SilverA8 View Post
I was so tired of mine showing up on the dash, I tried the fuse routine and that did NOT work. I disabled the unit in the gateway, and re-coded the TPMS (65) to 0202125, which DISABLES the TPMS. Start car, no TPMS nag. If I would have known to change the sensors when I changed the tires I would have done that at the time (exactly 5 years of age on sensors). The Tire Rack has new sensors that are about $89 each.
Speak of the devil now I am getting the "tyre pressure monitoring system malfunction error" Only thing that clears it is the "change wheels option" and then it comes back about 20 minutes later. Car has the original sensors so they must have died and that must be why I am seeing this error. Instead of getting new sensors I would like to avoid this in the future altogether as I don't see the TPMS as a valuable tool to myself; nor worth the price of the replacement sensors and valve stems.
I am taking my car to get it's oil changed and in the meantime I could ask my indy mechanic to just disable the TPMS while he's at it (pretty cool guy). I'm sure he would know how to re-code the TPMS per your instructions, but what did you mean/how did you disable the "gateway"? On top of all this, if I did go the route of buying new sensors would I have to buy just the 4 to get the error to go away, or would I need to buy an additional to make a total of 5 to accommodate to the dead one in the spare tire? I believe if the spare goes dead it doesn't alert you; but I might be wrong.
Thanks
Brozee is offline   Reply With Quote
Old 07-01-2011, 02:24 PM   #14
05SilverA8's Avatar
Default TPMS
As I recall it was as simple as un-checking the TPMS module in the gateway in the VCDS options.
As above: "go into address word 19 (CAN-Gateway) and go into Installation List and uncheck 65 Tire Pressure and save" That removes it from the gateway. You then need to turn it off in the TPMS module or it will throw errors.
05SilverA8 is offline   Reply With Quote
Old 07-01-2011, 02:46 PM   #15
jakematic's Avatar
Quote:
Thanks
My spare has been dead for over a month and just shows --- in MMI.
No errors or messages.
jakematic is offline   Reply With Quote
Old 07-01-2011, 09:34 PM   #16
Brozee's Avatar
So just to be completely clear.
Uncheck 65 in gateway to remove TPMS
Then
While still in VCDS, go to address word 17 (Instrument Cluster) and go into coding, you are going to remove the TPMS from the long code. By subtracting 16?
Thanks, and I'm guessing no physical removal of any fuse or unplugging of anything needs to be done; all is done with the vag-com programming.?
Old 07-01-2011, 10:06 PM   #17
mishar's Avatar
Second part is optional. It can be done through hidden menu too, or just left there for better days when somebody discover reasonably priced sensors. No error code. No unplugging.
Old 07-01-2011, 10:17 PM   #18
Brozee's Avatar
Great thanks, so all that is needed is to uncheck 65 in the gateway then?
Old 07-04-2011, 09:44 AM   #19
05SilverA8's Avatar
Default TPMS
NO - You need to do the long coding of the TPMS module to turn it off as well. I can post a picture if needed but the instructions are above.
Old 07-04-2011, 10:34 AM   #20
Brozee's Avatar
Would you mind posting a picture or just including the instructions in it's entirety to get it disabled once and for all in one single post. Were the instructions above you were referrig to fourringkings?
Thread Thread Starter Forum Replies Last Post
OEM wheels to....>> CobraCommander A8 / S8 (D3 Platform) Discussion 11 09-30-2015 10:14 AM
How do you turn off the speed warning ? LaserSVT Audi A3 / S3 /RS 3 MKII 1 09-29-2015 09:34 PM
Memory seat settings gone? ex-quattro PETE Q5/SQ5 MKI (8R) Discussion 1 09-29-2015 04:45 AM
Audi A5 FS 2011 A5 w/ Prestige and S-Line 517 Vehicles For Sale 1 09-25-2015 06:24 AM
TPMS on SQ5 asmi84 Q5/SQ5 MKI (8R) Discussion 0 09-12-2015 06:18 AM
Tags
2004, 2006, a4, a5, a8, a8l, audi, disable, disabling, monitor, monitoring, pressure, system, tire, tpms
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
