disconnect battery overnight--now variant rpm...
rpm jumping around today after disconnecting battery last night.
car drives ok, but not perfect.
example--was going 100km hr and rpm dropped from 3k to 2k and kept driving.
seems just rpm is jerking around.
i suspect a throttle body alignment after loss of power
cus day before all was fine
OK! I call uncle. Please
I've spent all morning tying to determine the location of my throttle body so I can clean it.
I cannot find a picture anywhere.
can someone please help ?
If you can't find it, I'm not sure you should be fiddling around the engine bay. If you insist, however, it is on the back of the engine. Follow the air intake right to it.
Supply Voltage Terminal 30---showing up on a lot of scans.
I am aware of the Ross Tech advice.
I did have the battery disconnected. It is about 18 months old only.
It's the loss of rpm and needle moving with kind of vibration.
one post thought torque was an issue.....
praying it's fuel or electrical (some electrical anyway)
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CN528780
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4DC484CEFD2AD9775-804A
6 Faults Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - MIL ON
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - Intermittent - MIL ON
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0025539
Coding: 0000002
VCID: 2447CB68E79B09012A7-8071
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2149C27CF8891C29411-8074
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN528780
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58BFAF98EB539DE176F-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2345C874E2950E3953D-8076
1 Fault Found:
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 72
Mileage: 171016 km
Time Indication: 0
Date: 2015.03.29
Time: 15:01:57
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346KX037507960
Coding: 0000103
Shop #: WSC 93250 999 64609
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301KR037529419
Subsystem 3 - Serial number: 7424.11.030000000000010054ÿ
Subsystem 4 - Serial number: 010054ÿ
1 Fault Found:
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 9
Reset counter: 83
Mileage: 167536 km
Time Indication: 0
Date: 2015.01.31
Time: 09:29:39
Freeze Frame:
Bin. Bits: 01011100
Bin. Bits: 0010010
Bin. Bits: 100
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000030928
Coding: 1085697
VCID: 5ABBB590955F8FF140B-800F
2 Faults Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 158
Reset counter: 99
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.25
Time: 06:16:23
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 171501 km
Time Indication: 0
Date: 2015.04.06
Time: 18:03:21
Freeze Frame:
Temperature: 35.0°C
Speed: 0.0 km/h
(no units): 69.0
(no units): 169.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111104
VCID: 2A5B255085BFDF7110B-807F
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02313
3 Faults Found:
01498 - Bulb for Parking Lamps; Right (M3)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 172926 km
Time Indication: 0
Date: 2003.06.20
Time: 03:47:22
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 172926 km
Time Indication: 0
Date: 2003.06.20
Time: 03:47:22
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 172926 km
Time Indication: 0
Date: 2003.06.20
Time: 03:47:22
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7278896
Shop #: WSC 00000 000 00000
VCID: 1B35F094DAE536F99BD-804E
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 131
Mileage: 166238 km
Time Indication: 0
Date: 2015.01.05
Time: 13:56:03
Freeze Frame:
Text: 00001413
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 100
Mileage: 172508 km
Time Indication: 0
Date: 2015.04.20
Time: 20:01:22
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012041
Shop #: WSC 93250 999 53700
VCID: 65C1966CAC213009FD9-8030
Component: Lenkradmodul H03 0070
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H44 0080
Revision: D13 Serial number: AUDID3CN021320
Coding: 0000333
Shop #: WSC 93250 999 65003
VCID: 5CB7B3889F6B71C1527-8009
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 0200503B110F17
Coding: FCFE7BDC1B2304
VCID: 2643D16091A7FB11343-8073
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 93250 999 80931
VCID: 2541D66CECA1F0093D9-8070
5 Faults Found:
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 238
Reset counter: 110
Mileage: 170114 km
Time Indication: 0
Date: 2015.03.07
Time: 09:29:48
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 108
Mileage: 172670 km
Time Indication: 0
Date: 2003.06.18
Time: 00:01:18
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Mileage: 172738 km
Time Indication: 0
Date: 2003.06.18
Time: 10:32:59
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 154
Reset counter: 70
Mileage: 167520 km
Time Indication: 0
Date: 2015.01.30
Time: 17:58:25
01577 - Turn-Off due to Over-Temp
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 91
Mileage: 169586 km
Time Indication: 0
Date: 2015.02.28
Time: 15:46:11
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
5 Faults Found:
01454 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Back
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 93
Mileage: 171864 km
Time Indication: 0
Date: 2015.04.12
Time: 08:43:26
01453 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Forward
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 93
Mileage: 171864 km
Time Indication: 0
Date: 2015.04.12
Time: 08:43:26
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 62
Reset counter: 70
Mileage: 89788 km
Time Indication: 0
Date: 2011.07.29
Time: 08:50:42
01456 - Driver's Seat Switch for Seatback Adjust (E96); Back
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 93
Mileage: 171996 km
Time Indication: 0
Date: 2015.04.12
Time: 02:05:46
01455 - Driver's Seat Switch for Seatback Adjust (E96); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 93
Mileage: 171996 km
Time Indication: 0
Date: 2015.04.12
Time: 02:05:46
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H42 0740
Revision: 00000000 Serial number: 355KM037511180
VCID: 387F0F184B137DE196F-806D
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000331700001
Coding: 0003973
VCID: 1D31FE8CC4F138C9659-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EB3B980897763D13C3-800B
1 Fault Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 90
Mileage: 172192 km
Time Indication: 0
Date: 2015.04.15
Time: 11:41:42
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040311190246
Coding: 0064542
VCID: 275DDC6496ADE2190F5-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
10 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 70
Mileage: 172850 km
Time Indication: 0
Date: 2003.06.19
Time: 08:26:02
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 70
Mileage: 136118 km
Time Indication: 0
Date: 2013.12.02
Time: 09:45:56
00984 - Left Tail Light (M4)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Reset counter: 70
Mileage: 114099 km
Time Indication: 0
Date: 2004.08.14
Time: 15:21:10
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 70
Mileage: 110536 km
Time Indication: 0
Date: 2004.05.05
Time: 12:26:17
01828 - Bulb for Tail-Lamp; Left
Freeze Frame:
Fault Priority: 3
Reset counter: 45
Mileage: 112094 km
Time Indication: 0
Date: 2004.06.16
Time: 14:24:30
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 148131 km
Time Indication: 0
Date: 2003.12.20
Time: 14:42:58
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 48
Mileage: 157866 km
Time Indication: 0
Date: 2004.03.22
Time: 20:38:32
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 136118 km
Time Indication: 0
Date: 2013.12.02
Time: 09:45:56
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 172850 km
Time Indication: 0
Date: 2003.06.19
Time: 08:26:02
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 159
Reset counter: 70
Mileage: 172363 km
Time Indication: 0
Date: 2015.04.16
Time: 21:47:52
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 M HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0450
Revision: Dev_D01 Serial number: 00000000546392
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000028129
Coding: 0010111
VCID: 1E33F980C9F723D17C3-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T08QWE
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 110
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 25
Reset counter: 106
Mileage: 170632 km
Time Indication: 0
Date: 2015.03.24
Time: 17:22:58
Freeze Frame:
Voltage: 13.56 V
Count: 236
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Time Indication: 0
Freeze Frame:
Voltage: 9.42 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 62CB8D70BD0F473118B-8037
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0480
Revision: 00000000 Serial number: 304KL037553116
Coding: 0000002
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 105
Mileage: 170684 km
Time Indication: 0
Date: 2015.03.24
Time: 18:55:48
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005308435
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1310310247
Coding: 303030393135313035414B56413031333130333130323437
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:01
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 11:32:29
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 12:35:00
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 12:35:28
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 12:35:38
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
VCID: 5DB1BE8C847178C9259-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3006547
Coding: 0000005
Shop #: WSC 93250 999 83976
VCID: 60CF8778B00355210EF-5140
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000333000100
Coding: 0001208
3 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 70
Mileage: 170645 km
Time Indication: 0
Date: 2015.03.24
Time: 18:24:07
01545 - Sensor for Parking Aid; Rear Left (G203)
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 3
Fault Frequency: 150
Reset counter: 8
Mileage: 168239 km
Time Indication: 0
Date: 2015.02.12
Time: 21:26:51
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 8
Mileage: 170646 km
Time Indication: 0
Date: 2015.03.24
Time: 18:24:16
End-------------------------
Coding: 0007773
6 Faults Found:
Coding: 0000002
Coding: 0007597
2 Faults Found:
Coding: 0263168
Component: ELV XXXX
Coding: 3940448
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 72
Mileage: 171016 km
Time Indication: 0
Date: 2015.03.29
Time: 15:01:57
Coding: 0000103
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 83
Mileage: 167536 km
Time Indication: 0
Date: 2015.01.31
Time: 09:29:39
Freeze Frame:
Bin. Bits: 01011100
Bin. Bits: 0010010
Bin. Bits: 100
Coding: 1085697
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 99
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.25
Time: 06:16:23
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 171501 km
Time Indication: 0
Date: 2015.04.06
Time: 18:03:21
Freeze Frame:
Temperature: 35.0°C
Speed: 0.0 km/h
(no units): 69.0
(no units): 169.0
Coding: 0111104
Coding: 00000030
Shop #: WSC 02313
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 172926 km
Time Indication: 0
Date: 2003.06.20
Time: 03:47:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 172926 km
Time Indication: 0
Date: 2003.06.20
Time: 03:47:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 172926 km
Time Indication: 0
Date: 2003.06.20
Time: 03:47:22
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 131
Mileage: 166238 km
Time Indication: 0
Date: 2015.01.05
Time: 13:56:03
Freeze Frame:
Text: 00001413
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 100
Mileage: 172508 km
Time Indication: 0
Date: 2015.04.20
Time: 20:01:22
Coding: 0530707
Coding: 0012041
Coding: 0000333
Coding: 0263168
Component: ELV XXXX
Coding: 0015510
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 110
Mileage: 170114 km
Time Indication: 0
Date: 2015.03.07
Time: 09:29:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 108
Mileage: 172670 km
Time Indication: 0
Date: 2003.06.18
Time: 00:01:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Mileage: 172738 km
Time Indication: 0
Date: 2003.06.18
Time: 10:32:59
000 - -
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 167520 km
Time Indication: 0
Date: 2015.01.30
Time: 17:58:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 91
Mileage: 169586 km
Time Indication: 0
Date: 2015.02.28
Time: 15:46:11
Coding: 4071522
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 93
Mileage: 171864 km
Time Indication: 0
Date: 2015.04.12
Time: 08:43:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 93
Mileage: 171864 km
Time Indication: 0
Date: 2015.04.12
Time: 08:43:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 70
Mileage: 89788 km
Time Indication: 0
Date: 2011.07.29
Time: 08:50:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 93
Mileage: 171996 km
Time Indication: 0
Date: 2015.04.12
Time: 02:05:46
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 93
Mileage: 171996 km
Time Indication: 0
Date: 2015.04.12
Time: 02:05:46
Coding: 0003973
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 90
Mileage: 172192 km
Time Indication: 0
Date: 2015.04.15
Time: 11:41:42
Coding: 0064542
10 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 172850 km
Time Indication: 0
Date: 2003.06.19
Time: 08:26:02
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 136118 km
Time Indication: 0
Date: 2013.12.02
Time: 09:45:56
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 114099 km
Time Indication: 0
Date: 2004.08.14
Time: 15:21:10
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 110536 km
Time Indication: 0
Date: 2004.05.05
Time: 12:26:17
Freeze Frame:
Fault Priority: 3
Reset counter: 45
Mileage: 112094 km
Time Indication: 0
Date: 2004.06.16
Time: 14:24:30
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 148131 km
Time Indication: 0
Date: 2003.12.20
Time: 14:42:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 48
Mileage: 157866 km
Time Indication: 0
Date: 2004.03.22
Time: 20:38:32
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 136118 km
Time Indication: 0
Date: 2013.12.02
Time: 09:45:56
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 172850 km
Time Indication: 0
Date: 2003.06.19
Time: 08:26:02
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 172363 km
Time Indication: 0
Date: 2015.04.16
Time: 21:47:52
Coding: 0000016
Coding: 0010111
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 110
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Coding: 0028196
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 106
Mileage: 170632 km
Time Indication: 0
Date: 2015.03.24
Time: 17:22:58
Freeze Frame:
Voltage: 13.56 V
Count: 236
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Time Indication: 0
Freeze Frame:
Voltage: 9.42 V
Count: 61
Coding: 0000001
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 105
Mileage: 170684 km
Time Indication: 0
Date: 2015.03.24
Time: 18:55:48
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:01
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 11:32:29
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 12:35:00
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 12:35:28
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163698 km
Time Indication: 0
Date: 2003.06.18
Time: 12:35:38
Coding: 0028196
Coding: 0028196
Coding: 0000005
1 Fault Found:
Coding: 0001208
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 70
Mileage: 170645 km
Time Indication: 0
Date: 2015.03.24
Time: 18:24:07
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Reset counter: 8
Mileage: 168239 km
Time Indication: 0
Date: 2015.02.12
Time: 21:26:51
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 8
Mileage: 170646 km
Time Indication: 0
Date: 2015.03.24
Time: 18:24:16
i'm wondering if the guy adapted my new battery 18 months ago ??
and if that would be playing a role if he didnt ?
getting the terminal 30 in a few addresses
like I said I did have battery out.
scanned, cleared, need to take another drive
then rescan
then rescan
Nevermind
It was getting late for me yesterday and I never thought to look at your vcds scan.
The engine code i was asking about is BFM
I think you need to have a good read through these and get an understanding of the various systems to then go fault find properly.
BFM Manual
Electrical
Gearbox
Brakes
Communications
Electrical General
Electrical Systems
Fuel Supply
Fuel Supply
Maintenance
Ingnition System
Service Gearbox
A8 Technical Features
09E Gearbox Part 1
09E Gearbox Part 2
BFM Manual
Electrical
Gearbox
Brakes
Communications
Electrical General
Electrical Systems
Fuel Supply
Fuel Supply
Maintenance
Ingnition System
Service Gearbox
09E Gearbox Part 1
09E Gearbox Part 2
It really sounds like a module lost it's memory and now needs to re-learn it's settings.
It could also be that a module just didn't initialize correctly. I would disconnect the battery, touch the battery cables together to remove any residual charge, wait 5 minutes, then reconnect the battery.
I did a Throttle Body Alignment then Ross Tech
suggests a similar procedure for the transmission through Basic Settings
but I was unable to access basic settings (it was greyed out)I tried with power but no engine
then tried with engine running.
I will be checking the ATF level later today
but I am curious about the coincidence of me disconnecting the battery the other day
then the start of this variant rpm poor driving.
after ATF and some drives, I will move on to my SAI issue and vaccum leaks.
