Does Manually Operating the Power Trunk Damage its Motor?
Sometimes I forget and just yank the trunk up, and I wondered if anyone who's taken the trunk motor apart or who understands the workings of the clutch could give an opinion. Also closing (faster than the motor does) by hand. I don't want to make the clutch slip any more than necessary. I had to remove the 50-pound tow hook and lug wrench because the trunk occasionally wouldn't launch. Cleaned and lubed hinges thoroughly and bought new struts, going to pop them on today.
Tom
Tom
If you open it fast or close manually clutch doesn't engage, so it is just like any nonmotorized trunk.
No damage.
If you open it slowly clutch will engage and you can't make it open much faster than motor dictates. Motorized closing has to be initiated by the button.
No damage.
AudiWorld Wiseguy
No problem.
Clutch is only engaged whilst motor is running. All other times the clutch is open. Manually operating the trunk lid doesn't trigger the motor or clutch to engage so it's not possible to damage as a result.
Clutch and motor can only be engaged by activating them via the various buttons (key fob, trunk lid, drivers door).
For safety, the system monitors the current draw of the motor, and if it exceeds a predetermined value (such as when it's binding or there's an obstruction) it automatically disengages the clutch and stops the motor.
In short, manually operating the lid does not cause any wear to the lid motor or clutch mechanism.
Dave,
If the trunk is opened via its handle, is the delay between when it pops and when the motor/clutch are actuated enough time to open manually w/o the clutch engaging? Or does it sense it's being lifted by hand and disengage?
I learned it's a magnetic clutch here; now I get it.
Never fails to elicit reactions from passersby. I thought I was special. Sadly, I saw a HYUNDAI open like it the other day. What will they copy next?
I would remove the motor or disconnect the power if it doesn't lift any more. It's lighter and you don't have to wait for it going up slowly. It's a bad design. D4 copied Hyundai and it works flawlessly.
Cheers,
Louis
Cheers,
Louis
Mine works 90% of the time, and I have two new struts sitting on my armchair's arm which I hope will fix the 10%. I guess they have to actually on the car so I'll try that next. *derp*
AudiWorld Wiseguy
Thanks guys.
Dave,
Dave,
RE Hyundai and the like, it's easy to make stuff reliable when the kit you put in your latest cars is decade old tech that's been developed to perfection by everyone else.
I wonder if they'd have the ***** to pull the trigger on active air suspension....10yr/100k warranty, haha, yea right!
icys4
Audi Original "S" Cars
18
02-07-2008 01:50 PM
ESFO
01-02-2006 06:46 PM
