Emergency: parking brake warning all of a sudden.
Car hs been driving great. I dont use the parking brake.
Shut car down 15 mins later i go to restart and the button is flashing and loud annoying beeping from dash and flashing parking brake light. It is not stuck on the car moves forward just fine. Any ideas?
I should add, few days ago when i **** the car off and press lock there was a liud whitring noise from the rear wheel area for about 5-6 seconds then stopped...
Any ideas? Im 1400 miles from home and cant atand this dash noise. No vagcom with me.
Txt me of this is a simple fix plz
248 606 5346
248 606 5346
Need to scan, but you likely have a parking brake malfunction--or at least it thinks so. It re calibrates itself every so often--the whirring you heard the other day was that calibration most likely. It may have cycled yet again--it often does right when I complete a long road trip type drive and shut down from my D3 experience.
If you are way away from home, maybe go to somewhere that advertises free scans (like Midas?) and see what they pull, plus get them to clear codes. Of course they need a scan tool that does more than just engine. If it settles down for now with a code clear that sticks, maybe you can get home.
I feel the pass rear engage and disengage but the right one i dont feel or hear anything when cucling it. I disconnected battery for 10 mins no change. Im trying to unplug the big plug on the driver sensor but im working blind and cant figure how to unplug it
So i unplugged battry again, got in and tried turning parking brake off, the flashing parking brake light and sound are off but still have the flashing brake light and the flashing yellow prk brake light in top right corner of center display..
FWIW those big plugs at rear wheels are very hard to get off. Been there, tried that. But having not succeeded, IIRC car kind of barfs electronically if you do succeed, at least w/ out VCDS to reset things.
Try disconnecting the battery for 30 minutes or more. Or all night if parked somewhere. Might reset things as you were thinking. Works once in a while for various electrical gremlins, but more like 30 minutes is what sticks in my mind for whatever reason.
Assuming the brake isn't hung up. (you'd know that by the burning smell after driving with the brake on). My guess is you aren't happy with the beeeeeep, which repeats every time you stop at a light and start up again.
Your problem could be like mine where some spurious wires, grounds or module might be intermittent. BTW, my problems started exactly as yours with the parking brake warning, noise, etc. It graduated to ABS, ESP, no speedometer function and more.
My solution to the beeeeeeeep was to unplug the two brake motor 30 AMP fuses. On my car, they are located under the cover in the right side of the trunk, the two fuses (I think they are blue) were the last at the bottom of the panel. I still have the brake flashing light and a momentary beep when the ABS comes on, but no continuous beep at every start.
Scanned the car a few days ago, here is the log. The level height and door issues are new too, but have not noticed any strange behavior with anything though...main concern right now is to get the ebrake fixed. Really would like to not spend 450$ on a new motor.
ALso some of these com and intermittent errors, as well as the battery regulator error..could it be from an old battery, which from reading, causes all sorts of random issues..
When i check on VCDS the battery level shows 70%. Looks to be original.
Thanks.
Friday,21,October,2016,16:31:10:07205
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
Ross-Tech: Home
VIN: WAUPN94EX8N000738 License Plate: JENYBUG
Mileage: 129510km-80473mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN94EX8N000738 Mileage: 129510km-80473miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BSM) Labels: Redir Fail!
Part No SW: 4E0 910 552 K HW: 4E0 907 552 A
Component: 5.2L V10/4V FSI ª0040
Revision: 5IH02--- Serial number: AUX3Z0G7728452
Coding: 01060009190F0160
Shop #: WSC 94817 999 177420
VCID: 2A5BC12A85E30C12C2-807E
4 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.31
Time: 07:49:57
Freeze Frame:
RPM: 673 /min
Load: 30.2 %
Speed: 4.0 km/h
Temperature: 99.0°C
Temperature: 34.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 128100 km
Time Indication: 0
Date: 2016.10.17
Time: 00:02:19
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 68.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 129512 km
Time Indication: 0
Date: 2016.10.21
Time: 16:20:40
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 18.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.811 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H03--- Serial number: 0111352
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 24472F12E7C7DA62F8-8070
1 Fault Found:
049458 - Ride Level Control Module
U0132 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124439 km
Time Indication: 0
Date: 2016.10.01
Time: 09:05:45
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT
Component: ESP 5.7 allrad H49 0650
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 2B55C42E8A19151A39-807E
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G7728452
Coding: 0410624
VCID: 58BF4BE2EB0F4E82A4-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 39
Mileage: 122320 km
Time Indication: 0
Date: 2016.08.31
Time: 07:53:32
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 120
Mileage: 124432 km
Time Indication: 0
Date: 2016.09.29
Time: 20:06:48
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 02313 758 00200
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348HY077526066
Coding: 0000003
VCID: 224B290AFDD3D4528A-8076
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000043940
Subsystem 3 - Serial number: 0106.08.070000000100010058ÿ
Subsystem 4 - Serial number: 010058ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000129117
Coding: 0041409
VCID: 1C3717F2DFB7E2A240-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E1 955 113 C
Component: ILM Fahrer H16 0240
Coding: 0133123
VCID: 387FEB624B4FAE8244-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00139548
Shop #: WSC 02313
2 Faults Found:
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 145
Mileage: 0 km
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 0 km
Time Indication: 0
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 275D381E56F1317ADD-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0129186
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F6DD03EBE01693A15-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 69
Mileage: 124198 km
Time Indication: 0
Date: 2016.09.17
Time: 20:12:01
Address 11: Engine II Labels: Redir Fail!
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 128100 km
Time Indication: 0
Date: 2016.10.17
Time: 00:02:19
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 68.0°C
Voltage: 11.811 V
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV00003GM
Coding: 0532707
VCID: 29593E2680E5070ACB-807C
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 00XW4
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB402D04259Dÿ†63
Subsystem 5 - Serial number: 04259Dÿ†63428RB402D052B2Eÿ†63
Subsystem 6 - Serial number: 052B2Eÿ†63528RB402D04AEF ÿ†63
Subsystem 7 - Serial number: 04AEF ÿ†63628RB402D0534AIÿ†63
Subsystem 8 - Serial number: 0534AIÿ†63729RB402915A6BRÿ†63
Subsystem 9 - Serial number: 15A6BRÿ†63829RB40290F966Vÿ
Subsystem 10 - Serial number: 0F966Vÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H04000 Serial number: 90026071910121
Coding: 0012141
VCID: 2643351A91FB2872E6-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 N HW: 4E0 920 951 N
Component: KOMBIINSTR. VDO H83 0620
Revision: D02 Serial number: AUDID3G7000135
Coding: 0048383
Shop #: WSC 15398 002 1048576
VCID: 306FD342A33F76C20C-8064
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B074248119
Coding: F5D5DFFF707A0E00
VCID: 2D51CA36B40D1B2A27-8078
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 124439 km
Time Indication: 0
Date: 2016.09.30
Time: 22:06:40
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 124439 km
Time Indication: 0
Date: 2016.10.01
Time: 09:05:45
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3455890
VCID: 183F0BE22B8F8E8264-804C
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0012510
VCID: 2C57C7328F17122230-8078
2 Faults Found:
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 118
Mileage: 124439 km
Time Indication: 0
Date: 2016.09.30
Time: 21:29:06
01487 - System Function Test
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 11101111
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H50 0990
Revision: 00000000 Serial number: 395HU077503263
VCID: 3169D646A8357FCA03-8064
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000718400118
Coding: 0003479
VCID: 1D311AF6C4ADEBAAB7-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028204
VCID: 204F2302F3DFC6429C-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0010
Revision: 00100010 Serial number: W040708080089
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000001563
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000008043
Coding: 0010111
VCID: 1E331DFAC9ABF0B2AE-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T1BJZ05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028204
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000732
Shop #: WSC 42193 001 1048576
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 145
Mileage: 128096 km
Time Indication: 0
Date: 2016.10.17
Time: 00:05:27
Freeze Frame:
Voltage: 13.15 V
Count: 160
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 7
Reset counter: 105
Mileage: 128096 km
Time Indication: 0
Date: 2016.10.17
Time: 18:35:49
Freeze Frame:
Voltage: 11.49 V
Count: 86
02430 - Left Parking Brake Motor (V282) Resistance to Movement
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00110011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 145
Mileage: 128096 km
Time Indication: 0
Date: 2016.10.17
Time: 18:35:48
Freeze Frame:
Voltage: 11.18 V
Count: 88
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 124440 km
Time Indication: 0
Date: 2016.10.01
Time: 09:05:45
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396H5077577908
Coding: 0000002
VCID: 2E53CD3AB90B60321E-807A
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010969
Shop #: WSC 03164 444 83924
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2708070212
Coding: 344530393135313035412056413032373038303730323132
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.30
Time: 23:16:47
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.30
Time: 23:23:13
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.30
Time: 23:23:24
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 6
Reset counter: 154
Mileage: 124439 km
Time Indication: 0
Date: 2016.10.01
Time: 04:07:44
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 124439 km
Time Indication: 0
Date: 2016.09.29
Time: 20:47:57
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028204
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900052756
Coding: 0232428
5 Faults Found:
01467 - Front Left Tire Pressure Sensor (G222)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 46.0
Temperature: 127.0°C
01468 - Front Right Tire Pressure Sensor (G223)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 49.0
Temperature: 17.0°C
Temperature: 16.0°C
Temperature: 17.0°C
01469 - Rear Left Tire Pressure Sensor (G224)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 52.0
Temperature: 17.0°C
Temperature: 17.0°C
01470 - Rear Right Tire Pressure Sensor (G225)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 55.0
Temperature: 17.0°C
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 253
Reset counter: 0
Mileage: 124752 km
Time Indication: 0
Date: 2016.10.05
Time: 16:59:56
Freeze Frame:
(no units): 70.0
Temperature: 24.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000707300046
Shop #: WSC 12336 024 394758
VCID: 3467DF5257274AE268-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7710OZ
Coding: 1121402
VCID: 5CB757F29F37A2A280-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028204
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720722206576
Coding: 0221208
VCID: 23452C0EE2C9DD5A81-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005005037
Coding: 0010900
VCID: 25413216ECFD236AEF-8070
End-------------------------(Elapsed Time: 04:35)--------------------------
Thanks.
Ross-Tech: Home
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.31
Time: 07:49:57
Freeze Frame:
RPM: 673 /min
Load: 30.2 %
Speed: 4.0 km/h
Temperature: 99.0°C
Temperature: 34.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 128100 km
Time Indication: 0
Date: 2016.10.17
Time: 00:02:19
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 68.0°C
Voltage: 11.938 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 129512 km
Time Indication: 0
Date: 2016.10.21
Time: 16:20:40
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 18.0°C
Voltage: 11.811 V
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 124439 km
Time Indication: 0
Date: 2016.10.01
Time: 09:05:45
Coding: 0001627
1 Fault Found:
Coding: 0410624
Component: ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 39
Mileage: 122320 km
Time Indication: 0
Date: 2016.08.31
Time: 07:53:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 120
Mileage: 124432 km
Time Indication: 0
Date: 2016.09.29
Time: 20:06:48
Coding: 4071520
Coding: 0000003
Coding: 0041409
Coding: 0133123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 145
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 0 km
Time Indication: 0
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 69
Mileage: 124198 km
Time Indication: 0
Date: 2016.09.17
Time: 20:12:01
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 128100 km
Time Indication: 0
Date: 2016.10.17
Time: 00:02:19
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 68.0°C
Voltage: 11.811 V
Coding: 0532707
Coding: 0012141
Coding: 0048383
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 124439 km
Time Indication: 0
Date: 2016.09.30
Time: 22:06:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 124439 km
Time Indication: 0
Date: 2016.10.01
Time: 09:05:45
Coding: 0012510
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 118
Mileage: 124439 km
Time Indication: 0
Date: 2016.09.30
Time: 21:29:06
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Coding: 4071530
Coding: 0003479
Coding: 0028204
Coding: 0048686
Coding: 0000026
Coding: 0010111
Coding: 0028204
Revision: --H03---
Coding: 0000732
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 145
Mileage: 128096 km
Time Indication: 0
Date: 2016.10.17
Time: 00:05:27
Freeze Frame:
Voltage: 13.15 V
Count: 160
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 105
Mileage: 128096 km
Time Indication: 0
Date: 2016.10.17
Time: 18:35:49
Freeze Frame:
Voltage: 11.49 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 145
Mileage: 128096 km
Time Indication: 0
Date: 2016.10.17
Time: 18:35:48
Freeze Frame:
Voltage: 11.18 V
Count: 88
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 124440 km
Time Indication: 0
Date: 2016.10.01
Time: 09:05:45
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.30
Time: 23:16:47
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.30
Time: 23:23:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 122329 km
Time Indication: 0
Date: 2016.08.30
Time: 23:23:24
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 154
Mileage: 124439 km
Time Indication: 0
Date: 2016.10.01
Time: 04:07:44
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 124439 km
Time Indication: 0
Date: 2016.09.29
Time: 20:47:57
Coding: 0028204
Coding: 0232428
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 46.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 49.0
Temperature: 17.0°C
Temperature: 16.0°C
Temperature: 17.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 52.0
Temperature: 17.0°C
Temperature: 17.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 124685 km
Time Indication: 0
Date: 2016.10.05
Time: 08:47:16
Freeze Frame:
(no units): 122.0
Voltage: 0.40 V
(no units): 55.0
Temperature: 17.0°C
Freeze Frame:
Fault Priority: 3
Reset counter: 0
Mileage: 124752 km
Time Indication: 0
Date: 2016.10.05
Time: 16:59:56
Freeze Frame:
(no units): 70.0
Temperature: 24.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1121402
Coding: 0028204
Coding: 0221208
Coding: 0010900
