Big mess after battery replacement
Happy new year to all of you.
About a week ago, my battery died and tried to jump and didn't budge so I bought a brand new battery and replaced it myself. After wards, car started but I think it messed up some electronic crap. Now my MMI is completely shut down with display stuck open. Sometimes, car won't even start, it doesn't even crank. I give some time and try it and it's hit or miss.
What do I do now?? I really don't want to take it to stealership.
Any advice??
Any advice??
Well first off, the new battery has to be recoded via VCDS cable. Try turning off the ignition and turn it back on and hold down the volume button to see if the mmi comes on. How long have you had your new battery in there?? Does anything else not work??
Maybe something simple...
There is a little wire that fastens to the positive battery post under the 10mm nut you have to undo. Did you reconnect that wire, or did it get broken?
If I recall right from some other posts, that wire ties into the power management module and thus would be important. If the car does not see the battery as correctly charged, it will shut down things it views as less important. MMI is among them; it also shuts down keyless entry very early on (if you have that) as another clue. Along the way, it also sheds the remote key locking, though not as early as the keyless entry.
Sorry, I was out of town and just got back. I'll try to look at the wire tomorrow if possible. I left my car at my parents house while I'm using my dad's car.
Hopefully, it's something simple.
Jump started off the 'jumper posts' presumably?
My experience is that with an incorrectly coded battery, you'll get all sorts of issues, such as those you describe.. Do you have, or have access to, VCDS? If not, you may be on the way to the dealer for a recode... search for battery threads on here.
K9
K9
3 months I replaced my battery and did not code it.
Now when the car stays 1 week then my alarm led's in the car shut down, so I knew some electronics go down, the new battery don't have a BEM code so I took the BEM code from a know brand which is in the list when open with VCDS, no problems anymore...
Here are VAG readings
Tuesday,07,January,2014,12:29:38:27737
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAULV44E77N011468 License Plate: AUDIA8
Mileage: 170190km-105751mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAULV44E77N011468 Mileage: 170190km/105751miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: 71H16--- Serial number: AUX3Z0F9708786
Coding: 01060009190F0120
Shop #: WSC 06204 444 84051
VCID: 204433EBF3AFBA1EB43-8075
8 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 3.0캜
Temperature: 9.0캜
Absolute Pres.: 990.0 mbar
Voltage: 12.192 V
001672 - ECM Power Relay Load Circuit: (J271)
P0688 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 169096 km
Time Indication: 0
Date: 2013.12.23
Time: 15:25:54
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 2.0캜
Temperature: 7.0캜
Absolute Pres.: 1000.0 mbar
Voltage: 11.430 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0캜
Temperature: -40.0캜
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 169096 km
Time Indication: 0
Date: 2013.12.23
Time: 00:02:02
Freeze Frame:
RPM: 1261 /min
Load: 43.5 %
Speed: 0.0 km/h
Temperature: 3.0캜
Temperature: 8.0캜
Voltage: 13.335 V
008224 - Intake Manifold Flap Position Sensor (Bank 2)
P2020 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 169096 km
Time Indication: 0
Date: 2013.12.23
Time: 00:02:02
Freeze Frame:
RPM: 1261 /min
Load: 43.5 %
Speed: 0.0 km/h
Temperature: 3.0캜
Temperature: 8.0캜
Voltage: 13.335 V
012424 - Starter Relay
P3088 - 001 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 169985 km
Time Indication: 0
Date: 2013.12.27
Time: 14:56:36
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 60.0캜
Temperature: 51.0캜
Absolute Pres.: 980.0 mbar
Voltage: 11.811 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170195 km
Time Indication: 0
Date: 2014.01.02
Time: 20:31:12
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 15.0캜
Temperature: 15.0캜
Voltage: 12.192 V
001153 - Coolant Fan Control Circuit 2
P0481 - 004 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170195 km
Time Indication: 0
Date: 2014.01.02
Time: 20:31:12
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 15.0캜
Temperature: 15.0캜
Voltage: 12.192 V
Readiness: 0000 0000
8 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 3.0캜
Temperature: 9.0캜
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 169096 km
Time Indication: 0
Date: 2013.12.23
Time: 15:25:54
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 2.0캜
Temperature: 7.0캜
Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0캜
Temperature: -40.0캜
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 169096 km
Time Indication: 0
Date: 2013.12.23
Time: 00:02:02
Freeze Frame:
RPM: 1261 /min
Load: 43.5 %
Speed: 0.0 km/h
Temperature: 3.0캜
Temperature: 8.0캜
Voltage: 13.335 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 169096 km
Time Indication: 0
Date: 2013.12.23
Time: 00:02:02
Freeze Frame:
RPM: 1261 /min
Load: 43.5 %
Speed: 0.0 km/h
Temperature: 3.0캜
Temperature: 8.0캜
Voltage: 13.335 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 169985 km
Time Indication: 0
Date: 2013.12.27
Time: 14:56:36
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 60.0캜
Temperature: 51.0캜
Voltage: 11.811 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170195 km
Time Indication: 0
Date: 2014.01.02
Time: 20:31:12
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 15.0캜
Temperature: 15.0캜
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170195 km
Time Indication: 0
Date: 2014.01.02
Time: 20:31:12
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 15.0캜
Temperature: 15.0캜
Voltage: 12.192 V
