Sponsored by:
Sponsored by:
EPB Help
Old 02-07-2017, 06:11 PM
jeffkruse's Avatar
Default EPB Help
I get the follow DTC's I have removed and cleaned the connections on each side, did a Terminal 30 reset and still get the errors. My question is what next, the module, and if I get a different module can I recode it with my VCDS. Will I get the component protection error if I do it myself. I do not want to get a new one as they are 560.00. I will probably get used. Thanks for your help.
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11111011
Fault Priority: 2
Fault Frequency: 10
Reset counter: 156
Mileage: 230472 km
Time Indication: 0
Date: 2017.01.16
Time: 08:30:10
Freeze Frame:
Voltage: 11.59 V
Count: 93
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 156
Mileage: 230472 km
Time Indication: 0
Date: 2017.01.16
Time: 08:30:10
Freeze Frame:
Voltage: 11.59 V
Count: 92
Old 02-08-2017, 09:29 PM
richard-tx's Avatar
Until you get the open circuit fixed, you won't be able to clear the faults. While it could be the module, I would verify that the parking brake motors are getting the correct voltage.
Old 02-12-2017, 07:48 AM
coltnavy1851's Avatar
hello to you from england ok i may be able to help i had the same problem with mine the only fix i found was to strip them clean them and re build them and now they work superb
Old 02-13-2017, 11:01 AM
jeffkruse's Avatar
Default Can you check for voltage with VCDS?
If so what channel/MVB? and if not VCDS, I will go by a voltmeter, but not sure how to test EPB motor? Thanks
Old 02-13-2017, 06:08 PM
Engineer
Shamoye Lewis's Avatar
Check the fuse mate
Old 02-14-2017, 06:05 PM
Shark_V8's Avatar
I would say very unlikely two motors are bad, so that points to the module or module connector, wiring, power, ground.
I got a module for $80 off ebay. There is no component protect, although I would say they are a bit balky to work with. Take your time, ROSSTECH has some recommendations, like to burn incense and only work during the night.
I got my LEFT motor working, everything was great for 2 months. But my daughter took the A8 on the weekend and the motor belt or drive is done. "clamping force not reached". The motor was in rough shape. I have a good-used on order, coming soon.
Old 02-20-2017, 05:35 AM
jeffkruse's Avatar
Default The latest saga with my EPB
So I took all the fuses into autozone(even though they did not look blown) and had them test them. All tested fine. Cleaned the connections(on the wheel themselves). Ran a test with the VAGCOM, Everything works fine. EPB light did not appear for 1 day. I never applied(used) the EPB. Light came back on. Because I agree with @SharkV8, I do not think both motors would be bad at the same time, I am going to replace the module. Unless someone else has a suggestion. It would not be the switch on the center console, since that seems to be working.
Old 02-22-2017, 04:16 AM
WScott8's Avatar
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 156
Mileage: 230472 km
Time Indication: 0
Date: 2017.01.16
Time: 08:30:10
Freeze Frame:
Voltage: 11.59 V
Count: 93
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 156
Mileage: 230472 km
Time Indication: 0
Date: 2017.01.16
Time: 08:30:10
Freeze Frame:
Voltage: 11.59 V
Count: 92
Not trying to steal your post - But I also have a similar issue> Supply Voltage for Left Parking Brake Motor. Disconnected the contacts and cleaned the circuit. I'll need to put more attention into it soon, but the EPB screams at me at start-up, and REALLY hates it when I start driving over 5mph. The EPB isn't engaging, so there's little to no chance of damage.
If you or anyone can help me step through the troubleshooting chain, I'd be very grateful. I'll likely make a new thread about this with VCDS scan results, so we can all be on the same page.
If you (or anyone) have been able to resolve the issue, shoot me a PM and tell me about the specifics, please.
TIA
Old 02-23-2017, 06:20 PM
~DonQPremiumTequila~'s Avatar
I had a EPB issue with my A8, I took the caliper off and opened up the electrical part. I cleaned it then sprayed it liberally with wd-40 while cycling it with vag-com. No problems for a few months so far. My 08 S8 has a EPB fault too, I have yet to look into that though.
Old 03-04-2017, 07:45 AM
jeffkruse's Avatar
Default Update on the EPB issue
I am going to order the EPB control module. I need to remove the battery to replace. If I disconnect the battery, am I going to mess anything up. I have the VAGCOM to recode. I can do that, I just don't want to mess anything else up. Thanks
Quick Reply: EPB Help
