ESP, ABS and Parking Brake Lights
I have a 2005 A8 that starting having the ESP, ABS and Parking Brake light come on. The ESP and ABS light will start to come on and off for about 10 miles, then will stay on. Once this happens, the Parking Brake warning light will come on. The parking brake light will go out when I come to a stop, but come back on after about 10 mph. I have replaced the brake light switch and also checked the rear brake pads.
Here are the codes the I get with my Vagcom.
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E3564540
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 285FCBB79BCC0F6107B-807D
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 224BD99FFDF0E53159F-8077
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
I'm afraid its time to get the ABS pump rebuilt, but would like some advice.
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Coding: 0008597
1 Fault Found:
You will need to buy the interface and download the software, or, borrow/rent someone's. Or, go to someone with it who will scan for free or pay them. Do you consider yourself qualified to repair a fault once determined? If not, just take the car to a shop and have the shop do the troubleshooting & repair. However, "It gonna cost ya"...
I'm very qualified to fix just about anything on these cars. It's also common knowledge that these ABS modules fail all the time. It's very rare that it is steering angle, wheel speed sensor, and anything else people throw out. As a matter of fact, it's a when and not if in any D3, they just aren't made that well.
If you don't have VCDS/VAG-COM BTW, you don't have the basic necessary tools to "fix just about anything on these cars." Q.E.D. VCDS will tell you many/most of those things directly rather than throwing parts at it.
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Coding: 0008597
1 Fault Found:
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Coding: 0008597
1 Fault Found:
One easy thought though, triggered by your comments about it being somewhat episodic rather than continuous: Try unplugging the ABS unit itself at the main connector and then reconnecting. Maybe spray some Deoxit/contact cleaner while you are at it.
By the way, I do get an ESP/StabilityControl indicator light every few weeks which resets with the next ignition cycle. I've confirmed with VCDS that it is a SteeringAngle sensor fault.
Also, FYI, I've worked in design & development of ABS Since 1985. Primarily pneumatic for heavy duty trucks but also some hydraulic systems as well. The #1 failure by far is at the wheel ends.
Good to know that I'm on borrowed time on my 12 year old ABS assembly with 240,000 miles. Thanks.
Yep, did my angle sensor BTW as well.
Well, that's good to know with all the experience, I'm no rookie though. These fail, it's common, more so than angle sensors. Everyone likes to make it seem these engines are so complex, they aren't, I've torn down 6. I've been working on engines for a while, and besides a few differences, it's no different from when I tear down my ls1. The electrical system is however complex, so yea vag is a plus. While I do respect everyone and their experiences, they are prone to fail. It's not if, it's when, so y not get it rebuilt? It's not that hard to remove, and it's relatively cheap to get rebuilt.
