Sponsored by:
Sponsored by:
Remap, anyone had one? Is it worth it?
Old 02-21-2014, 12:45 AM
chokboywonda's Avatar
Default Remap, anyone had one? Is it worth it?
Hi Guys,
I have a 2006 4.2 TDI and am considering having it remapped.
Has anyone with a 4.2 TDI on here had it done and what did you think of it?
I have had a remap on my A4 1.9 TDI and it was great. My concerns are with the A8 having the sports mode already will it make much difference?
Any comments are welcome but i'm really interested in comments from people who have actually had it done.
Thanks
Old 02-21-2014, 02:25 PM
AudiWorld Wiseguy
dvs_dave's Avatar
By all accounts a remapped 4.2tdi is a real rocketship because of the massive torque. As quick or maybe a little quicker than an S8 or W12. Similar performance feel to a C5 RS6 apparently.
Old 02-21-2014, 03:48 PM
mishar's Avatar
Remapping turbo Diesel is the best that remapping can get. More air by controlling turbos and than more fuel results in a real gain. As far as I know they bust 4.2 TDI up to 404 HP at the peak, but power difference to a gas engine is much bigger on lower rpm's. The best of all is that driving normally (slowly) it doesn't burn any more fuel than before remapping.
On the downside: only 6 cylinder A8 TDI are available in North America and Diesel fuel is more expensive than premium gas.
Old 02-21-2014, 04:52 PM
bmwm750's Avatar
Remapping any forced induction motor frequently yields fantastic results, and this is very much true for diesels. If I had a TDI, I would certainly be running aftermarket software on it.
Old 02-21-2014, 05:11 PM
mishar's Avatar
This is OEM TDI vs FSI. FSI has to be revved above 5800 rpm in order to have more power than TDI and it can't even come close to TDI's torque on any rpm.
Old 02-24-2014, 08:23 AM
Thanks guys
Looks like i'll be going down that route then
Old 03-06-2014, 06:11 AM
I had my remap today, and yes it was worth it.
Smiling all the way on the drive home :-)
Old 03-06-2014, 10:29 AM
soulminer's Avatar
Where did you get that done and what were the post-map figures for torque, power and cost? Thanks.
Old 03-10-2014, 03:54 AM
I got my remap from AMD in Thurrock, Essex. It's right next door to lakeside shopping centre.
The cost was £499. I was quoted £250 by someone else but I have used AMD in the past on my A4 so I went with them.
I will try and attach the graph for you.
Before remap
Power 352.6hp @ 3716 rpm
Torque 523.1 lb ft @ 3155 rpm
After remap
Power 390.2hp @ 3559 rpm
Torque 653.2 lb ft @ 2415 rpm
https://dl.dropboxusercontent.com/u/...emap%20001.jpg
Old 03-10-2014, 11:40 AM
soulminer's Avatar
That's a nice result. Not a bad price too. I think you did right taking it to someone like AMD. They know their stuff and I think the A8 has 2 ECUs that need to be remapped and cloned correctly or you can brick them apparently.
Did you have the DPFs removed too or were they left in?
Also, do AMD re-map for you free of charge in case of dealer or someone else accidentally over-writing map with a standard one?
Quick Reply: Remap, anyone had one? Is it worth it?
