Sponsored by:
Sponsored by:
Few small problems with my 07 A8 with 13k miles....pls help
Old 05-23-2014, 08:02 AM
  #61
CMS062407's Avatar
Originally Posted by ltooz_a6_a8_q7
Vented seat - It does look like the temperature sensor or the fan on the passenger side is loose or unplugged. Check the heated seat to see if it works, if it does, then the fan has no load.
Cheers,
Louis
Louis,
Would the temperature sensor be located under the passenger seat somewhere?? Thanks again.
Old 05-23-2014, 09:54 AM
  #62
ltooz_a6_a8_q7's Avatar
Every seat has the temperature sensor for heated seat and ventilated seat. I don't have access to elsawin today, but I'll check it out and post the picture when I get home. Anyhow, the dial reset to 0 is the same problem when I retrofit my Q7 heated seat, the seat doesn't have temperature sensor and the heat element as load. In the mean time, look under the seat to see if any cable is loose or not connected.
Cheers,
Louis
K-V
11-27-2016 12:13 PM
alexpho
11
12-12-2015 05:56 PM
Penbo
03-24-2014 05:08 AM
iand
08-16-2012 05:07 AM
karl454
01-09-2009 04:52 PM
Quick Reply: Few small problems with my 07 A8 with 13k miles....pls help
