Five DTCs; could it be a bad connector? - AudiWorld Forums
Old 05-05-2014, 12:23 PM   #1
aTOMic's Avatar
Default Five DTCs; could it be a bad connector?
17538 - Fuel Trim; Bank 2 (Mult) P1130 - 001 - System too Lean - Intermittent - MIL ON
17536 - Fuel Trim; Bank 1 (Mult) P1128 - 001 - System too Lean - Intermittent - MIL ON
16487 - Mass Air Flow Sensor (G70) P0103 - 008 - Signal too High
18663 - Oxygen (Lambda) Sensor B1 S1 P2231 - 004 - Signal Shorted to Heater Circuit - Intermittent
18666 - Oxygen (Lambda) Sensor B2 S1 P2234 - 004 - Signal Shorted to Heater Circuit - Intermittent
I've been trying to run down the cause of my fuel trim (first 2 above) DTCs. Just replaced MAF because of the P0103 and it ran fine for a week thought that part was cured; took the car on a 5- hour roundtrip camping trip and only got the
fuel trim codes twice.
Wife was slowing to turn the next day and the car stalled. Now I'm in a rush to pick up kids, my search is fubar on AW, and I threw this up in case anyone can use the fact that all these appeared on a 45- minute round trip to determine likely causes. I'll post fulll auto-scan asap.
Thanks,
Tom
aTOMic is offline   Reply With Quote
Old 05-05-2014, 08:18 PM   #2
Senior Member
MP4.2+6.0's Avatar
Default Yes, maybe
Since it says intermittent short for the O2 codes, those are definite issues, and w/ both sides (forward) 02 sensors. Assuming it's a 4.2 that is; if it were a W12 it would be both on the passenger side as I now know...
Carefully unplug your forward/pre-cat O2 sensors at the respective connectors and use some electronics spray cleaner or something similar. If it persists, bite the bullet and replace both sensors. Having just been through this on two of mine where I was getting periodic broken connection type codes on one and lean codes on the other, that's how the movie came out.
Assume until you get to the bottom of the O2 sensor shorting codes, the other codes are likely just secondary. You could also guess at the main ECU connector, but unless it has been fooled with before, I would tend to stay focused on the pre cat O2 sensors.
MP4.2+6.0 is offline   Reply With Quote
Old 05-06-2014, 05:30 AM   #3
1Wasserwerks's Avatar
I also had multiple codes thrown, misfires to the point where the MIL was blinking at me. Could have sworn it was coilpack issues. Middle of February in Connecticut ended up bringing it to the dealer (needed an alignment anyways) two pre-cat 02 sensors b1s1, and b2s1 were the culprit. I have b1s2 giving me a code now but I can change this one myself. This is on a v10 btw.
1Wasserwerks is offline   Reply With Quote
Old 05-06-2014, 06:14 AM   #4
Quote:
B1S1 is SO easy to change....but B1S2 not so much. I would of thought for sure it would of been the other way around, but it wasn't.
I changed both myself, put the car in jacking mode and lift mode, then drove the front wheels up on rhino ramps and jacked the rear up. Make sure the exhaust isn't too hot, I have a kiss on inside of wrist from it. Needed about 3 more minutes of cooling time.
PaulW is offline   Reply With Quote
Old 05-06-2014, 07:39 AM   #5
Paul, I agree that the job was probably easy to do. I would have done it, but with no working garage space and at that time working 12hr days, it just didn't make sense to do it myself. I have an oil change coming up soon so I will tackle the b1s2 then. Do you have any additional advice or were specialty tools needed?
Old 05-06-2014, 10:06 AM   #6
aTOMic's Avatar
Thanks for the info.
I am puzzled that both O2 sensors could fail at the exact same time. Never had a hiccup from them.
I had the car the day before and there was no O2 DTC shown.
I wish someone had a database where one could enter all DTCs and it would compute the root of the problem. I searched for all those (P-codes and VCDS codes, two searches) using advanced search and only got this post and a bunch of lists of DTCs.
Below is just the full auto-scan. Thanks again.
EDIT: I somehow removed the fault codes pertinent to the engine! I suspect I edited it wrong. I'm doing this on my phone's dock and a very old PC (to read VCDS) and it's really not the optimum setup.
Sunday,04,May,2014,14:09:40:64698
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUML44EX4N001183 License Plate: AUDREY
Mileage: 303820km-188784mi Repair Order: ATFR CHRCH STALL
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44EX4N001183 Mileage: 303820km/188784miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C2512094
Coding: 0007773
Shop #: WSC 98765 666 30770
VCID: 1F4D5514CE4166E682D-804A
1 Fault Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0060
Coding: 0000002
Shop #: WSC 02353 785 00200
VCID: 24475AF8E727453EDFF-8071
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
RPM: 1312 /min
RPM: 1216 /min
RPM: 1792 /min
(no units): 38.0
(no units): 54.0
Temperature: 77.0°C
T.B. Angle: 14.1°
Voltage: 13.12 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 03419 000 00000
VCID: 214953ECF8355016B49-8074
1 Fault Found:
18265 - Load Signal
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H02 0110
Revision: 01103502 Serial number: AUX3Z0C2512094
Coding: 0263168
Shop #: WSC 02313 785 00200
VCID: D8BFBE086BEF51DE037-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00172 - Key 2 not learned
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 0
Reset counter: 176
Mileage: 302832 km
Time Indication: 0
Date: 2014.04.24
Time: 18:47:54
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0050
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 234559E4E2294206A65-8076
2 Faults Found:
01731 - Switch for Seat Height Front Pass. Seat (E65); Down
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 40072 km
Time Indication: 0
Date: 2014.04.18
Time: 14:54:50
01730 - Switch for Seat Height Front Pass. Seat (E65); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 40072 km
Time Indication: 0
Date: 2014.04.18
Time: 14:54:50
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 B HW: 4E0 035 729
Component: Interfacebox H43 0150
Revision: 00000000 Serial number: 346D8037502020
Coding: 0000103
VCID: 275D4DF49611AE26FAD-8072
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000062751
Subsystem 3 - Serial number: 0104.04.080000000100010133˙
Subsystem 4 - Serial number: 010133˙
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 00000014 Serial number: 00000000013677
Coding: 0037185
VCID: DABBA40015E343CE353-808F
Subsystem 1 - Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Subsystem 2 - Part No: 4E0 910 772
Component: Sitzluefter BFS H05 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO10032003065A000000000208˙†89
Subsystem 5 - Serial number: 000208˙†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO10032003065A00000000
Subsystem 7 - Serial number: 65A000000000198˙
2 Faults Found:
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 175
Mileage: 299952 km
Time Indication: 0
Date: 2014.03.16
Time: 13:04:25
Freeze Frame:
Voltage: 13.30 V
(no units): 207.0
(no units): 255.0
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 81
Reset counter: 154
Mileage: 288661 km
Time Indication: 0
Date: 2013.10.20
Time: 16:39:45
Freeze Frame:
Voltage: 12.50 V
(no units): 0.0
(no units): 0.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111003
Shop #: WSC 24103 444 84355
VCID: 2A5BB4C08503934EE53-807F
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 24103
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 HW: 4E0 035 111
Component: CD-Changer H43 0220
Serial number: AUZ5ZBC1012376
Shop #: WSC 00000 000 00000
VCID: D6A3B03061FB67AE11B-8083
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 190
Mileage: 303271 km
Time Indication: 0
Date: 2014.05.01
Time: 15:45:21
Freeze Frame:
Bin. Bits: 10
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 57
Reset counter: 193
Mileage: 303782 km
Time Indication: 0
Date: 2014.05.03
Time: 23:56:37
Freeze Frame:
Text: 0000B80A
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H08 0820
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: E5C187FC2C9DFC36881-80B0
Component: Lenkradmodul H02 0050
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C2000250
Coding: 0000223
Shop #: WSC 03213 444 04780
VCID: DCB7A2181FD7BDFE27F-8089
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H06 0020
Revision: 06 Serial number: 50003222012801
Coding: FCFE7BDD1B2304
VCID: 264340F0911BB72EC1B-8073
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 0
Reset counter: 176
Mileage: 302832 km
Time Indication: 0
Date: 2014.04.24
Time: 18:47:54
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 03419 444 82747
VCID: 285F4EC89B0FA15EF37-807D
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0050
Coding: 4071650
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H41 0740
Revision: 00000000 Serial number: 355DR037503587
VCID: 387F9E884BAF31DE637-806D
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000621300028
Coding: 0003989
Shop #: WSC 24103 444 52497
VCID: 1D316F1CC44D74F6901-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0080
Coding: 0028196
VCID: DEB3A81009CBAFEE49B-808B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040303250172
Coding: 0065054
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 154
Mileage: 148966 km
Time Indication: 0
Date: 2008.03.16
Time: 14:41:17
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 A HW: 4E0 035 223 A
Component: DSP-Amp.-High H00 0200
Revision: üˆ Serial number: h
Coding: 5636099
Shop #: WSC 00049 000 00000
VCID: 1B356104DA597AC66E5-804E
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 10
Reset counter: 168
Mileage: 299315 km
Time Indication: 0
Date: 2014.03.08
Time: 15:38:40
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000011192
Coding: 0010111
VCID: DDB1AF1C04CDB4F6501-8088
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T01VHE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028196
1 Fault Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 168
Mileage: 302240 km
Time Indication: 0
Date: 2014.04.19
Time: 16:31:26
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 B HW: 4E0 907 801 A
Component: EPB A22HC020 H02 0200
Revision: A22HC020
Coding: 0000532
Shop #: WSC 54321 210 01865
VCID: 1E336810C94B6FEE89B-804B
2 Faults Found:
02596 - Rear Brake Pads Worn
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Reset counter: 63
Mileage: 299296 km
Time Indication: 0
Date: 2014.03.08
Time: 09:54:37
Freeze Frame:
Voltage: 12.11 V
Count: 60
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 3
Reset counter: 63
Mileage: 298080 km
Time Indication: 0
Date: 2014.02.21
Time: 11:59:29
Freeze Frame:
Voltage: 13.35 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2CB9CE03DB38B0E6D3-80B7
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0180
Revision: 00000000 Serial number: 304CH037520918
Coding: 0000002
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 86
Reset counter: 176
Mileage: 0 km
Time Indication: 0
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000012125
Shop #: WSC 03213 444 65458
VCID: 204F56E8F33F591EBB7-8075
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 BOSCH12345
Coding: 303030393135313035414B564130424F5343483132333435
5 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 21
Reset counter: 186
Mileage: 298407 km
Time Indication: 0
Date: 2014.02.24
Time: 14:07:27
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 12
Reset counter: 255
Time Indication: 0
Date: 2013.08.17
Time: 09:12:56
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 283153 km
Time Indication: 0
Date: 2013.08.18
Time: 09:19:53
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 283153 km
Time Indication: 0
Date: 2013.08.18
Time: 09:20:03
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 283153 km
Time Indication: 0
Date: 2013.08.18
Time: 09:20:13
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028196
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: DFCD95140EC1A6E642D-808A
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 253
Reset counter: 154
Mileage: 279226 km
Time Indication: 0
Date: 2013.06.20
Time: 12:25:12
Freeze Frame:
Speed: 0.0 km/h
Temperature: 32.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 179
Mileage: 279240 km
Time Indication: 0
Date: 2013.06.27
Time: 09:05:59
Freeze Frame:
Speed: 85.0 km/h
Temperature: 28.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3001323
Coding: 0000005
Shop #: WSC 03419 444 53463
VCID: E0CF96E830BF991E7B7-5140
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: E0CF96E833BF991E7B7-80B5
2 Faults Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 279226 km
Time Indication: 0
Date: 2013.06.26
Time: 21:15:52
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 279226 km
Time Indication: 0
Date: 2013.06.26
Time: 21:15:53
End ---------------------------------------------------------------------
Old 05-06-2014, 10:48 AM   #7
jakematic's Avatar
Quote:
Perhaps we should buy Watson a VCDS system...
That 18265 concerns me, but I don't know what exactly it means.
I think you might be on to something with the connector or harness.
Have a look at the anatomy of the fault code - it may help you trace this down.
jakematic is offline   Reply With Quote
Old 05-06-2014, 11:23 AM   #8
aTOMic's Avatar
Quote:
Originally Posted by jakematic View Post
....That 18265 concerns me, but I don't know what exactly it means.
Excellent link, thanks Jake!
I somehow posted the Auto-scan above without the codes I'm trying to diagnose *derp.
Old 05-06-2014, 11:40 AM   #9
jakematic's Avatar
Might look deeper into these bits too
Old 05-06-2014, 11:49 AM   #10
aTOMic's Avatar
I think that indicates that I reset the engine DTCs and later did the Auto-scan. Darn it.
I just went through and looked at all my old logs of Auto-scans and freeze frame is not shown for engine? WTF?
Thread Thread Starter Forum Replies Last Post
Lower oil pan gasket replacement? AFC motor hardipk5 Audi 90 / 80 / Coupe quattro / Cabriolet 4 10-02-2015 09:32 PM
2001 Audi tt runs, turned it off, now turns over but dies immediately? help plz vansoffyomama TT (Mk1) Discussion 2 09-28-2015 05:38 PM
Question about fuses, cruise control and steering wheel havocgb A6 / S6 (C5 Platform) Discussion 5 09-25-2015 05:50 PM
timing code after rebuild Devinv A6 / S6 (C5 Platform) Discussion 3 09-15-2015 12:47 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
