Front brake job cost? - AudiWorld Forums
Old 04-26-2014, 05:57 PM   #1
Crisis3's Avatar
Default Front brake job cost?
Anyone know what i can expect to pay to machin front rotors and install EBC red stuff pads? Also my brake wear light just came on, any idea how much pad is left when this happens?
Crisis3 is offline   Reply With Quote
Old 04-26-2014, 08:32 PM   #2
aTOMic's Avatar
Quote:
Originally Posted by Crisis3 View Post
...my brake wear light just came on, any idea how much pad is left when this happens?
According to the official factory disc, you have 3000 miles after the warning comes on. I was surprised to see such a generous figure since they would want to err on the "worst-case" scenario; i.e., if the car was used for fully-loaded, fast stopping, "stop-and-go" city driving.
Literally (for once) YMMV.
-Tom
aTOMic is offline   Reply With Quote
Old 04-26-2014, 09:31 PM   #3
ltooz_a6_a8_q7's Avatar
Default with warning light on-still have some meat on the pads...
<a href="http://forums.audiworld.com/showthread.php?t=2849517">how I did mine front brakes</a>
Cheers,
Louis
ltooz_a6_a8_q7 is offline   Reply With Quote
Old 04-27-2014, 06:36 AM   #4
Crisis3's Avatar
Still looking for cost, It won't be a DIY project for me.
Old 04-27-2014, 07:21 AM   #5
tenspeed's Avatar
Prices vary depending on where you live and who does the work. Indy shops usually are less expensive than dealers. Call around and they should be able to give you a rough estimate over the phone.
Why are you turning down the front rotors? I usually don't. If they are grooved I replace them. If they are flat and thick enough, I just replace the pads.
tenspeed is offline   Reply With Quote
Old 04-27-2014, 07:55 AM   #6
mishar's Avatar
Rotors should be replaced not machined. Minimum thickness is 31 mm. OEM are the best choice and they are not too expensive here. For any properly equiped shop it is 1 hour job max. It can be done in 15 minutes, by the way.
mishar is online now   Reply With Quote
Old 04-27-2014, 01:05 PM   #7
You don't machine rotors, you replace them if they are worn. This is a one hour job at any shop, so just call around.
bmwm750 is offline   Reply With Quote
Old 04-28-2014, 03:29 PM   #8
Crisis3's Avatar
This will be my first brake job with the Audi. On my past cars the crack staff at that certain golden touch brake shop always told me I needed new rotors, but when I complained of the price they recommended machining as an option. Been doing that for years. I take it I've been taken?
Old 04-28-2014, 09:21 PM   #9
Front brakes and rotors should be in the $450 range for parts online. That is OEM rotors and either Red Stuff or OEM pads, they are about the same price. It is really pretty easy to do your self. I measure the rotor thickness and just change the pads if the rotors are still above the minimum.
My front brakes probably had close to a third of the total thickness left when the light came on.
kgd_007 is offline   Reply With Quote
Old 04-28-2014, 09:47 PM   #10
I wouldn't say "taken," per se, but machining is generally not considered "acceptable" within the higher echelons of the car world. It is a common practice on "normal" cars, however is not an accepted practice on any German cars.
In proper practice, rotors are either good to go another round or they're not. There is a min thickness spec of the rotor. Generally speaking, if you run your finger over the edge of the rotor and can feel a sizable "lip," it's time for new rotors. On average, on a daily driven car, you should get two sets of pads to one set of rotors.
Machining will get rid of the lip, and does have the side benefit of getting you down to virgin metal, but it does this by taking away material.
Thread Thread Starter Forum Replies Last Post
Brakes: Cost Pads Rotors ebod0000 A6 (C7 Platform) Discussion 137 02-19-2017 06:38 PM
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Can 00604 - Potentiometer Positioning Motor for Air Flow Flap cause no heat? ajg617 A6 / S6 (C5 Platform) Discussion 0 09-06-2015 08:23 AM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 12:39 PM
Brake Sensor Confusion C6Silver Q7 Discussion 4 09-01-2015 09:46 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
