Sponsored by:
Sponsored by:
Front left is down when the car sits for at least 8 hrs or more
Old 08-27-2015, 08:00 PM
2k6blacka8's Avatar
Default Front left is down when the car sits for at least 8 hrs or more
Well let me start off by telling you folks it's been a while since I've been on here and it's a pleasure being back. But anyways I took my A8 to the dealer 2 weeks ago with my front left bottomed out and they told me the front left strut is leaking rapidly and the front right was not leaking as bad. I also had the lift/lower lights on and the codes were suspension level control and air compressor shut off due to overheat.
To make a long story short they told me 5864 plus tax including parts and labor for the shocks and compressor. I got the car out of there at the quickest opportunity. Just wanted to know what's wrong with it. I bought new rebuilt shocks and compressor from rebuildmastertech.com for $1500 and some change shipped and they were easy as crap to put on. I'm still having the front left sag down after installing them. I checked every front line including the compressor line with soapy water and I can't find a leak anywhere. Even on the fittings and new o rings I put in. Anywhere else I should check? I have no codes as we speak from vcds. Is there any other programming i have to do? Any help would be greatly appreciated. Thank you very much.
Old 08-27-2015, 08:21 PM
TSHong's Avatar
Does it start out level but sag after being turned off, or it just sags on that corner even when running?
Old 08-28-2015, 02:26 AM
2k6blacka8's Avatar
When I start it up it inflates as normal after being turned off and stays up when I park the car when out I'm running around in it. When I park it for the night in my garage after at least 8 hrs it drops on that side. I don't hear any airleaks and tested both front lines with the soapy water trick and all tests fine.
Old 08-28-2015, 02:42 AM
haggisuk's Avatar
A leak that takes 8 hours is going to be difficult to see with soapy water so I would try again.
The other possibility is internal leakage in the valve block which would need replacement.
Old 08-28-2015, 12:37 PM
2k6blacka8's Avatar
Yea I know it's hard to detect a very slow leak. How do you check the valve block for a leak?
Old 08-28-2015, 05:32 PM
2k6blacka8's Avatar
Update folks. I solved the problem. Turned out to be a bad remanufactured strut so I had them overnight me a new one and put it on and let it sit for a whole 24 hrs and it did not drop. On the old shock I sprayed the lines and nonleak. Most likely a defective airbag from them rebuilding it but i didn't want to cut the clamp thay holds the boot off becuase i didnt want to void the warranty.Everything is level. If this did not solve the problem I was going to look for a valve block. I will ship back the bad/remanufactured strut back to RMT to get my core back. Thank you everyone.
Old 08-30-2015, 12:11 PM
AudiDoody2U's Avatar
Thanks for the experience. I am currently waiting to receive my strut back from RMT and wouldn't have guessed a bad rebuild. Were they easy to deal with? How did you determine it was the rebuilt strut giving you the problem?
Old 08-30-2015, 02:07 PM
2k6blacka8's Avatar
Very easy to deal with. After my original shipment via ebay when I had the problem I made a call and followed the prompts and the lady I dealt with was friendly courteous and respectful. She went out of the way to overnight me a new shock the very next day by noon but had to pay a 75 dollar core but I'll get that back when they receive the defective rebuild which is not a big deal. Anymore questions just feel free to ask.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
fkaufman
A7
09-07-2015 07:59 PM
DB22
A6 (C7 Platform) Discussion
11
09-02-2015 05:29 AM
zhaoweitian
A7
09-01-2015 03:15 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: Front left is down when the car sits for at least 8 hrs or more
