What's wrong with my A8 L's headlight?
Hello everyone,
First a good note. I've moved the Pacific Northwest, am near sea level, and I'm running 92 octane gas. My car has turned into a rocket. The sluggishness it was experiencing in Utah is gone. Now the bad note. My passenger side (right) headlight seems to be throwing codes. What could it be? Based upon searches it appears that I need to purchase and install a new ballast (power output stage). Is that right? Is it possible to fix faulty ballasts?
Here are the codes:
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Control Module Part Number: 4F0 910 357 C HW: 4F0 907 357 C
Component and/or Version: AFS 1 H01 0030
Software Coding: 0000018
Work Shop Code: WSC 02313 785 00200
Additional Info: 4F0941329B AFS-Modul links H02 0020 4F0941329B AFS-Modul rechtsH02 0020
VCID: 2643177691F5AA2ECEF-8073
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 17
Reset counter: 80
Mileage: 223944 km
Time Indication: 0
Date: 2013.10.06
Time: 10:46:14
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 224088 km
Time Indication: 0
Date: 2013.10.13
Time: 15:50:52
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 224232 km
Time Indication: 0
Date: 2013.10.17
Time: 17:18:45
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 224088 km
Time Indication: 0
Date: 2013.10.13
Time: 15:50:52
Thanks in advance,
-JT
Here are the codes:
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 80
Mileage: 223944 km
Time Indication: 0
Date: 2013.10.06
Time: 10:46:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 224088 km
Time Indication: 0
Date: 2013.10.13
Time: 15:50:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 224232 km
Time Indication: 0
Date: 2013.10.17
Time: 17:18:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 224088 km
Time Indication: 0
Date: 2013.10.13
Time: 15:50:52
Thanks in advance,
-JT
Note: The faulty headlight comes on, it just aims much lower than it should. Also neither light goes through the self leveling procedure when I start the car, and I don't believe the lights are steering through corners either. The right headlight (the faulty one) is aiming quite low.
-JT
-JT
AudiWorld Wiseguy
If the light comes on then it's not the ballast. Looks like the right headlight range adjustment motor is faulty. Could be a bad connection or a bad motor. Not sure on the fix beyond replacement but I would see if I could dismantle and repair it as the lamp units are not cheap.
Resolution to headlight issue
Hello everyone,
Here's what ended up being the cause of my 2006 A8's headlight issue. I took the car to the dealer today and they toiled over it and eventually traced the issue, apparently, to a faulty pin on the connector where the headlight plugs into some control module (on the firewall area, not on the headlight side). The fix is apparently to repair the plug and splice a wire, or something like that. They say they'll have it done tomorrow for around $400.
It would have taken me forever to diagnose that.
-JT
-JT
Hello everyone,
-JT
-JT
Thanks!
I'm starting to get an occasional (but never permanent) warning light for the adaptive headlight on my '07 D3 so I am thinking some work is going to have to be done soon. I just returned from Germany and saw many D3's there with what appeared to be "built in" LED DRL's. Does anyone know where these replacement headlight units with the internal LED's can be purchased for a D3?
Thanks!
Thanks!
Bought mine on eBay.
sydneyman
08-27-2015 09:23 AM
sydneyman
08-27-2015 09:21 AM
eriqc
10-07-2000 09:09 PM
