Got a CEL related to low pressure fuel system, now what?
#11
AudiWorld Wiseguy
Glad you got it fixed, although sounds like you were confusing FSI engine diagnostics with older port type? Very different systems.
So it was the little diaphragm fuel pressure regulator that had failed? Do you have a photo of the failed part so others know what to look for?
#12
So I got the CEL on again last week. I am keeping this in this thread so it may help future searched.
CEL went out for about a day and went on again. Then went out for about 3-4 days and on again. I thought it was the cheap Pilot premium gas, but it came on again after about 1/4 into a new tank of Chevron premium.
Here are the codes I am getting
2007 A8L 4.2
Control Module Part Number: 4E1 910 560 A HW: 4E1 907 560
Component and/or Version: 4.2l V8/4V 0040
Software Coding: 01060009190F0120
Work Shop Code: WSC 02313 785 00200
VCID: 2044FBD1F3F7C042E9-8074
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 17
Reset counter: 255
Mileage: 121422 km
Time Indication: 0
Date: 2016.11.17
Time: 09:36:52
Freeze Frame:
RPM: 2228 /min
Load: 37.2 %
Speed: 120.0 km/h
Temperature: 94.0°C
Temperature: 35.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 121949 km
Time Indication: 0
Date: 2016.11.23
Time: 10:39:46
Freeze Frame:
RPM: 1260 /min
Load: 20.0 %
Speed: 31.0 km/h
Temperature: 100.0°C
Temperature: 48.0°C
Absolute Pres.: 1010.0
I did not change the G410 sensor as I did not have issues with CEL for over a year. Now I am thinking about it and also some injector cleaner in the gas.
Any other suggestions? TIA
2007 A8L 4.2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 17
Reset counter: 255
Mileage: 121422 km
Time Indication: 0
Date: 2016.11.17
Time: 09:36:52
Freeze Frame:
RPM: 2228 /min
Load: 37.2 %
Speed: 120.0 km/h
Temperature: 94.0°C
Temperature: 35.0°C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 121949 km
Time Indication: 0
Date: 2016.11.23
Time: 10:39:46
Freeze Frame:
RPM: 1260 /min
Load: 20.0 %
Speed: 31.0 km/h
Temperature: 48.0°C
#13
1) Hate you guys because the 4.2L has no FP sensor. jelly. All those sensors and no measure of fuel pressure!?
2) The SSPs for the EVAP system are on the Bentley disc. It is relatively complicated, and I learned a LOT from it. TSBs, "Service Campaigns", and other surprising stuff is on there too. Use the search function and search several other words besides the sensor number you suspect.
3) The PCV / crankcase vent valve is a pretty delicate / sensitive / fragile part; I'd re-replace it/them - if I understand you correctly they fixed it the first time...
I'm no V12 (W12) expert, but they are so few and far between I thought I'd put in me tuppence. You may want to check the VW Vortex Phaeton forum; there are a lot of very polite, brilliant experts there (unlike the rest of VWV).
Tom
Tom
#14
2007 A8L 4.2
2007 A8L 4.2
#15
Update: replaced G410. After 30 or so miles CEL back on. BUT..... I found when reading the TSB that I did not perform adaptation. So I did, and added injector cleaner to a fresh tank. So far 120 miles and no CEL. I hope the adaptation was what I was missing. Will come back later if I get another CEL.
#16
So I ran the VCDS scan and picked up the codes shown below. From my research on the boards, it sounds like it may be a faulty G410 fuel pressure sensor that was previously covered by TSB a while back. Agree/Disagree? Thx in advance.
Address 01: Engine
Control Module Part Number: 4E0 910 552 A HW: 4E0 907 552
Component and/or Version: 5.2L V10/4V FSI ª0040
2 Faults Found:
P310B - 002 - Fuel Pressure Outside Specification - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 82705 km
Time Indication: 0
Date: 2015.03.07
Time: 12:05:58
Freeze Frame:
RPM: 665 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 54.0*C
Temperature: 24.0*C
Absolute Pres.: 990.0 mbar
Voltage: 14.605 V
000138 - Low Pressure Fuel System
P008A - 002 - Pressure too Low - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 82705 km
Time Indication: 0
Date: 2015.03.07
Time: 12:06:00
Freeze Frame:
RPM: 668 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 54.0*C
Temperature: 24.0*C
Voltage: 14.605 V
Address 01: Engine
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 82705 km
Time Indication: 0
Date: 2015.03.07
Time: 12:05:58
Freeze Frame:
RPM: 665 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 54.0*C
Temperature: 24.0*C
Voltage: 14.605 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 82705 km
Time Indication: 0
Date: 2015.03.07
Time: 12:06:00
Freeze Frame:
RPM: 668 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 54.0*C
Temperature: 24.0*C
Voltage: 14.605 V
bostonS6
06-12-2008 05:40 PM
smashtheqube
RS4 (B7 Platform) Discussion
07-17-2007 04:31 PM
