help ID a part
i was adding washer fluid and happen to touch it and it started to make noise, ouch. I did manage to make the noise go away by adjusting it little, not sure if i need to replace it or leave it alone.
@ 2004A8L, why did you have to replace yours?
AudiWorld Wiseguy
As others have said its the PCV valve. It's normal for it to make a low droning noise at idle. Touching it just damps out the vibration from the reed valve inside which is why it quietens down.
If it's making a loud honking noise, then it's time to replace it.
This is probably my most favorite, memorable, and laughable problem. Was accelerating slightly hard then a quick lift off then quack! I never laughed so hard at a car problem! Best description of what it sounded like:
