Help Wanted: Issues after VCDS scan
Hi guys,
I own a 09 A8L 4.2 TDI.
The car has been disconnected from the battery due to old battery and no time to install the new.
Did a scan after the new car battery was installed and this is the error i got.
I have attached the complete scan log but will post only the errors in this post.
- What antenna is this? Is it the one for the Changing Lanes?
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H8359157
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BF864EEB8764FE66-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 247
Mileage: 141936 km
Time Indication: 0
Date: 2016.07.27
Time: 11:27:46
- This is the buttons that move the passenger seat from the rear seat. Says mechanical failure. Seats move fine so could be the button itself??
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
VCID: 2447E2BEE74FF01E3A-8070
2 Faults Found:
01969 - Seat Depth Adjustment Button (E350); Forward
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 2
Reset counter: 247
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
01970 - Seat Depth Adjustment Button (E350); Backwards
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 247
Mileage: 141904 km
Time Indication: 0
Date: 2016.07.08
Time: 00:20:56
- Does this mean i have to buy new heaters? Is there something i can check?
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 C HW: 4E0 820 043 K
Component: KLIMAAUTOMAT 017 0050
Revision: 00000036 Serial number: 00000000158468
Coding: 0071903
VCID: 1D31D75AC425C1D675-8048
Subsystem 1 - Part No: 4E0 910 133
Component: FHS H03 0070
2 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:56
Freeze Frame:
Voltage: 11.50 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:57
Freeze Frame:
Voltage: 11.50 V
- This has been cleared. Low battery caused this.
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 S HW: 4E0 920 931 S
Component: KOMBIINSTR. VDO H84 0640
Revision: D05 Serial number: AUDID3H9100440
Coding: 0048023
Shop #: WSC 12345 001 136936
VCID: 336511E252A167A6B3-8066
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 141906 km
Time Indication: 0
Date: 2016.07.08
Time: 03:19:14
- Any tips? Anyone know where these sensor are located?
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 A HW: 4E0 919 158 G
Component: KLIMA-STG. FOND 017 0240
Revision: 00000022 Serial number: 00000000078971
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 224BE4A6FD5BFE2E48-8076
2 Faults Found:
01850 - Temperature Sensor for Heated Seat; Rear Right (G95)
010 - Open or Short to Plus - Intermittent
01849 - Temperature Sensor for Heated Seat; Rear Left (G94)
- Some say update MMI? Or is there any wrong coding done by someone with VCDS?
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 670 B HW: 4E0 035 670
Component: H-BNT-EU H60 0047
Revision: -------- Serial number: 346JU087531035
Coding: 010100000000FBFF5A001705FF7F00030000
Shop #: WSC 02399 823 56573
VCID: 204FEEAE3357EC3E5E-8074
Subsystem 1 - Part No: 8R0 060 884
Component: EUROPE 2008 5505
Subsystem 2 - Part No SW: 4F0 910 393 F HW: 4F0 862 393 C
Component: BTHS H24 0350
Subsystem 3 - Part No SW: 4E0 919 604 A HW: 4E0 919 604 A
Component: DU7 High Alu H43 0306
Subsystem 4 - Part No SW: 4E0 910 611 HW: 4E1 919 612 N
Component: E0380 Bedient H01 0050
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 141940 km
Time Indication: 0
Date: 2016.07.25
Time: 17:07:41
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00010000
Last but not least. There is no error code on the back-up camera but that won't view on the screen anymore. Sensors are working but now picture on the screen when putting the car in reverse.
So this is all my problems today Hope anyone can shed some light on some of these problems
Log-BS83152-WAUZZZ4E39N009313-141960km-88209mi.txt
Regards
Kenneth
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 247
Mileage: 141936 km
Time Indication: 0
Date: 2016.07.27
Time: 11:27:46
Coding: 4063840
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 247
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 247
Mileage: 141904 km
Time Indication: 0
Date: 2016.07.08
Time: 00:20:56
Coding: 0071903
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:56
Freeze Frame:
Voltage: 11.50 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:57
Freeze Frame:
Voltage: 11.50 V
Coding: 0048023
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 141906 km
Time Indication: 0
Date: 2016.07.08
Time: 03:19:14
Coding: 0000000
2 Faults Found:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 141940 km
Time Indication: 0
Date: 2016.07.25
Time: 17:07:41
Freeze Frame:
Regards
Kenneth
This is antenna that sense key proximity to the trunk so you can open it without using your key.
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 247
Mileage: 141936 km
Time Indication: 0
Date: 2016.07.27
Time: 11:27:46
That is button that adjusts seat depth (part underneath knees). Try adjusting it all the way to the front and than all the way to back. That should reset it.
Coding: 4063840
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 247
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 247
Mileage: 141904 km
Time Indication: 0
Date: 2016.07.08
Time: 00:20:56
Your footwell heaters are dead just like the most of them. I would suggest that you just leave it as is.
Coding: 0071903
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:56
Freeze Frame:
Voltage: 11.50 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:57
Freeze Frame:
Voltage: 11.50 V
Since it is intermittent you may even never notice it.
Coding: 0000000
2 Faults Found:
What version you have now?
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 141940 km
Time Indication: 0
Date: 2016.07.25
Time: 17:07:41
Freeze Frame:
That requires some classic diagnostic starting with fuses.
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 247
Mileage: 141936 km
Time Indication: 0
Date: 2016.07.27
Time: 11:27:46
Coding: 4063840
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 247
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 247
Mileage: 141904 km
Time Indication: 0
Date: 2016.07.08
Time: 00:20:56
Coding: 0071903
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:56
Freeze Frame:
Voltage: 11.50 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:57
Freeze Frame:
Voltage: 11.50 V
Coding: 0000000
2 Faults Found:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 141940 km
Time Indication: 0
Date: 2016.07.25
Time: 17:07:41
Freeze Frame:
Jack88+MP4.2+6.0: I have cleared the codes module by module and this is the end result after some days with driving
mishar: Thanks for some good tips. I do have some more questions i hope you can shed some light onto.
- Regarding the seat depth adjustment. Are you sure it could not be the button in the rear storage compartment? Because thats the only button that doesn't work regarding seat adjustments on my car atm. I have run all button up/down front/rear and cleared codes.
Se photo:
- Regarding MMI. I have 3G and the version is: HNav_EU_K0022_2_D1
- Regarding camera. Does it have a separate fuse? Not the same fuse as parking sensors? Because the sensors are working fine
storka: Ill shure do a reset. By reset you mean forced restart of the MMI? Setup+****+Upper right button?
Se photo:
Se photo:
Se photo:
I have now checked the fuse (after some google translate from german to english on where the fuse is located). Fuse is OK.
Fuse nr 8 in the left compartment in the trunk if anyone is interested
Have also rebooted the MMI. Still no change.. I have also removed the inside trim on the boot lid to gain access to the camera to check the wires and it looks good.
Its so strange i dont get a fault code when i do a scan.
In regards to your reverse camera have you tried altering he settings on the mmi because you can go back to just parking sensor display as an option in the mmi and have no picture or do you mean you still have the car legend to the side of the picture but the rest of the screen is black
possibly kessy on the way ( mossfit chip on the board) out or antenna is had it. More likely kessy. will still work but probably need to press remote for trunk access.
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 247
Mileage: 141936 km
Time Indication: 0
Date: 2016.07.27
Time: 11:27:46
Coding: 4063840
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 247
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 247
Mileage: 141904 km
Time Indication: 0
Date: 2016.07.08
Time: 00:20:56
Coding: 0071903
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:56
Freeze Frame:
Voltage: 11.50 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:57
Freeze Frame:
Voltage: 11.50 V
Coding: 0000000
2 Faults Found:
check your can gateway long coding mainly mmi stuff also see if reverse camera box is checked
+1 yes sounds like someone has had a play or mmi update. I am still sorting control head error after 5570 update.
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 141940 km
Time Indication: 0
Date: 2016.07.25
Time: 17:07:41
Freeze Frame:
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 247
Mileage: 141936 km
Time Indication: 0
Date: 2016.07.27
Time: 11:27:46
Coding: 4063840
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 247
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 247
Mileage: 141904 km
Time Indication: 0
Date: 2016.07.08
Time: 00:20:56
Coding: 0071903
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:56
Freeze Frame:
Voltage: 11.50 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 136076 km
Time Indication: 0
Date: 2016.01.18
Time: 00:38:57
Freeze Frame:
Voltage: 11.50 V
Coding: 0000000
2 Faults Found:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 141940 km
Time Indication: 0
Date: 2016.07.25
Time: 17:07:41
Freeze Frame:
