How I Replaced Rear EPB Brake Pads On My 06 A8L - AudiWorld Forums
Old 05-17-2014, 09:52 PM   #1
ltooz_a6_a8_q7's Avatar
Default How I Replaced Rear EPB Brake Pads On My 06 A8L
Alright, I've done it and after reading all these warnings from people, I just followed the video from VCDS and use simple logic to change my brake pads. As long as you have the $350 VCDS and a laptop, you can get it done pretty quickly. If the brake jobs out there are less than $350, then you may just let them to do it if you don't want to spend the $350 + laptop. People are reluctant to buy the VCDS because they're afraid to use the laptop and not the money (my experience with some of my friends and family members).
Again, this is the way I did mine, I'm sure there are many ways to skin a cat.
BTW, the tires are almost 30k miles, I think I have to replace them soon, on a 19", is it normal?
Cheers and enjoy,
Louis
ltooz_a6_a8_q7 is offline   Reply With Quote
Old 05-18-2014, 07:18 AM   #2
aTOMic's Avatar
Thanks for posting this. Where did you get the pads?(for $40)?
I'm curious as to why you did the brakes when the warning light wasn't on. Good thing you did, though.
Did the warning come on for the front ones when you did them @77k?
-Tom
aTOMic is offline   Reply With Quote
Old 05-18-2014, 08:11 AM   #3
Galco's Avatar
On rear tires, 30K miles is pretty good. My soft summer Hankooks only got about 20K. Newest set are all season Hankooks in hopes to get closer to warrantied 40K miles. Will see.
Galco is offline   Reply With Quote
Old 05-18-2014, 10:33 AM   #4
Default The front had sensors, the warning light did come up
-Tom
at 77k, but not the rear. So the rear can last 15k miles longer than the front.
Here is the link for the Bendix I bought
<a href="http://www.amazon.com/gp/product/B0063T02U0/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&cre ativeASIN=B0063T02U0&linkCode=as2&tag=dognmonkey-20&linkId=UNDSBGTELR5WHPAR">Bendix MKD1018 Semi-Metallic Brake Pad Set</a><img src="http://ir-na.amazon-adsystem.com/e/ir?t=dognmonkey-20&l=as2&o=1&a=B0063T02U0" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
Old 05-18-2014, 10:36 AM   #5
Default My all 4 tires are the same wear except one bent
Quote:
wheel, worn out from the inside a little more. Anyhow, 20k miles is too fast. I'm going to see if these will last 35k.
Cheers,
Louis
Old 05-19-2014, 01:50 AM   #6
Thank you for the post. Did you ever try it with the non-rosstech cable?
SoCalJ is offline   Reply With Quote
Old 05-19-2014, 12:51 PM   #7
Default No - I did not try the non-rosstech cable ...
Quote:
Here is my take about non-rosstech ($30) vs rosstech ($350):
-If you plan to keep the car and fix the brakes yourself - tools are required - must pay - Not just this version but my next Audi will also be eBrakes and $350 will be there (I hope) and supported.
-When it comes to messing around with signals controlling modules and stuff - I preferred the original - I'm sure the signal integrity is much cleaner than the cheaper version. When the signals communication serially and if a bit is missing due to noisy signal and change the outcome of the output and causes damage to my car computer... No thank you.
-Do it right so I don't have to worry about side effects of cheaper versions.
-I can afford it because when I bought this A8L with EPB brakes, I calculated the total cost of my car with this cable in it.
I read your other posts and you're having problems without and VCDS, and still procrastinate about getting cheap or full version while your car is sick - I would just get a $30 for now to scan the problems to fix the current problems - then when the time comes, buy the $350 if have to do the brakes if finance is the concern.
With all the money I've been saving by buying tools, fixing the house, the cars, I've been taking family to vacations and stuff.
Cheers,
Louis
Thread Thread Starter Forum Replies Last Post
Brakes: Cost Pads Rotors ebod0000 A6 (C7 Platform) Discussion 137 02-19-2017 06:38 PM
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Audi A4 2002 S4 6spd 98k rsixxer23 Vehicles For Sale 4 01-06-2016 04:25 AM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 12:39 PM
Brake Sensor Confusion C6Silver Q7 Discussion 4 09-01-2015 09:46 PM
Tags
06, a8, aodi, brake, braking, pads, placing
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
