how to remove trunk lid trim?
I've got a passenger inboard taillight with condensation and I want to take a look at sealing it up. However, I can't figure out how to get the trim off to get at it. Obviously I'm missing some screws somewhere but not sure where. Anybody have a write up on how it comes off?
Thanks
Thanks
I can't believe I didn't write this up
I've been opening this trunk trim so many times and I didn't even write up about it, I thought it was so obvious, but it wasn't.
Remove the tool box (4 screws), pop the cover out to see the screws
Remove the handle
Pop the rubber cover of the trunk latch out or if you pull the trim off, it will come out with it.
Remove 2 screws inside the right latch handle (picture above).
Now start popping out the clips along the trim, start with the top corner first until they all pop out, you can remove the lights and the trunk electric close switch plugs.
Hope this is clear enough
Cheers,
Louis
Remove the handle
Cheers,
Louis
Remove the tool kit (I think - mine is missing, grrr), then...
There's a screw in the recessed black trunk lid pull-down handle on the right side of the lid, then you pry off the glow-in-the-dark part of that release and the screw has to come out (has loctite BTW) then there are big spring clips which hold the whole lid liner on, I used half a clothespin to avoid scratching as I pried between the painted metal and the mouse fur liner (takes a bit of force, don't worry the spring clips are very stout). I first removed the bump stops but IIRC it was not necessary (they unscrew with an adjustable wrench).
I took pics but I am so busy lately haven't had time to do a DIY on here. I had the same leaky light problem as you!
-Tom
-Tom
-Tom
-Tom
Nice, good info thanks for posting.
Thanks for all the help guys!!
Now if I could've figured out how to get my hand in the trunk gizards to release the wiring clip I'd have done better.
Instead I pried the whole tail light apart and unclipped from inside. Sealed the outer edge and gasket with clear silicon. Not the prettiest but you can't see from the exterior.
Ran it to a self wash place and used the high pressure hose out, seems to be holding up until I'm in the mood to spend $400 on a replacement.
Remove the handle
Cheers,
Louis
Remove the handle
Cheers,
Louis
Remove the handle
Cheers,
Louis
Remove the handle
Cheers,
Louis
thanks again, you've saved this bloke two broken handles.
addìct
01-29-2005 09:05 AM
Steve Trac, Sec 303
08-20-2004 07:01 PM
Seanism (clone510)
08-01-2003 10:10 PM
bruce_hyman
05-26-2003 06:29 AM
RichMN
06-23-2001 09:29 PM
