Identify sound..
Identify sound..
My S8 is making a strange whining sound from the front possibly from the engine room, first i thougt it was the steering but i found out that it comes when i push the throttle down little, it makes a whining sound.
It is the same on all gears P N D.
It also gives a feeling of smal vibration. Its difficult to explain.
No fault codes that i can match it with.
I have searched "whining sound" "strange sound" etc but nothing that matches my problem.
Could it be any drive belt or something, i dont know how the D3 is when it comes to belts, but my D2 had drive belt.
also, you can use a pipe as a way to pinpoint noises, hold one end to your ear with the other at different pulleys and you'll be able to figure out exactly where the noise is coming from.... this method is a bit redneck, and if your careless its a good way to mess your car (or yourself) up by sticking a pipe into moving parts, standard "darwin" rules apply here.
My upper rear link arm has been bad and clonking i little while now, could this be the cause of the sound?
About the whining sound problem it disappeard while driving today, and i was thinking a little and may figured out where the sound came from.
I wash the car maybe 1 time a week now when its winter and dirty, and i use degreasing around the car, and i do the grills to, i spray direct in the grill, so maybe it has make some belt or bolt or something cleaned and degreased so it makes the whining sound.
So this do not sound good at all when thinking about it, so now maybe you can help me with a question, What kind of grease or lube do you prefer using in the parts behind the grill? I have heard that motor oil is not good (I used it on my old S8 D2 -98 belt fan when it sound bad, it helped for i little while).
It is unlikely that washing the car did anything to cause the noise. Start by looking at the belt. If the belt looks like the one on the left, it needs to be replaced. All of the wheels it connects to are the pulleys. The pulleys can also make noise if they are bad.
Thanks i will look at it tomorrow and see. Do you know if the steering has anything to do with the belt?
