Interior LED Kit + Exterior LEDs-Error Free-Lifetime Warranty-Free shipping
Audiworld Basic Sponsor
---------------------------------------------LEDs------For------Your-------Audi----------------------------------------------------------------
CHECK OUT OUR NEW AUDI SECTION ON OUR WEBSITE!!!!!
CLICK HERE for all Updated LEDs for your Audi Car - updated with new LEDs weekly!
Our LEDs are PLUG AND PLAY / ERROR FREE
**PLEASE NOTE** IF you do not see your model listed, contact us and we will work on SPECIAL PRICING to make you a custom set, if you help us test and review a NEW Audi LED Kit it will be FREE!!
Features of our LEDs:
-The lights will "fade out" when you turn off your car just like your current stock lights
-These will not stay on or “glow” after you shut off your car like other sets
-Crisp White color – No cheap blue or yellow tint
-Works with MFD (car controls)
-No Errors
-Lifetime Warranty
-No footwell spotting like other inferior LED sets
Interior LED Kits:
LEDs for Audi ? deAutoKey
License Plate LEDs:
Check out our Universal LED bulbs For Audi License Plates:
Universal License Plate LEDs Super Bright / Error Free Fits many VW and Audi Models ? deAutoKey
-Compatible with-
Audi MKII TT
Audi B5 A4
Audi B5 S4
Audi A3 8P
Audi A4 B6 B7
And our Complete LED Housing Audi License Plates:
LED License Plate Housings Crisp White-Error Free-Plug and play Fits: Many Audi Models ? deAutoKey
-Compatible with-
A3/S3 O4-09
A3 Cabriolet 08-09
B6 A4/S4 01-05
B7 A4/S4 05-08
A6/C6 05-09
S6 05-09
D3 A8/S8 03-07
Q7 07-09
RS4 Avant Quattro 06-08
RS4 Carbriolet 06-08
RS6 Avant 08-09
Before & After:
Same bulbs for sale are being used in cars below:
*NEW*LED FOOTWELLS:
New & the first!!
Footwell Option for Audi models equipped with OEM LED footwells!
Choose from Crisp White / Red or Blue!!
New LED Footwells for Audi models that are equipped with OEM LED Footwells ? deAutoKey
If you have non-LED Footwells, please follow link below:
2pc 6 LED Wafer Footwell set in Crisp White/Red/Blue fits: VW, Audi, all cars ? deAutoKey
*NEW*TRUNK LED Strip - Brightest option ever:
Get the brightest LED for your trunk with no hassle at our low introductory price. [THIS FITS ALL CAR MODELS]
To purchase:
Universal 48 LED Flexible Strip for your Trunk [Fits all Car Models] ? deAutoKey
We did the research, and created the best and brightest LED for your trunk, our 48 LED Strip simply lines your trunk, with either 3m tape or velcro which are both included.
This is the best solution for a dark trunk, easily installs and hides:
-Plug & Play
-Error Free
-48 Bright White LEDs (Also comes in red)
-Enough LEDs to light up your entire trunk but short enough to fit any trunk, can install vertically or horizontally.
-Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
-Strong 3M tape & Velcro so you can install on any hard surface or trunk lining (please use a blow dryer to heat up glue and cold metal, this will activate the glue)
-Resistor which allows for the light to stay on and not dim if your dome lights shut off while trunk is open. This feature is a must have, it allows for a bright continuous light at all times.
-Trunk LED will not stay dimly lit when your car is off.
-Comes with 3 adapters: Wedge, Adjustable Festoon, and Bayonet, this will fit every trunk adapter on the market.
Actual LED strip measures: 31 inches – this length will fit all trunks, can install vertically or horizontally.
Black Wire measures: 52 inches – please note- excess wire simply tucks into your trunk’s housing/lining so you will not have any leftover in your trunk.
Includes:
1 LED strip with strong 3M tape attached
3 Adapters (Wedge/festoon/bayonet)
3 Pieces of velcro
-No Errors
-Lifetime Warranty
Interior LED Kits:
License Plate LEDs:
-Compatible with-
Audi MKII TT
Audi B5 A4
Audi B5 S4
Audi A3 8P
Audi A4 B6 B7
-Compatible with-
A3/S3 O4-09
A3 Cabriolet 08-09
B6 A4/S4 01-05
B7 A4/S4 05-08
A6/C6 05-09
S6 05-09
D3 A8/S8 03-07
Q7 07-09
RS6 Avant 08-09
Before & After:
*NEW*LED FOOTWELLS:
New & the first!!
To purchase:
-Plug & Play
-Error Free
Includes:
3 Pieces of velcro
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
LEDs are an investment.
Check out www.deAutoLED.com to see all our LEDs available!
LEDs:
-Are an upgrade to any car
-Creates a more appealing & modern look to your car
-Are safer and creates a more enjoyable riding experience
-Our LEDs come with a Lifetime Warranty!
This is one of the few mods that will normally add to your car’s resale value!
LEDs:
Bright error free LEDs:
194 10pc CREE LED Reverse LED Fits:Audi A3/S3/RS3 + Many More | deAutoKey
Attachment 100792
Attachment 100792
Amazing review of our error free BRIGHT Reverse LEDs:
Ok all, here is the write up on the DeAutoLED rear LED reverse lights vs stock & the license plate LEDs.
The overall assessment on the reverse lights is get'em. Totally worth it. Brighter by far. I can actually see in my rear camera now. Night and day (pun intended) difference.
The License plate lights, well, they don't fit. The actual piece looks nice, and I'm sure it's brighter, but they aren't plug & play with the Audi wiring. They sent a wire adapter with them, but it does not fit the Audi wiring either, and to be honest, the small end plug that fits into the light housing itself is pretty flimsy. Not a solid click in like the OEM one. I'd recommend skipping these, as I am sending mine back.
So here goes the install on the reverse lights. Easy Peazy. Trim tools required and one Phillips head screwdriver. Reference above link I put in my thread for a video.
Before
Drivers side (Left) LED/ Passenger (Right) OEM bulb
Both side LEDs
Close up OEM Bulb
Close up LED
Install
Pop the square bumper plate with plastic trim tool
Use Phillips screwdriver to loosen retaining screw
Pop the reflector/light housing out of the bumper with plastic trim tool
Locate the ballast for the reverse light. Rotate it, take it out, and remove OEM bulb.
Before
Both side LEDs
Close up OEM Bulb
Close up LED
Install
Thanks for the orders and support - if you have any questions our friendly staff is virtually available 24/7:
www.deAutoLED.com
www.deAutoLED.com
www.deAutoLED.com
www.deAutoLED.com
Received quickly USA to Australia and included spares.
We receive a lot of business AFTER someone purchases a different LED they are not happy with or cause errors, so we really appreciate you taking the time to write this feedback as it allows us to confirm we are doing something right for the Audi/VW community.
Thank you again
Clean smooth OEM fade in/out with all of our Interior LEDs including trunk LEDs!
-our LEDs also WON'T stay dimly lit when your car is off!!
https://vimeo.com/101984748
See the difference with our LEDs and Customer service! Free shipping and lifetime warranty on all LEDs/HIDs!
See the difference, feedback like this makes bringing only the best quality LEDs and testing EVERYTHING we sell worth it!
FREE SHIPPING WITHIN THE US!
