Intermittent "Parking Brake!" warning
#11
also if I try to re establish connection after it looses it I cant until the car is stopped
#12
Did you check the wiring for issue as Mainely and MP4 suggested? If the issue stayed with that side, that's the likely culprit. Where a wire bends or is exposed to the most heat or elements would be the most likely spots to deteriorate.
#14
#16
Again, just based on history of issues on board over many years, more than a few have unwrapped that harness area just below the module and found widely varying issues and sometimes pretty appalling corrosion--like sort of a loom of quasi bare wires in worst cases. Might be issue w/ module itself I suppose, but first be sure harness is in order given some have found obvious issues there. You could also ohm (continuity) test it from connector out to wheel sensors, but you need to find the connector pin out for that.
#17
#19
I've checked continuity in the wiring on both sides and they read less than an ohm. I bent and tugged an jiggled all the wires and couldn't recreate an open circuit. I also pulled the fender well out on the drivers side. I moved and jiggeled the main harness as well and still couldn't recreate the problem. No obvious signs of corrosion or chafing anywhere. One side note regarding my loss of communication at 19kmh. Apparently that is programmed into vagcom or the module for "safety reasons". Also another odd thing I saw today on vagcom is that I watched the right side wheel speed sensor not read at all. Then I shut the car off and restarted it and it was working again.... pulling my hair out at this issue because I want to say its the module but I want to be sure its not the wiring first. Any specific places on the harness I should check? Thanks for all the help!!
