LIQUI MOLY
LIQUI MOLY
Hi guys,
I just want to share an update.
After I bought my S8 I used LIQUI MOLY fuel additives with Shell V-power and you can feel difference in performance. Oil change was done with Liqui Moly oil.
Also new K&N air filter helped a lot.
Now after trip to KY this weekend my car sounds funny. There is possibility it is a hole in the flex pipe. I will upload video of the sound tomorrow in new thread.
Read the first post in this thread:
https://www.audiworld.com/forums/a8-...-read-2877219/
Then heed the advice to use the search function. I mention it in relation to your K&N air filter. Dozens if not hundreds of posts regarding them. You will want to remove them immediately from your vehicle.
Or, use the referenced parts suppliers to purchase new Mass Airflow Sensors.
Hope it is not MAF
Hi guys,
I have a bunch of K&N filter cleaner and oil.
I'm in the minority here about K&N filters. I ran one in my Q45 for 6+ years, 10+ years on my D2, and 2+ years with my W12. I am very careful on the use of their oil. I use it very, very lightly. So I personally have a good track record with K&N.
I guess we both are in the minority. I ran one for over 10 years in a 5 speed maxima with a MAF! No problems at all!
I just verified that my 1994 Q45 did have a MAF sensor. I seriously did use very minimal oil.
As a side note, I use BG44K every 10K miles but I think I'm going to use it every 5K. It cleans everything because it does not burn. My thought is that used regularly, it will keep my O2 sensors relatively clean. I can tell a little bump in miles per tank.
https://www.audiworld.com/forums/a8-...2866998/page3/
https://www.audiworld.com/forums/a8-...2878901/page4/
I'll add to the strong advice to not use oiled air filters such as K&N.
They flow better because they don't filter as well.
If you're driving in a dusty area, silica particles that would otherwise be trapped by paper are making their way into the cylinder head past the rings into the crankcase, where they slowly cause wear.
Is it worth the risk to the MAF sensors, and the wear on the reciprocating bits, for a supposed few extra horse powers?
Besides, the dual air box systems on the S8 and W12 flow plenty.
As for fuel system cleaners, the active ingredient that has been tested and proven to work is PEA.
I add 3.75 ounces of Redline to each tank of gas.
We know how much PEA it contains by it's MSDS, other manufacturers not so much.
MSDS;
Redline SI-1 https://www.redlineoil.com/content/f...DS%2012-12.pdf (2013: 30-40% PEA)
Techron https://cglapps.chevron.com/msdspds/...&docFormat=PDF (2011: PEA not listed, but company confirms it’s still being used, see Chevron's Response on PEA in Techron | Fuels and Fuel Additives: Gasoline and Diesel | Bob Is The Oil Guy)
BG 44K http://bgfleming.com/products/msds/208.pdf (2013: doesn’t use PEA)
MSDS;
