Shudder Bounce in D
Shudder Bounce in D
Hello everyone newbie here
I have a problem in my 2005 Audi A8 3.0 v6 that I purchased. The car starts and idles perfectly although when I select drive or sport or use the flappy paddles and accelerate there is a hesitation a shudder from the engine. Its as if there is a misfire in the engine at certain points. The car will drive although continues to do this whilst you accelerate. If I place the car in neutral it will rev perfectly with no misfire symptoms. It leads me to believe there is a problem with the automatic gearbox..
Any help would be greatly appreciated.
Thanks
Thanks
Thanks for your reply. I put it onto VCDS and it came back with cylinder 6 misfire and engine mount solenoid valve. I'm going to replace all spark plugs and see if this help and see if the engine mounting is leaking or done.
I think the engine mount is more likely the problem...
Cheers and good luck,
Louis
+1 on that & mishar's advice
Also scan the tranny if you haven't already, plus note/tell us if the shudder is always involving the same gear. There is a known issue around 4-5 that affects the ZF six speed if it turns out to be there consistently--also makes a "hooting" noise at the same time.
Spark plugs sound likely so far, but other possibles can be 02 sensor, MAF issues, cam/timing sensor issues, and the spark plug coil pack. You should usually see codes for those kinds of scenarios, and plugs sound likely/promising so far given the code. BTW, if plugs look good and/or if issue persists w/ the code, then expect it is the coil pack for that cylinder. Common modern Audi problem, and literally millions were recalled for new coil packs, my W12 (x12!) included.
kraizeaudi
01-19-2011 02:54 PM
maaliish
08-04-2006 03:06 PM
SuperGreg
12-04-2003 10:54 AM
