Mmi issues - AudiWorld Forums
Mmi issues
Old 02-12-2014, 11:24 AM   #1
Default Mmi issues
A8l 2004. The mmi screen and radio would go on and off randomly. Removed center console and opened up controls and cleaned curcuit board and found stuck button. Cleaned and put back together and everything worked great except car button. Removed again and cleaned that area on curcuit board and reinstalled now I have nothing seams all power is gone. Any thoughts would be appriciated.
Thanks
Jamie
Jfthrasher is offline   Reply With Quote
Old 02-12-2014, 01:21 PM   #2
Senior Member
MP4.2+6.0's Avatar
Default The circuit board does not like liquids.
If you did it with just air, an electronics solvent or rubbing alcohol that dried, it should be okay, and I would recheck connections and then wherever the fuse is. If you used a water based or non quick dry solvent (409, Windex, whatever) unfortunately you may have fried it with power applied.
MP4.2+6.0 is offline   Reply With Quote
Old 02-12-2014, 01:57 PM   #3
I used an electronics quick dry plastic safe solvent. I couldn't locate a fuse for tuner. I did find the fuse for the nav system and it was fine. Still get no lights sound land screen does not open.
Old 02-12-2014, 02:58 PM   #4
mishar's Avatar
Screen won't open if it is muted. Try pressing the volume button.
mishar is online now   Reply With Quote
Old 02-13-2014, 12:41 PM   #5
Quote:
I have pushed all buttons. And still nothing Even tried the three button reset and system does nothing.
Went ahead and orderd replacement control .. We will see if that does it.
Old 02-18-2014, 10:11 AM   #6
Replaced control buttons in center console and still nothing.
Checked fuses on both sides of dash and on both compartments in truck. All look good
Any suggestions?
Old 02-18-2014, 10:57 AM   #7
mishar's Avatar
Quote:
Have you replaced only buttons or circuit board too?
VCDS scan would be the next.
Old 02-18-2014, 11:10 AM   #8
Complete new assembly buttons and circuit board
Old 02-18-2014, 07:50 PM   #9
Having scan done tomorrow
Old 02-20-2014, 03:12 PM   #10
Spoke with mechanic and he said he had never seen such.... The scanner makes no connection to mmi units. He said it was like they were not there. We are all scratching our heads.
Thread Thread Starter Forum Replies Last Post
How to mirror your phone on the MMI screen markN1689 Audi A3 / S3 /RS 3 MKII 149 01-13-2017 02:21 PM
MMI Car button Doesn't work 2004 audi a8l hellonwheels33 A8 / S8 (D3 Platform) Discussion 27 09-02-2016 01:29 AM
ATTN D3 A8 Owners:OEM AMI Bluetooth Adapters Located! milellie111 A8 / S8 (D3 Platform) Discussion 18 09-19-2015 08:22 AM
New 2016 Q5. Help picking SD Card DaGrandMastah Q5/SQ5 MKI (8R) Discussion 19 09-11-2015 08:50 AM
Android app issue sethm1 Audi A3 / S3 / RS3 0 09-04-2015 05:01 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
