My 2004 A8L 4.2 died after a normal journey
My A8 have suddenly problems, I made a journey of 125km, parked the car and came back after 20min and started the car and it was running but cluster dead. After 5 km I went out of the car again and came back after 5 min. car start and die after 2 seconds, cluster still dead. Engine start but don't run because immobilizer box get no power I suppose.
Booth only to open with key. Xenons burn without key so I hat to pull the fuses to save my battery. Alarm Leds in the door flashing but I cannot lock the car.
The fuses on left side show some water corrosion, I pulled all and clean them. 6 months befor I have water leak problem from my sunroof, i opend that time the drains by a wire and they flush again. After the car was function without problem, only my MMI panel is not function 100% but I don't care so much.
Somebody an idea whats wrong ? maybe J519 gives a problem.
Start by making sure battery is fully charged
D3 A8's can do a lot of weird things when the main battery is discharged. It may appear many systems have issues, only to find it is a more basic battery fault. If your battery is more than 4-5 years old, it is fair to assume it may now be faulty and need replacement. At least getting it fully charged first will help diagnose.
AudiWorld Wiseguy
+1 on the diagnostic scan, but your mention of what sounds like quite extensive past water damage to the electrics is I suspect still haunting you. There is corrosion in the electrics somewhere that's probably now got to a critical point to cause this problem.
So, it's been 12 months since the issue started and it visited a dealer at some point? And no follow up below about even basic stuff concerning the battery (car should be about on its third one by now), let alone scan?
Is this a "test"--like your signature suggests?
Net, I don't follow and why 12 months passes in between. The other power (battery) management thread/post makes it more a guessing game. Again the pointer to that area was right here from me a year ago. Please explain more the history, current issues, where you are on looking at obvious stuff like battery and its age, etc.
Without a scan and for anything beyond the battery, 99% chance you are wasting your time. No one can tell you magically, oh that's the standard flux inverter problem with the 2y 3x prime variant and you just order part z and all is good.
Now the car is back and have more time to get it running again.
I'm Duracell automotive dealer and battery no issue, easy to swap for me and prog a new BEM code.
(PS, I advice to use a AGM gell battery if some components not to want go sleep )
Last 2 days I did a selfstudy and I have now the Electric schematics and more, end of the week I suppose it will run again. Below the VCDS code.
VIN: WAUML44EX4N012605 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Cannot be reached 1100
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Cannot be reached 1100
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0C9525291
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4D05FECE1DD1E68D9-804A
8 Faults Found:
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster
18347 - Powertrain Databus
P1939 - 008 - Missing Message from Controller for Access & Start Auth.
18044 - Powertrain Data Bus
P1636 - 008 - Missing Message from Airbag Controller
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0022839
Coding: 0000002
VCID: 24470A12E77BF23ED0B-8071
3 Faults Found:
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 102.0
Temperature: 9.0°C
T.B. Angle: 0.0°
Voltage: 12.64 V
18271 - Powertrain Data Bus
P1863 - 000 - Missing Message from Steering Angle Sensor
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 102.0
Temperature: 9.0°C
T.B. Angle: 0.0°
Voltage: 12.64 V
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 102.0
Temperature: 9.0°C
T.B. Angle: 0.0°
Voltage: 12.64 V
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth.
Cannot be reached
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2345090EE275F506A91-8076
No fault code found.
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0260
Revision: 00000021 Serial number: 00000000028070
Coding: 1085761
Shop #: WSC 02311 785 00200
VCID: 1B3531EEDA05CDC6611-804E
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 02005039230A5E
Coding: FCFE7BDD1B2304
VCID: 2643101A9147002ECEF-8073
4 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 15
00381 - Databus Instrument Cluster
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 3
Time Indication: 15
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 15
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 15
Address 25: Immobilizer
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0025510
Shop #: WSC 00011 888 06946
VCID: 25411716EC410B36C75-8070
1 Fault Found:
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Mileage: 0 km
Time Indication: 0
Address 36: Seat Mem. Drvr
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040511110118
Coding: 0004857
Shop #: WSC 02729 823 28888
VCID: 285F1E229B53165EFC3-807D
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
10 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 3
Mileage: 186700 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:00
00576 - Terminal 15
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 36
Reset counter: 3
Mileage: 0 km
Time Indication: 0
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Reset counter: 3
Mileage: 135370 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:04
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 159
Reset counter: 3
Mileage: 135370 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:01
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 136
Reset counter: 3
Mileage: 135370 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 38
Reset counter: 3
Mileage: 0 km
Time Indication: 0
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 32
Reset counter: 3
Mileage: 30230 km
Time Indication: 0
Date: 2011.10.12
Time: 22:52:04
01308 - Control Module for Roof Electronics (J528)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 25
Reset counter: 92
Mileage: 30225 km
Time Indication: 0
Date: 2011.07.06
Time: 16:11:07
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 62
Reset counter: 3
Mileage: 186700 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:27
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 92
Mileage: 30226 km
Time Indication: 0
Date: 2011.08.18
Time: 05:37:32
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000023385
Coding: 0010101
Shop #: WSC 12345 123 12345
VCID: 1E3338FAC917D8EE86F-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
VCID: DEB3F8FA099718EE46F-808B
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000531
Shop #: WSC 80093 222 18370
5 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
Freeze Frame:
Voltage: 12.32 V
Count: 247
02434 - Supply Voltage for Control Module for Left Channel
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11111001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 3
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 12.32 V
Count: 112
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 3
Time Indication: 0
Freeze Frame:
Voltage: 11.28 V
Count: 242
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Reset counter: 3
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 5.07 V
Count: 40
02435 - Supply Voltage for Control Module for Right Channel
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 12.32 V
Count: 113
Address 55: Xenon Range
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000001755
Shop #: WSC 00000 000 00000
VCID: 204F0602F363EE1EB43-8075
Subsystem 1 - Part No: 310 314 E04 G
Component: von VA0 310314E04G
Coding: 333130333134453034472056413033313033313445303447
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 186700 km
Time Indication: 0
Date: 2003.08.07
Time: 14:04:30
02273 - Quiescent Current Stage 2
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 186700 km
Time Indication: 0
Date: 2003.08.07
Time: 14:04:30
Address 62: Door, Rear Left
Cannot be reached
Address 65: Tire Pressure
Cannot be reached
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
VCID: DDB1FFF6049103F65F5-8088
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3005120
Coding: 0000005
Shop #: WSC 08252 444 52590
VCID: E0CFC60230E32E1E743-517A
Subsystem 1 - Part No: 4E0 910 616
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 76: Park Assist
Cannot be reached
End ---------------------------------------------------------------------
