my P0701 code. easiest explanation for me to understand
P0171 and P0174 - OBD-II Trouble Codes
Auto Systems and Repair
Fuel System Too Lean (Bank 1 or 2)
Our emissions expert has put together the following information about the P0171 and P0174 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
OBD II P0171
OBD II P0174
Fault Code Definition
OBD II P0171 Fuel System Too Lean (Bank 1)
OBD II P0174 Fuel System Too Lean (Bank 2)
Symptoms
Check Engine Light will illuminate
In some cases, no adverse conditions may be noticed by the driver
In other cases, there may be performance problems, such as a lack of power on acceleration and some "coughing" or misfiring
The vehicle may have trouble idling, especially when warm or when sitting at a stoplight
Common Problems That Trigger the P0171 and P0174 Code
PCM software needs to be updated
Vacuum leaks (Intake Manifold Gaskets, vacuum hoses, PCV hoses, etc.)
Mass Airflow Sensor (MAF)
Plugged Fuel Filter or weak Fuel Pump
Plugged or dirty Fuel Injectors
Common Misdiagnosis
Oxygen Sensors
Polluting Gases Expelled
NOX (Oxides of Nitrogen): One of the two ingredients that, when exposed to sunlight, cause smog
HCs (Hydrocarbons): Unburned droplets of raw fuel that smell, affect breathing, and contribute to smog
The Basics
Combustion engines operate by burning an air/fuel mixture of about 14.7 to 1—14.7 parts air to 1 part fuel. When the air ratio goes below 14.7 parts, this is called a "rich" mixture. If the air rises above 14.7 parts, it is called a "lean" mixture.
Rich Mixture = Too much fuel, not enough air
Lean Mixture = Too much air, not enough fuel
To keep the engine running properly, the Engine Control Module measures the oxygen content in the exhaust with oxygen sensors and makes adjustments to the mixture by injecting more or less fuel.
The control module operates within specific parameters and under normal conditions, it will make minor adjustments to the air/fuel mixture. When these adjustments become too large, a fault code is set. When the P0171/P0174 code sets, the oxygen sensors are detecting too little oxygen in the exhaust and the control module is adding more fuel than normal to sustain the proper air/fuel mixture.
P0171/P0174 Diagnostic Theory for Shops and Technicians
When a vehicle has the fault code P0171 and or P0174, it means that computer can no longer automatically adjust the mixture between air and fuel. Code P0171 applies to Bank 1 and P0174 applies to Bank 2. Code P0174 mainly applies to V6 or V8 engines because 4-cylinder engines generally have only one bank, though there are a few exceptions. Some of the high performance 4-cylinder and straight 6-cylinder engines (such as those in BMW and Lexus) split the cylinders into groups of two or three and call them separate banks.
When the code says that the Fuel System is "too lean," it means that the computer has been adding more and more fuel, which is called Long Term Fuel Trim. Ideally, the Long Term Fuel Trim should be close to 1 to 2 percent. When a code P0171 is set, it means that the Fuel Trim is anywhere from 15 percent to as high as 35 percent compensated. When this happens, the computer knows that there is an improper condition in the control of the Fuel System.
The first step in the diagnosis of a code P0171 and/or P0174 is to look at a minimum of three ranges of the Long Term Fuel Trim numbers on a scanner. Check the idle reading—3000 RPM unloaded and 3000 RPM with at least 50 percent load. Then check the freeze frame information for the code to see which range(s) failed and what the operating conditions were.
Before we get into the main causes of P0171, let's explore why this code matters.
Why Does a P0171/P0174 Code and Running "Too Lean" Matter?
"Lean" running cars and light trucks are highly polluting vehicles. Most of the NOx pollution, which is poisonous and can cause asthma, is caused by vehicles that are running too lean. A lean running car can also misfire, which puts raw fuel (HCs) into the atmosphere. When you are behind a car or truck that smells bad and makes your eyes burn, it is misfiring and running too lean. In comparison, a "rich" running engine has no smell (CO is odorless) or you may detect a rotten egg smell, which is caused by the Catalytic Converter consuming too much sulfur, like when you are behind a big SUV at full throttle going up a long, steep hill.
P0171 is not an Oxygen Sensor problem. Before a P0171 code is possible, the computer first ran a series of tests to validate the readings from the oxygen sensors. Since the oxygen sensors passed their readiness tests and didn't set any codes, the computer then looked to the Fuel Trim adjustment. When the computer determined the air-to-fuel mixture to be too lean, it then set the P0171 code.
What Are Some Common Causes of Code P0171/P0174?
Always check to make sure that there is not a PCM software update due or available. Often, as the vehicle's engine wears, the PCM's Fuel Map software inaccurately compensates for this condition. The fuel mixture grows lean and eventually, the code sets.
A vacuum leak is very common. It could be a torn PCV hose, a torn Intake Air Boot, or even a broken seal on the dipstick (the dipstick is a part of the PCV system and if it does not seal, too much unmetered air will enter the engine). Don’t rule out a sticking/leaking EGR Valve or leaking EGR or Intake Manifold Gasket. If it is a V6 or V8 engine and the code is only on one side/bank, it could be a defective Intake Manifold Gasket or cracked/leaking manifold.
What if There Is No Vacuum Leak or Both Codes (P0171 and P0174) Set?
An "under reporting" Mass Air Flow Sensor can be a common cause of a code P0171 and P0174. Essentially, this means that the Air Flow Sensor is telling the computer that much less air is entering the engine than actually is.
Since the oxygen sensors are telling the computer that more fuel is needed, this causes confusion in the computer because the Mass Air Flow Sensor is still saying there is too little air and the Oxygen Sensor is reporting that the mixture is still too lean. The computer tried to compensate, but since resolution is impossible, it sets the code. It is important to restate that the Oxygen Sensors are accurate—the fuel mixture is too lean. In this case, the Air Flow Meter or Sensor is inaccurately reporting the real amount of air entering the engine.
How Do I Know if the Problem Is the Mass Air Flow Sensor?
There is a very effective "truth test" for any Mass Air Flow Sensor. Start the engine, let it idle, and then check the Barometric Pressure reading on the scan tool data. If the reading is about 26.5 Hg and you are close to sea level, you know that you have a defective Air Flow Meter because it is telling you that you are at about 4500 feet above sea level. (These conversion tables will help.) When the Mass Air Flow Sensor sees this Barometric reading, it adjusts its Air Density table and then "under reports" the actual amount of air entering the engine. It does this because the Barometric Pressure Sensor is actually part of the Mass Air Flow Sensor.
Sometimes the Air Flow Sensor and the sensing wire get covered with dirt, dust, or oil residue, which can also set a P0171. Cleaning the sensor might hold off problems for a while, but eventually, the MAF sensor should be replaced. Always make sure the Air Filter and its enclosure are dirt-, dust-, and oil-free. If you clean and replace the filter and its enclosure as needed, you will prevent the new MAF from failing.
Additional Causes of Code P0171/P0174
A plugged Fuel Filter or poorly functioning Fuel Pump can set the P0171 code. The computer hears (accurately) from the Oxygen Sensor that the Fuel Mixture is too lean so the computer keeps increasing the amount of fuel being delivered into the combustion chambers. But in this case, the Fuel System can’t increase the amount of fuel.
If you still can't find the problem, be sure to check and verify that fuel pressure and delivery are at spec. If fuel pressure and volume check out okay, scope the injectors and perform injector drop and/or flow tests to see if they are capable of delivering enough fuel. Dirty/contaminated gas can definitely plug injectors and trigger these lean codes.
Watch This Video for Help Diagnosing "Lean" Codes
OBD II Fault Code
OBD II P0171
OBD II P0174
Symptoms
Common Misdiagnosis
Oxygen Sensors
The Basics
Fine/Auto 101. But, how does this help you fix your D3 specifically?
To be very direct P codes are kind of crap to me. I think people have already so of told you that in other posts IIRC. If you own a Toyota or many other vehicles that's about all you get. Better than nothing, but mediocrity for VW/Audi diagnostics. Or if it's a BMW as another example (or my Mini with the same electronics), unless you pay though the nose and then are prepared to deal with essentially assembly language yesteryear macro crap for any customization, back to P code simplistic tools.
Then layered on top of P code generics to start with, what you have here is a very generic, very lengthy treatise on general stoichiometric (aka 14.7 to 1) stuff and some overlapping subjects. It is helpful for Automotive Gasoline Engine Theory 101, so I respect you may find value there. But as far as fixing a D3 or Audi specifically (if you are doing that still), I think you are trapped in generic code babble of sorts. As I think came up in prior posts, do yourself a really big favor and buy a VCDS. Putting a point on it, a lot of times when I see P code posts (aka crap tool info posts in my book), I just roll my eyes and let someone else deal with it a lot of the time.
To be specific, having skimmed that stuff it both gave a lot of kind of false leads that I don't think are common with Audis, and didn't seem to even flag one of the biggies. To me, the lean codes by themselves (not coupled with 02 sensor codes) most commonly are somewhere in the secondary air injection system or in assorted vacuum leaks. It mentions vacuum leaks generically, but unless I missed it says squat about SAI. If you have what I have to characterize as the "real tool"--that is a true gift and wonder compared to anything else I know of or have to contend with when I try to fix other brands of cars in the family--you would really tire of the frustrating P code simplistic stuff. And then when it sends you down lots of ratholes not common to the Audi more typical issues, and totally seems to miss another (SAI), not good. BTW, it also fails to mention that on the check engine light (CEL) area, Audi's behave very characteristically when there is an issue in this area. You clear the codes, and then two driving cycles later (cold hot cold = one cycle) the light comes back. Very good pointer it is in this same area--vacuum leaks or SAI the same early suspects with any lean code info. Getting to the bottom of issues in the lean code area are already hard because they are often at the intersection of some overlapping systems, but you are tying at least one hand behind your back and wearing 10 year old scratched up Dr. Dean readers from your sister in law instead of your real prescription.
If you still have a real issue with your D3, let us know what the VCDS codes are.
I felt that if it were a hose or one of the other issues they mention, that I could check those things out on the weekend.
A vcds might be more dangerous than helpful in my hands ! I'm being half-joking.
The cheapest right now is the visual inspection route.
Where I live there are a handful of people that could troubleshoot this car.
I've got a few things colliding all at once--e-test, money, time--and I'm just trying to balance them all.
always appreciate your responses.
There are decent independents - but not many and the good ones charge appropriately.
I would suggest taking the vehicle off the road if the e-test is imminent.
There is a real possibility you will need one or more of these:
VCDS $350
SAI $300
Lambda $125
Coil pack $20
MAF $200
And then there's these:
Strut $600
Valve block $450
Then there is the question mark of the TCU code you recently got.
Bottom line there is no cheap/easy fix here, especially if time is not on your side.
That's more than most areas have, especially if they can really do it and aren't self-professed experts.
Let's cut to the chase.
VCDS $350
SAI $300
Lambda $125
Coil pack $20
MAF $200
Strut $600
Valve block $450
VCDS $350
SAI $300
Lambda $125
Coil pack $20
MAF $200
Strut $600
Valve block $450
2 independants that might/could/will help me find my issues
and neither is the sole dealership in this city.
cus I didnt buy or lease from them on regular basis they always gave me the least able technician.
It took 3 visits for them to figure out why cold water was dripping onto my feet when a/c was on. seriously.
It turned out to be clogged plennums (?) with tree debris.
wouldnt someone kinda know that around the shop ? this is a big big dealer too.
It's just the way it is.
However.... not knowing about clogged drains is nearly incompetent in my book.
Then again, most people are 'technicians' [aka parts changers] and not mechanics these days.
Of the two indys in your area I hope at least one has a dealer level diagnostic tool like VCDS.
Otherwise none of the problems will get fixed.
PaulW
10
11-19-2008 06:42 AM
ToledoS4
06-12-2002 03:55 PM
