New to us 08 D3 S8 in Ice Silver
Imported it and drove it home last night! What a car. I will use this thread to detail any updates and troubles I have with the car as to not create a 1000 new threads. Kind of a log really.
My first gripe about the S8..the short gearing in the differentials, or short OD gear! jeez man you dont need to be revving at 2700 rpm doing 75 mph...no wonder the mileage sucks!
Other than that...I thought my ls400 interior was quiet, this is definitely an order of magnitude quieter.
The car:
2008 Audi S8, Ice Silver Metallic on Black Valcona leather.
-Base bose system
-extended leather
-solar sunroof
-convenience package
-sport steering wheel
-gunmetal grey 20" summer wheels
-c6 RS6 19x8.5" winter wheels
-121,000 km at pickup.
First order of business: front upper control arm bushings. then, resonator delete. Change the rear license plate lights to canbus LED.
A couple dirty pictures:
The car:
-Base bose system
-extended leather
-solar sunroof
i can shift it by the flappy paddles and on the stalk.
75 is 120ish kph and this one revs the same way ours does.
I assume the A8 revs lower due to different gearing, but they share the same trans.
I've rechecked numbers and it seems you are closer to the right speed/rpm. S8 at 2700 rpm runs 78 mph in 6th speed. A8 at the same rpm goes 96 mph. Gearing it that way they achieved better acceleration. That's what "S" is about, not fuel consumption.
S8 would theoretically go 214 mph at 7000 rpm in 6th gear. For that it would need close to 1000 HP. As it is it is fastest (without limiter) in 5th gear 171 mph.
I am reading MMI newest version for 2G is 5570 yes?
Dealer wants $250 for the discs and cant see which version they would be ordering.
I read people get these discs from audi for $10???
Mainly looking to have 3d maps and have ability to connect USB stocks for music in the car.
Currently running 4140
That is for european market cars. USA current version is 4610. Part# 4F0-998-961. You can buy it from many reputable sources. Beware some are selling burned copies which can malfunction during install and cause issues. You also have to upgrade map discs but I'm not sure how new they need to be in order to do the 4610 upgrade. Even with that you do not get 3d maps in the USA. The only way to get 3d maps is to upgade to a D4 . Not sure about the usb to AMI with the upgrade as my D3 didn't have AMI.
finally did a full system scan. Also lowered the front 10 mm. and did and alignment (good for alignment, the toe was wayyyy out of whack with the busyed outer tie rod, i replaced it but had no real way of knowing what was supposed ot be right). feels much better now.
here are the results. looks like it did have a midfire back in may once or twice.
carbon clean the intake and sonic clean the injectors eventually. but so far engien runs very smooth.
i di smell some oil, looks like the VC have a tiny seep near the rear. enough that there is dirt stuck to it, but no fresh oil that i can see. need to take the belly pn off and give it a good look over some day.
Friday,26,August,2016,17:36:19:07205
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
Ross-Tech: Home
VIN: WAUPN94EX8N000738 License Plate: JENYBUG
Mileage: 121720km-75633mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN94EX8N000738 Mileage: 121720km-75633miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BSM) Labels: Redir Fail!
Part No SW: 4E0 910 552 K HW: 4E0 907 552 A
Component: 5.2L V10/4V FSI Ŗ0040
Revision: 5IH02--- Serial number: AUX3Z0G7728452
Coding: 01060009190F0160
Shop #: WSC 94817 999 177420
VCID: 2A5BC12A85E30C12DE-807E
2 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 31
Reset counter: 255
Mileage: 119635 km
Time Indication: 0
Date: 2016.03.23
Time: 14:31:31
Freeze Frame:
RPM: 681 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 51.0°C
Temperature: 18.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 121721 km
Time Indication: 0
Date: 2016.08.26
Time: 17:30:55
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 102.0°C
Temperature: 81.0°C
Voltage: 11.938 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H03--- Serial number: 0111352
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 24472F12E7C7DA62E4-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT
Component: ESP 5.7 allrad H49 0650
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 2B55C42E8A19151A25-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G7728452
Coding: 0410624
VCID: 58BF4BE2EB0F4E82B8-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 230
Mileage: 111184 km
Time Indication: 0
Date: 2015.08.12
Time: 08:50:46
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 14
Time Indication: 0
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 8
Reset counter: 76
Mileage: 120608 km
Time Indication: 0
Date: 2016.07.25
Time: 14:59:38
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 121216 km
Time Indication: 0
Date: 2016.08.25
Time: 13:34:22
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 02313 758 00200
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348HY077526066
Coding: 0000003
VCID: 224B290AFDD3D45296-8076
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000043940
Subsystem 3 - Serial number: 0106.08.070000000100010058˙
Subsystem 4 - Serial number: 010058˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000129117
Coding: 0041409
VCID: 1C3717F2DFB7E2A25C-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133123
VCID: 387FEB624B4FAE8258-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 120614 km
Time Indication: 0
Date: 2016.07.12
Time: 17:49:43
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 275D381E56F1317AC1-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0129186
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F6DD03EBE01693A09-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 5
Reset counter: 4
Mileage: 120196 km
Time Indication: 0
Date: 2016.05.16
Time: 10:31:45
Address 11: Engine II Labels: Redir Fail!
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119934 km
Time Indication: 0
Date: 2016.05.12
Time: 08:59:25
Freeze Frame:
RPM: 1903 /min
Load: 48.2 %
Speed: 39.0 km/h
Temperature: 24.0°C
Temperature: 17.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.335 V
000776 - Cylinder 8
P0308 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119934 km
Time Indication: 0
Date: 2016.05.12
Time: 08:59:25
Freeze Frame:
RPM: 1903 /min
Load: 48.2 %
Speed: 39.0 km/h
Temperature: 24.0°C
Temperature: 17.0°C
Voltage: 13.335 V
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV00003GM
Coding: 0532707
VCID: 29593E2680E5070AD7-807C
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 00XW4
Subsystem 3 - Serial number: 0001.01.0000H0200000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB402D04259D˙†63
Subsystem 5 - Serial number: 04259D˙†63428RB402D052B2E˙†63
Subsystem 6 - Serial number: 052B2E˙†63528RB402D04AEF ˙†63
Subsystem 7 - Serial number: 04AEF ˙†63628RB402D0534AI˙†63
Subsystem 8 - Serial number: 0534AI˙†63729RB402915A6BR˙†63
Subsystem 9 - Serial number: 15A6BR˙†63829RB40290F966V˙
Subsystem 10 - Serial number: 0F966V˙
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H04000 Serial number: 90026071910121
Coding: 0012141
VCID: 2643351A91FB2872FA-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 N HW: 4E0 920 951 N
Component: KOMBIINSTR. VDO H83 0620
Revision: D02 Serial number: AUDID3G7000135
Coding: 0048383
Shop #: WSC 15398 002 1048576
VCID: 306FD342A33F76C210-8064
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B074248119
Coding: F5D5DFFF707A0E00
VCID: 2D51CA36B40D1B2A3B-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3455890
VCID: 183F0BE22B8F8E8278-804C
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0012510
VCID: 2C57C7328F1712222C-8078
2 Faults Found:
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 0 km
Time Indication: 0
01398 - Signal Conductor for Central Locking; Doors Open
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 3
Reset counter: 55
Mileage: 119636 km
Time Indication: 0
Date: 2016.04.13
Time: 17:29:06
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H50 0990
Revision: 00000000 Serial number: 395HU077503263
VCID: 3169D646A8357FCA1F-8064
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000718400118
Coding: 0003479
VCID: 1D311AF6C4ADEBAAAB-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028204
VCID: 204F2302F3DFC64280-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0010
Revision: 00100010 Serial number: W040708080089
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 73
Mileage: 121218 km
Time Indication: 0
Date: 2016.08.24
Time: 18:55:32
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000001563
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000008043
Coding: 0010111
VCID: 1E331DFAC9ABF0B2B2-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T1BJZ05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028204
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000732
Shop #: WSC 42193 001 1048576
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396H5077577908
Coding: 0000002
VCID: 2E53CD3AB90B603202-807A
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010969
Shop #: WSC 03164 444 83924
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2708070212
Coding: 344530393135313035412056413032373038303730323132
Shop #: WSC 00000 128 00289
5 Faults Found:
02277 - Quiescent Current Stage 6
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 60
Reset counter: 255
Mileage: 116360 km
Time Indication: 0
Date: 2015.12.09
Time: 21:27:58
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 88
Reset counter: 255
Mileage: 116281 km
Time Indication: 0
Date: 2015.11.24
Time: 06:26:46
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Reset counter: 255
Mileage: 116759 km
Time Indication: 0
Date: 2016.01.05
Time: 09:24:57
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 62
Reset counter: 255
Mileage: 116360 km
Time Indication: 0
Date: 2015.12.09
Time: 21:27:38
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 52
Reset counter: 255
Mileage: 119635 km
Time Indication: 0
Date: 2016.04.06
Time: 18:29:53
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028204
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900052756
Coding: 0232428
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000707300046
Shop #: WSC 12336 024 394758
VCID: 3467DF5257274AE274-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7710OZ
Coding: 1121402
VCID: 5CB757F29F37A2A29C-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028204
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720722206576
Coding: 0221208
VCID: 23452C0EE2C9DD5A9D-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005005037
Coding: 0010900
VCID: 25413216ECFD236AF3-8070
End-------------------------(Elapsed Time: 04:20)--------------------------
Ross-Tech: Home
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 255
Mileage: 119635 km
Time Indication: 0
Date: 2016.03.23
Time: 14:31:31
Freeze Frame:
RPM: 681 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 51.0°C
Temperature: 18.0°C
Voltage: 14.224 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 121721 km
Time Indication: 0
Date: 2016.08.26
Time: 17:30:55
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Voltage: 11.938 V
Coding: 0000002
Coding: 0001627
Coding: 0410624
Component: ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 230
Mileage: 111184 km
Time Indication: 0
Date: 2015.08.12
Time: 08:50:46
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 14
Time Indication: 0
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 76
Mileage: 120608 km
Time Indication: 0
Date: 2016.07.25
Time: 14:59:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 121216 km
Time Indication: 0
Date: 2016.08.25
Time: 13:34:22
Coding: 4071520
Coding: 0000003
Coding: 0041409
Coding: 0133123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 120614 km
Time Indication: 0
Date: 2016.07.12
Time: 17:49:43
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 4
Mileage: 120196 km
Time Indication: 0
Date: 2016.05.16
Time: 10:31:45
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119934 km
Time Indication: 0
Date: 2016.05.12
Time: 08:59:25
Freeze Frame:
RPM: 1903 /min
Load: 48.2 %
Speed: 39.0 km/h
Temperature: 24.0°C
Temperature: 17.0°C
Voltage: 13.335 V
000776 - Cylinder 8
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119934 km
Time Indication: 0
Date: 2016.05.12
Time: 08:59:25
Freeze Frame:
RPM: 1903 /min
Load: 48.2 %
Speed: 39.0 km/h
Temperature: 24.0°C
Temperature: 17.0°C
Voltage: 13.335 V
Coding: 0532707
Coding: 0012141
Coding: 0048383
Coding: 0012510
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 55
Mileage: 119636 km
Time Indication: 0
Date: 2016.04.13
Time: 17:29:06
Coding: 4071530
Coding: 0003479
Coding: 0028204
Coding: 0048686
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 73
Mileage: 121218 km
Time Indication: 0
Date: 2016.08.24
Time: 18:55:32
Coding: 0000026
Coding: 0010111
Coding: 0028204
Revision: --H03---
Coding: 0000732
Coding: 0000018
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 60
Reset counter: 255
Mileage: 116360 km
Time Indication: 0
Date: 2015.12.09
Time: 21:27:58
Freeze Frame:
Fault Priority: 7
Fault Frequency: 88
Reset counter: 255
Mileage: 116281 km
Time Indication: 0
Date: 2015.11.24
Time: 06:26:46
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Reset counter: 255
Mileage: 116759 km
Time Indication: 0
Date: 2016.01.05
Time: 09:24:57
Freeze Frame:
Fault Priority: 7
Fault Frequency: 62
Reset counter: 255
Mileage: 116360 km
Time Indication: 0
Date: 2015.12.09
Time: 21:27:38
Freeze Frame:
Fault Priority: 7
Fault Frequency: 52
Reset counter: 255
Mileage: 119635 km
Time Indication: 0
Date: 2016.04.06
Time: 18:29:53
Coding: 0028204
Coding: 0232428
Coding: 1121402
Coding: 0028204
Coding: 0221208
Coding: 0010900
Lot of stuff in there. Not uncommon, some stuff I'm not familiar with in there, but these things seem to generate codes randomly from time to time, and it's been at least a year since that one was cleared. Sounds like a couple minor things going out, maybe, but nothing serious that I see. See if any of them come back after clearing, I suppose.
Few things from this weekends roadtrip,
Crusing 70mph for 1 hr mileage was 22.5,
Crusing 80 for 1 hr mileage was 21.
In downtown traffic...12mpg...glad i dont live there and only have to visit. Its all 60mph roads around us here
this is by far the quietest and sure footed high speed driving i have ever done. What a brilliant machine. The dual pane windows are amazing.
Had it alined on a nice hunter inground unit, and balnced the tires. Its tome for new ones but i still have a bit of driving to do on these ones. Well worrth the time and few dollars for a super smooth ride.
But, used quite a bit of oil in these 800 miles we did. I made sure it was at the max line on the dip stick before we left, and got a low oil warning near home, so i put in half a quart to bring it back to the stock level. Really, the warning will go off with it half a quart low? Owners manual states wait 2 minutes for the oil to drain down. I dont think I waited that long. On the dipstick when i pulled it out the oil was at the MIN level.
No way the engine is hurt, thing pulls way too good and is very smooth. I suspect the PCV or oil mist separator contraption is to blame. Pulled the oil cap off and it has a very strong vacuum there at idle-leads me to suspect the valve is stuck open with gunk.
Does anyone have a crankcase vacuum spec for this engine ?
It looks like on the v10, the PCV and oil separator is right there beside the bank 1 throttle body, easily acessable..
