Sponsored by:
Sponsored by:
Reset service light
Old 05-19-2016, 03:37 PM
Jack88's Avatar
Default Reset service light
All right, I give up. How do you reset the service light? I reset every parameter in VCDS after the quick button for reset service light didn't work, and it still says "Service!" Of all the stupid things to be stumped by, I know...
Old 05-19-2016, 04:10 PM
greyrust's Avatar
I've had good results by using the key to start the vehicle, post RSL procedure.
Old 05-19-2016, 04:11 PM
uberwgn's Avatar
Jack, have you seen the Ross Tech video on the various methods:
Old 05-19-2016, 05:35 PM
Jack88's Avatar
I don't know if it was the key or doing the SRI quick reset the right way. I don't know why, but when I clicked the SRI button, seeing it check all the values made me think it was resetting them. I hadn't seen the pull down menu. Then I started it manually with the key and the light is now gone. Thanks for the quick and easy answer to a stupid question. Now, if only I could figure out why there's a code for N201 Driver's Side Ignitor keeping the airbag light on...
Old 05-19-2016, 06:10 PM
TSHong's Avatar
For that type of airbag code, the usual fix is DeOxit contact cleaner or just remove the connector and splice the wires using butt connectors or soldering.
Old 05-19-2016, 06:51 PM
Jack88's Avatar
The connector for the ignitor looks like it's really hard to access. Are you supposed to get at it through the trunk or is the rear deck supposed to come off?
Old 05-19-2016, 09:47 PM
mishar's Avatar
Not sure which airbag connector you are looking for but there are some underneath the rear bench.
Old 05-20-2016, 01:30 AM
TSHong's Avatar
Which igniter is giving the fault code?
Old 05-20-2016, 02:55 AM
uberwgn's Avatar
That's the piece so many miss. Glad you got it sorted.
Old 05-20-2016, 03:08 AM
Jack88's Avatar
N201 Driver's Side Rear Igniter. Looking at diagrams I have, it looks like it's the one in the rearmost pillar.
Northwestern
Audi allroad
04-09-2015 08:26 PM
audisbb
08-17-2009 12:26 PM
cyclezib
11-28-2008 08:17 PM
trimike
11-13-2008 08:00 AM
NVidt
05-06-2003 09:00 AM
Quick Reply: Reset service light
