Oil Leak. Front of FSI motor
Did an oil change last night and the engine guard was heavy with oil. Looks to be coming from the front right side of motor. After the oil change I started it up and opened the oil fill cap for a second. It has Lots of suction there. Like a good shop vac. Hope that is a good thing. Any tips on a common oil leak I should look for. Looked all over and could not see anything obvious. Was not a good night for the car or me.
Yeah, I had the same issue and I see you posted it before https://www.audiworld.com/forums/a8-...7-fsi-2865485/
I haven't located my source yet, but I cleaned the front of engine really good and going to monitor it before I bring it in the shop. I was thinking might be the gasket at base of oil filter housing then running under intake manifold then down front of engine, well that's what many B7 S4 owners experienced and our engines are set up similar.
I had forgot I posted that before. Wish it was like that. Now it is much more oil.
Not sure how it could be the filter housing. My filter to way up top next to the firewall. 07 FSI. Looks clean up there. Where do I look to see if that is it? I will get the scope camera going under the filter and see what I can find.
You are the best!
I have the same car with same engine. I came across this post and it may be the culprit. Take a look: Found my oil leak and got it fixed
Now this is some info I can jump on. Thanks for the link. Pictures and part numbers. What more could a guy ask for. Thanks!
Great link but am having some trouble with the part numbers on the gaskets. I will update that here and I learn more. Right now I have different part numbers.
For the 2007 FSI 4.2
Gasket 079103121BE
It is the same for the o-ring N90959701
Gasket 079103121BE
I'd like to take care of this on my own but cannot seem to locate a procedure for intake manifold removal. Anyone that can provide assistance in removing the intake manifold for an 07 4.2FSI would be appreciated.
bsewall
11-30-2006 11:48 AM
CP
05-24-2001 05:56 PM
