online coding and component protection
#11
Hi, these are the fault codes found on my car
Sunday,13,December,2015,13:06:33:38927
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Ross-Tech: Home
Dealer/Shop Name: Tendai
VIN: WAUZZZ8K5AA184433 License Plate: EF10VMP
Mileage: 91860km-57079mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72
VIN: WAUZZZ8K5AA184433 Mileage: 91860km-57079miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 019 C HW: 03L 906 019 AL
Component: R4 2,0L EDC H25 8428
Revision: 25H25---
Coding: 0A194012230503080000
Shop #: WSC 00202 210 80978
ASAM Dataset: EV_ECM20TDI03L906019C A02006
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 2B556698429D3F66EE-807E
16 Faults Found:
5595 - Crash Shut-Down Activated
P1609 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:30:03
4527 - Coolant Fan Control Circuit 1
P0480 00 [036] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Date: 2000.00.00
Time: 00:00:00
4531 - Fan 1 Control Circuit
P0691 00 [036] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Date: 2000.00.00
Time: 00:00:00
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:37:43
4640 - Engine Oil Temp. Sensor (G8)
P0197 00 [039] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91860 km
Date: 2009.06.26
Time: 01:02:44
5169 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [172] - Signal too High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:30:04
5282 - Intake Air Temp. Sensor (G42)
P0113 00 [172] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:30:04
4996 - Glow Plug Control Module (J179)
P0684 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91860 km
Date: 2009.06.26
Time: 00:00:47
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4713 - No Communication with ABS Brake Control Module
U0121 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4715 - No Communication with Instrument Cluster
U0155 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4716 - No Communications with Parking Brake Control Module
U0128 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4719 - No Communication with Diagnostic Gateway
U0146 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4720 - Body Control Module (Central Electric 2)
U0141 00 [039] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 91860 km
Date: 2009.06.26
Time: 00:07:13
Readiness: 1 2 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BB HW: 8K0 907 379 BB
Component: ESP8 front H04 0020
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 06325 000 00000
VCID: 7AFB93DCF54756EE25-802E
11 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 11
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:15:37
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x10A2
Hex Value: 0x0003
Hex Value: 0x245F
Hex Value: 0x00FF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:15:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x17A2
Hex Value: 0x0033
Hex Value: 0x025A
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 36
Reset counter: 80
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 20:20:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x002E
Hex Value: 0x0294
Hex Value: 0x00FF
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x2384
Hex Value: 0x00FF
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x2384
Hex Value: 0x00FF
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:09
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0032
Hex Value: 0x1F82
Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:11
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0014
Hex Value: 0x1387
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x2384
Hex Value: 0x00FF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0032
Hex Value: 0x1D99
Hex Value: 0x00FF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0027
Hex Value: 0xB999
Hex Value: 0x00FF
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0032
Hex Value: 0x6699
Hex Value: 0x00FF
Address 05: Acc/Start Auth.
Cannot be reached
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T2 820 043 AD HW: 8T2 820 043 AD
Component: KLIMA 1 ZONE H08 0180
Revision: B0000000 Serial number: 01110520101872
Coding: 34240000
VCID: 74E7BDE4D723209E7F-8020
4 Faults Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:30:07
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 80
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:30:07
Freeze Frame:
Temperature: 20.0°C
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:00:43
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:56:14
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
Component: BCM1 1.0 H29 0380
Revision: 06029001 Serial number: 00000000672627
Coding: 690040B1003400010001000000005F5F001D02080600000100 0000
VCID: 377D4AE886D58B869A-8062
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120510 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - LDS H08 0090
9 Faults Found:
03351 - Bulb for DRL and Marker Light; Left
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:52:00
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.07.13
Time: 03:32:00
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:50:00
02745 - Bulb for Daytime Running Light; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 18:24:00
00910 - Indicator Lamp for Emergency Flashers (K6)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 18:34:00
01800 - Light Switch (E1)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:22:00
03280 - Switch Position of Light-Switch ****
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:30:00
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0GD285
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 44872D24CF03D01E0F-8010
Crash sensor for side airbag; driver side:
Serial number: 6334MSME52056C047
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME531552397
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME44600402/
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME6E5D3B0C%
Crash sensor for front airbag; driver side:
Serial number: 63732SME7E5E4822C
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME7E5E0B36H
1 Fault Found:
12658176 - No Communications with Steering Angle Sender (G85)
U0126 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Date: 2009.06.26
Time: 03:01:47
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 D HW: 8K0 953 568 D
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JEB000LV
Coding: 000002
VCID: 3B7556D8BAFDAFE67E-806E
7 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:15:26
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:16:21
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:14
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 6
Reset counter: 40
Time Indication: 0
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:09
Freeze Frame:
(no units): 44.0
Text: 2C92FFFFFFFF00C0FF
Lambda Factor: 4.24
Raw, Index/Key Err.: 255 255 000
Text: 3E710000FFFFFFFFFF
(no units): -0.00
Raw, Index/Key Err.: 255 255 255
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 120
Time Indication: 0
00886 - Turn Signal Switch (E2)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:27
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 F HW: 8K0 920 950 F
Component: KOMBIINSTR. H20 0255
Revision: 00300000 Serial number: CIR225C4A
Coding: 2F04080002002600010000
VCID: 326B7BFC6DB76EAEAD-8066
1 Fault Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:35:04
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1051781C0
Coding: 00CF07
VCID: 0109E4309891053664-8054
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H04 0003
17 Faults Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:31:05
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.70 V
Count: 6
Bin. Bits: 10000
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 9
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 19:03:52
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 7
Bin. Bits: 10000
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 19:03:53
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 8
Bin. Bits: 10000
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 45
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 20:27:55
Freeze Frame:
Bin. Bits: 10000
Voltage: 10.40 V
Count: 17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:08:43
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 86
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:08:43
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 10000
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:14
Freeze Frame:
Bin. Bits: 11101
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:15
Freeze Frame:
Bin. Bits: 11101
Voltage: 14.50 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:12:52
Freeze Frame:
Bin. Bits: 10100
Voltage: 7.30 V
Count: 7
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:11:31
Freeze Frame:
Bin. Bits: 00000
Voltage: 13.50 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:22:38
Freeze Frame:
Bin. Bits: 00000
Voltage: 13.80 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 120
Time Indication: 0
Freeze Frame:
Bin. Bits: 00000
Voltage: 14.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:01:07
Freeze Frame:
Bin. Bits: 00000
Voltage: 6.90 V
Count: 8
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:00:05
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.30 V
Count: 7
Bin. Bits: 10000
Time: 4.90 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 03:01:48
Freeze Frame:
Bin. Bits: 10001
Voltage: 11.90 V
Count: 6
Bin. Bits: 10000
Time: 0.40 s
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 03:35:00
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000518206
Shop #: WSC 00000 000 00000
VCID: 34677DE497A3609EBF-8060
8 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 4
Reset counter: 80
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 12.50 V
Count: 38
Speed: 0.0 km/h
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:16:03
Freeze Frame:
Voltage: 7.30 V
Count: 44
Hex Value: 0x0263
Hex Value: 0x0081
Hex Value: 0x1010
00323 - Vehicle Inclination Sensor (G384)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:45:55
Freeze Frame:
Voltage: 12.60 V
Count: 27
Speed: 0.0 km/h
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Voltage: 12.40 V
Count: 67
Speed: 0.0 km/h
Hex Value: 0x0277
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Voltage: 12.40 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0277
Hex Value: 0x0001
Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 254
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:00:01
Freeze Frame:
Voltage: 11.60 V
Count: 29
Speed: 0.0 km/h
Hex Value: 0x0177
Hex Value: 0x0008
Hex Value: 0x1010
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 32
Reset counter: 80
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 11.60 V
Count: 28
Speed: 0.0 km/h
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 5
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:06:20
Freeze Frame:
Voltage: 14.00 V
Count: 11
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0028
Hex Value: 0x1010
Address 56: Radio (J503) Labels: 8Tx-035-152-56.clb
Part No SW: 8T2 035 152 D HW: 8T2 035 152 D
Component: Chorus3 H01 0054
Revision: 00000001 Serial number: AUZ1Z2K5113605
Coding: 00000480040108000159070000
Subsystem 1 - Part No SW: 8T0 919 603 HW: 8T0 919 603
Component: Display H09 X017
6 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:17
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 120
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:11:59
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 129
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:24:05
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 18:47:04
Freeze Frame:
Bin. Bits: 001
00468 - CD-ROM Drive (R92)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:18
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End-------------------------(Elapsed Time: 02:13)--------------------------
Log-EF10VMP-WAUZZZ8K5AA184433-91860km-57079mi.txt
Open
Displaying Log-EF10VMP-WAUZZZ8K5AA184433-91860km-57079mi.txt.
Ross-Tech: Home
Revision: 25H25---
16 Faults Found:
P1609 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:30:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:37:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91860 km
Date: 2009.06.26
Time: 01:02:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:30:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91861 km
Date: 2015.08.26
Time: 09:30:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91860 km
Date: 2009.06.26
Time: 00:00:47
U0126 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
U0164 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
U0121 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
U0155 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
U0128 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
U0146 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 91860 km
Date: 2009.06.26
Time: 00:07:13
Coding: 160504
11 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:15:37
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x10A2
Hex Value: 0x0003
Hex Value: 0x245F
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:15:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x17A2
Hex Value: 0x0033
Hex Value: 0x025A
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 36
Reset counter: 80
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 20:20:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x002E
Hex Value: 0x0294
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x2384
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x2384
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:09
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0032
Hex Value: 0x1F82
Hex Value: 0x00FF
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:11
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0014
Hex Value: 0x1387
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x2384
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0032
Hex Value: 0x1D99
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0027
Hex Value: 0xB999
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0032
Hex Value: 0x6699
Hex Value: 0x00FF
Cannot be reached
Coding: 34240000
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:30:07
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 80
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:30:07
Freeze Frame:
Temperature: 20.0°C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:00:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:56:14
Coding: 00FD11
9 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:52:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.07.13
Time: 03:32:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:50:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 18:24:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 18:34:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:22:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:30:00
1 Fault Found:
U0126 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Date: 2009.06.26
Time: 03:01:47
Coding: 000002
7 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:15:26
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:16:21
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 40
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 02:00:09
Freeze Frame:
(no units): 44.0
Lambda Factor: 4.24
(no units): -0.00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 120
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:27
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:35:04
Coding: 00CF07
17 Faults Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.08.26
Time: 09:31:05
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.70 V
Count: 6
Bin. Bits: 10000
Freeze Frame:
Fault Priority: 1
Fault Frequency: 9
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 19:03:52
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 7
Bin. Bits: 10000
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 19:03:53
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 8
Bin. Bits: 10000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 45
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 20:27:55
Freeze Frame:
Bin. Bits: 10000
Voltage: 10.40 V
Count: 17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:08:43
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Freeze Frame:
Fault Priority: 1
Fault Frequency: 86
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:08:43
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 10000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:14
Freeze Frame:
Bin. Bits: 11101
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:15
Freeze Frame:
Bin. Bits: 11101
Voltage: 14.50 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:12:52
Freeze Frame:
Bin. Bits: 10100
Voltage: 7.30 V
Count: 7
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:11:31
Freeze Frame:
Bin. Bits: 00000
Voltage: 13.50 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:22:38
Freeze Frame:
Bin. Bits: 00000
Voltage: 13.80 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 120
Time Indication: 0
Freeze Frame:
Bin. Bits: 00000
Voltage: 14.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:01:07
Freeze Frame:
Bin. Bits: 00000
Voltage: 6.90 V
Count: 8
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:00:05
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.30 V
Count: 7
Bin. Bits: 10000
Time: 4.90 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 03:01:48
Freeze Frame:
Bin. Bits: 10001
Voltage: 11.90 V
Count: 6
Bin. Bits: 10000
Time: 0.40 s
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 03:35:00
Cannot be reached
Cannot be reached
Cannot be reached
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 80
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 12.50 V
Count: 38
Speed: 0.0 km/h
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.03
Time: 14:16:03
Freeze Frame:
Voltage: 7.30 V
Count: 44
Hex Value: 0x0263
Hex Value: 0x0081
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:45:55
Freeze Frame:
Voltage: 12.60 V
Count: 27
Speed: 0.0 km/h
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Voltage: 12.40 V
Count: 67
Speed: 0.0 km/h
Hex Value: 0x0277
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Time Indication: 0
Freeze Frame:
Voltage: 12.40 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0277
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:00:01
Freeze Frame:
Voltage: 11.60 V
Count: 29
Speed: 0.0 km/h
Hex Value: 0x0177
Hex Value: 0x0008
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Fault Frequency: 32
Reset counter: 80
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 11.60 V
Count: 28
Speed: 0.0 km/h
Hex Value: 0x0173
Hex Value: 0x0008
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:06:20
Freeze Frame:
Voltage: 14.00 V
Count: 11
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0028
Hex Value: 0x1010
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:07:17
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 120
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:11:59
000 - -
Freeze Frame:
Fault Priority: 3
Reset counter: 80
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 01:24:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 120
Mileage: 91861 km
Time Indication: 0
Date: 2015.09.01
Time: 18:47:04
Freeze Frame:
Bin. Bits: 001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 91860 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:18
Cannot be reached
Cannot be reached
Open
#12
You should maybe wrap code tags around the vcds dump, also I see its an A4 diesel so maybe your post will be better in the appropriate forum if its model specific help your needing.
Looks like you have a lot of work ahead clearing the crash damage
#13
Cool diagnostic scan.
I don't offer a service to read complete diagnostic scans and provide testing/troubleshooting/repair advice. Not for a price nor for free.
I understand Ross-Tech will read complete scans and offer areas to look for problems for a modest fee.
#14
Yes I think you should post it on the A4 forum.
They driving similar so would be more helpful.
I have had the jammed starter error on mine but starts eventually.
I haven't even seen a a8 with so many error codes.
A lot are from low battery I think
#18
I think he is getting it sorted.
Pmed me quote
Hi,
Thanks for the contact you gave me. I managed to contact him and was able to scan my car and came up with loads of fault codes. The guy adviced me to change bcm2 and he will help me with coding. Will post the scan results.
Pmed me quote
Hi,
#19
just an update from my PM
Quote:
<table width="100%" style="table-layout: fixed;" border="0" cellspacing="0" cellpadding="3"><tbody><tr><td class="alt2" style="border: 1px inset currentColor; border-image: none;"> Originally Posted by storka
Quote:
<table width="100%" style="table-layout: fixed;" border="0" cellspacing="0" cellpadding="3"><tbody><tr><td class="alt2" style="border: 1px inset currentColor; border-image: none;"> Originally Posted by Tendai Kufandirori
Search for Jack #### in Poland on Skype
He is not a freeby person. He is a vw Audi mech.
Charged me 45 euro for the work he did for me.
Tell him Graham sent you.
Post your experience when you get a chance.
</td></tr></tbody></table>
Hi,
Hi
No problem.
He is a bit of a wiz.
When he is finished do a bit of a write up on my thread as most people are a bit sceptical about this I think.
Cheers
Hi
I will definitely write. I have a strong feeling this guy knows his stuff because the Audi dealer could not diagnose the car but he managed to explain how to do it. I will keep you posted. Thanks
How did it all go ?
Hi. Almost there now just waiting to get a new BCM2 which is quite expensive from the dealers. Hopefully soon and Jack has been helpful. Will keep you posted when I am done.
Ok sounds promising
</td></tr></tbody></table>Hi
Sorry I haven't been on the forum. Jack managed to sort my car perfectly. That guy is a genius. I wouldn't mind to recommend him to anyone. He knows his stuff for sure. I would like also to thank you for recommending him to me. Just wanted to share the update with you.
Hi,
Hi
No problem.
Cheers
Hi
How did it all go ?
Ok sounds promising
#20
Hi
Few months back I had a massive problem with my car and my local dealer couldn't do it. Only managed to change pyrotechnic fuse. So I had to take my car home and luckily I was introduced to this gentleman called Jack who was brilliant and am glad it's running perfect. Anyone who has a big problem with your vag cars, I can pass on the details. He knows his trade
