Oxygen sensor, codes p0150,p0155,p2254
#21
The cables and terminals on the generator aren't that big. People have to be able to make the connections. The bolts that hold the terminals to the generator output lugs are common 1/2" bolts.
#24
Many thanks for mentioning the TSB, finally sunk in for me
Go for the car side connector, or actually what is the wiring leading up to it. Given you changed the sensor, but still have a connection type code, that most likely puts it in the wiring. The individual conductors that lead to the connector are small enough they can be prone to internal breakage or other issues.
After I went through this drill on mine, I finally bought a set of the pre-made connector jumpers and new plug from audiusaparts, plus some all in one heat shrink tube and solder splice connectors. Cut out the connector a few inches back--where the (small conductor) wiring could still get broken due to repeated movement or stress. I spliced in the new jumpers after threading them into the new connector end, used a heat gun on the pre fab connectors to melt the solder and think the tubing cover all in one step, and taped it up with some black cloth tape. Presto, no more codes ever since.
Although I had forgotten it at the time, there is actually a W12 specific TSB for 2005s and 2006s that covers exactly this connector/wiring issue, with exactly the same fix path as I eventually went down after eliminating other scenarios like the particular sensor. The TSB said it was corrosion at the wire terminal connectors. What ever it was, mine was cured.
[edited additional remarks] I forgot to mention, the car feels more responsive to the pedal, and my mileage has improved as well, not a huge improvement, but from a flat 20 commute to closer to 21.5 ............ thanks agian
audiquattroduo
11
11-13-2008 02:46 AM
