Panicked on tire wear, give me a reality check please
#31
I intend to do it once and be good for the next 10 years.
#32
As an update, had a full suspension inspection and alignment done last week when I finally got back to driving it again- Everything in the suspension checked out fine, just a slightly loose tie rod end- which I knew about- and had them fix.
The rear alignment was off, and was re-set. Not sure how that happened- maybe a pothole, who knows. It was aligned 9 months ago, and was out of spec last week.
Still have a slight wobble between 50-60 mph. Next thing to check is the wheel centering rings. They fit the hubs, but not sure they are the right size for the wheels. 3 are green, one is black. So- new centering rings are going on this weekend.
Hopefully this will fix the slight vibration at 50-60 mph.
#33
hate hate hate vibrations, especially on large luxury cars.
ANy chance you could put on 4 different wheels/tires for a quick test to rule your current ones out?
#34
Definitely a place to suspect. If they aren't metal already, hopefully your new ones are that rather than plastic. I'm guessing you are adapting a set of wheels that fit newer Audi's w/ the larger hub center?
#35
Doesn't that "Constant S" setting prevent the camber change on our cars?
#37
Funny- I test drove an E55 a couple of weeks before I bought my A8, no- they aren't even remotely similar, but the low end thrust the E55 possessed was intoxicating.
#38
If it were mine, I would locate a set of factory rims and get rid of the aftermarket rims. I know there is a set of factory rims for sale in Orlando. There is nothing like forged rims for strength.
#39
Honestly, I have thought about it. But up until now I didn't believe the cost of purchasing a new set of wheels and tires was worth it. If I can't get rid of the vibration between 50-60, I may do just that- however.
#40
FWIW, you can sometimes find the twin 10 spoke OE 20's used on D4 A8's and A7's/S7's as quasi takeoffs with tires for not much more than the value of the tires and mounting as new. The A7/S7 tire you find is very close to the D3 fitment. Some guys on board with D3's have run them IIRC. Forged wheels BTW, so probably a lot of quality difference too, and re-usable with current generation Audis (without the adapter ring to retrofit to D3's). On supply/demand basis, for what ever reason a lot end up on the market and just kind of sit.
