Sponsored by:
Sponsored by:
Parking Brake Error - Hall Effect Sensor
Old 07-29-2015, 05:11 AM
Philc98's Avatar
Default Parking Brake Error - Hall Effect Sensor
I had the parking brake light come on last week. It is strange because the parking brake still works perfectly. I have ran VAG Com and it shows that there is a hall effect sensor issue on the right side. I ran through all the tests in VAG open / close / test. Reset the pad thickness. Everything seems to be working properly but I cannot clear the light. Any thoughts would be appreciated.
Phil
Old 07-29-2015, 02:06 PM
Mister Bally's Avatar
Verify all wiring is good (standard automotive electrical troubleshooting techniques-use the wiring diagram that is in the service manual). If so, consider replacing the defective Hall-Effect Sensor. This may mean the complete motor or calpier assembly.
Old 07-29-2015, 11:16 PM
AudiWorld Wiseguy
dvs_dave's Avatar
OP, did you not like the same answer the first time you asked?
https://www.audiworld.com/forums/a8-.../#post24707032
Old 07-30-2015, 03:06 AM
03_AR_CO's Avatar
I have a working motor on my shelf in the garage here if interested. Let me know.
Old 08-05-2015, 09:19 AM
Philc98's Avatar
I received minimal feedback as I posted within someone else's post that was somewhat unrelated so I thought I would get more input and valuable experience if it was in its own post.... but thanks for the sarcasm. Always helpful.
Phil
Old 08-05-2015, 06:10 PM
AudiWorld Wiseguy
dvs_dave's Avatar
Phil
No problem and you're welcome. Next time I'll hold off and wait for a couple of pages of "maybe this, maybe that" type posts before posting an actual solution....just the way you like it.
Old 08-06-2015, 08:18 AM
carl viking's Avatar
Default I'm one of the unlucky ones as well
I have followed the tips given on this board (and common sense) - used top notch contact cleaner / lubricant, bent connector pins a tiny bit to ensure tighter fit etc. Done the Ross-Tech process. Has worked fine for 4 months, was off and on before that (a few weeks at a time), usually corrected with wet weather. In the end - the good news is that I know it's the connector / motor - not the car wiring harness (which can fail for some).
Over time I will have to replace the caliper, but it's not cheap. And since prior owner painted it black, I have to do the same with replacement.
It's unclear to me if there is any correlation to age or mileage for this to fail. if not, a used caliper may actually be a smart move, as long as you can do the work yourself.
Old 08-06-2015, 09:24 AM
AudiWorld Wiseguy
dvs_dave's Avatar
You can buy the motor by itself (part no: 4E0998281B) or you certainly used to be able to. It's attached with a couple of torx bolts and is a very quick swap.
Even if it's no longer available without the caliper, I'd still just swap the motor over as a caliper change makes the job much more involved.
Old 08-06-2015, 09:32 AM
That's excellent news - not sure how I missed that? $400 sure is a better price than the entire caliper.
Thank you!
Old 09-30-2019, 04:10 PM
rob1962's Avatar
Thank you!
$100 aliexpress.com https://www.aliexpress.com/item/3296...27424c4dNTqaV3
Nedlohmick
Q5/SQ5 MKI (8R) Discussion
06-18-2017 04:18 PM
@wesome
02-27-2009 04:27 AM
richmond5
05-12-2006 03:31 PM
freak
12-13-2002 12:36 PM
SIS4
08-05-2002 08:21 AM
Quick Reply: Parking Brake Error - Hall Effect Sensor
