Rain/light sensor
#11
I really don't think you have rain sensor fitted
That should have at least a q after it.
E is too early
When I fitted auto wipers ( long drama) I had to get a later model central electric module
At least q at the end and it worked. And that's after wiring and installing the sensor.
Found out by chance on a post somewhere.
I will see if I can find my old one and see what version was on it.
HAve not seen one with auto lights without auto wipers.
Although my auto lights worked with the older cent elec.
There are two different light sensors for the windscreen
One is a light rain sensor one is light sensor only.
You may have to check your sensor part number as it may have only come with auto lights.
Or as you said check your option codes
E is too early
#12
E is too early
E is too early
#13
AudiWorld Wiseguy
No rain sensor on 04 USA
For some wierd reason the 04 USA models don't have the rain sensor, light sensor only. Mine is the same.
You can retrofit it fairly easily though. There's a couple of "how to" threads on here if you search.
#14
Mine is 2004 and it has that option and it also works too
#15
This adds even more to the confusion. I honestly think it is all based in the coding, and/or modules accepting the coding. I have both the light sensor which is the extended part of the rearview mirror and the round circle which rests inside of the rearview mirror housing. I honestly think they prepared (fitted necessary components (sensors), but a module that can not accept the coding) for it but only "activated" it after a certain build date. Im going to have to look into the electrics pdf I have.
#16
So I take that as a no that auto wipers is on your options list ?
There are positively two different sensors available as I said.
As DVDs Dave it should be fairly easy to retro fit.
#17
#18
This is why at the beginning I asked to see who has rain sensing wipers to provide their code to 09, which includes wipers and rain/light sensor and their code to 38. Just to try and see if changing the code, to a verified functioning code of a functioning rain sensing wipers, will make mine work. Sorry if anything is confusing, its a bit late and I'm a bit tired.
#20
+1 The D3 harness is supposed to be customized for each one built--exactly wired for the specific options and equipment in the specific car.
