Real time help, stuck at work.
#101
What are you talking about "Like I said", in the now 101 post on this thread you have never stated anything or contributed with a post until #100, If you read back from the beginning to the post 3 months ago when he did confirm that the relay was bad, as I traced it to power from terminal 30 was not being converted over to create terminal 15 by way of J329 relay, you would read that Doc switched out said J329 relay and the vehicle came to life, it was the relay, now in my many years of working on vehicles, machinery, etc. I have seen many relays go bad, horn, fuel pump, starter, all kinds, BUT, I will say as I am going to discuss with Doc on the phone in the morning, is that if his relay is burnt again after 3 months of use, then something is creating a heavy draw, and if you read all through the information I posted you would see that the "ECU, Trans ABS etc" will not be in service when terminal 15 is dead, HENCE the ignition will NOT power on....
Please do not confuse !
#102
The spare relay that I replaced the original relay with was a $8 amazon deal- I suspect it wasn't the best relay available for the job. But it did bring the car to life, until two days ago.
I replaced the "replacement" J329 with a relay that certainly cost more- from the auto parts store in town. I have no idea if it was better quality or not. anyway- the (now second) replacement of J329 did not bring the car to life.
Giovanni- I'm headed out to get some work done for a few hours. I will text you when I'm back in cell phone range.
#104
You can work back from the relay socket (again). Have you put your 12V tester or VOM on the coil "input" terminal, the blue line from the Authorization and start module and see if 12V is present on attempt to start
If not then the signal or voltage from the start authorization module is not coming in. It looks like there was a service saga going on with that relay panel. Somebody has been in there more than a few times over the life of the car.
Where is the authorization and start module located?
#105
Johnny, I checked for voltage across the blue terminal and 30, good voltage.
I jumpered 15 and 30, lots of mechanical whirring and air release...
Reinserted the relay and she fired up.
Trying to run VCDS now, always hangs up on the digital radio scan.....
#106
Thursday,08,December,2016,18:16:40:39127
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
www.Ross-Tech.com
Dealer/Shop Name: ERP
VIN: WAUML44E96N019693 License Plate:
Mileage: 181770km-112946mi Repair Order: 08Dec201602
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E96N019693 Mileage: 181770km-112946miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F0784333
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFC35FEB8BBC82D1-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 02313 785 00200
VCID: 2447A7AFE74328628D-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 346AP067530666
Coding: 0000003
VCID: 204FABBFF35B3442E9-8074
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000057090
Subsystem 3 - Serial number: 0131.01.080000000100010117˙
Subsystem 4 - Serial number: 010117˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000090194
Coding: 0004417
Shop #: WSC 22198 444 64035
VCID: 1C379F4FDF3310A235-8048
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7266809
Shop #: WSC 00000 000 00000
VCID: 1B359C53DA3D179A3C-804E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Revision: 0000000 Serial number: AUZ4Z7E20
VCID: 2643BDA7917FDA7293-8072
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 181779 km
Time Indication: 0
Date: 2016.12.08
Time: 19:01:01
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65C1FAABACF9116A5A-8030
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F0003789
Coding: 0048203
Shop #: WSC 46297 000 104857
VCID: 326B51F7ADB7B6D20F-8066
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 20003061228034
Coding: FCFE7BDD1B7904
VCID: 275DB0A39675C37AA8-8072
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
Address 34: Level Control
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355BX067561786
VCID: 387F63DF4BCB5C8231-806C
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000006062
Coding: 0000016
VCID: 2541BAABEC79D16A9A-8070
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000078354
Coding: 0010111
VCID: 1E339547C92F02B2DB-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396AR067531923
Coding: 0000002
VCID: 2345A4B3E24D2F5AF4-8076
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000000629
Shop #: WSC 22198 444 84161
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 310212C07X
Coding: 344530393135313035412056413033313032313243303758
Shop #: WSC 22198 444 05017
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700037458
Coding: 0232125
VCID: 5FCDE8438EA54BBA90-800A
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 36
Mileage: 177651 km
Time Indication: 0
Date: 2016.10.18
Time: 05:48:14
Freeze Frame:
Speed: 112.0 km/h
Temperature: -3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000601130281
Shop #: WSC 12336 024 394758
VCID: 2D51428BB489E92A52-8078
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720602003332
Coding: 0201208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007529115
Coding: 0010900
VCID: 224BA1B7FD572652FF-8076
End-------------------------(Elapsed Time: 03:52)--------------------------
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
Coding: 0004417
Cannot be reached
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 181779 km
Time Indication: 0
Date: 2016.12.08
Time: 19:01:01
Address 15: Airbags
Cannot be reached
Coding: 0012141
Coding: 0048203
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
Cannot be reached
Coding: 4071530
Cannot be reached
Coding: 0032364
Cannot be reached
Coding: 0000016
Coding: 0010111
Coding: 0032364
Cannot be reached
Cannot be reached
Coding: 0000002
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 36
Mileage: 177651 km
Time Indication: 0
Date: 2016.10.18
Time: 05:48:14
Freeze Frame:
Speed: 112.0 km/h
Temperature: -3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0032364
Coding: 0201208
Coding: 0010900
#107
The above is a new scan, I can't get the central conv. code to clear. Any ideas on the that?
Also, under carpet felt dry.
#108
It is located on the drivers side floorboard under the carpet, as Doc has power across the relay pull-in circuit when the key is turned on, and he jumped terminal 30 (LINE) to terminal 15 (LOAD) and certain items powered up, he then put the $8 relay back in and it started, BUT as it just got very cold where he is, he wondered if that would cause this to allow it to start, I suggested that he lift the carpet to look for wetness where the J518 KESSY module is located, who knows, if he does have wetness maybe it would be shorted, but when frozen no short......
We will see..
We will see..
#109
New scan- can't clear the remaining codes individually...
Thursday,08,December,2016,19:05:44:39127
www.Ross-Tech.com
Mileage: 181780km-112952mi Repair Order: 08Dec201603
VIN: WAUML44E96N019693 Mileage: 181780km-112952miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
15-Airbags -- Status: OK 0000
34-Level Control -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F0784333
Coding: 0007773
VCID: 2E534587B98F92326B-807A
1 Fault Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181780 km
Time Indication: 0
Freeze Frame:
RPM: 680 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 28.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.462 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0077174
Coding: 0000002
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
Coding: 0004417
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 36636DE741DFAAF223-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 181779 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 075
Raw, Form. N/A: 000 000 000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0004NYB
Coding: 0532707
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36FGA
Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB400E1D413E˙†63
Subsystem 5 - Serial number: 1D413E˙†63428RB400E1D46DU˙†63
Subsystem 6 - Serial number: 1D46DU˙†63528RB400E1D8CB$˙†63
Subsystem 7 - Serial number: 1D8CB$˙†63628RB400E1D892S˙†63
Subsystem 8 - Serial number: 1D892S˙†63729RB400D76155K˙†63
Subsystem 9 - Serial number: 76155K˙†63829RB400D761B0M˙
Subsystem 10 - Serial number: 761B0M˙
Coding: 0012141
Coding: 0048203
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0010210
VCID: 285FB39F9B6BCC02A1-807C
Coding: 4071530
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H03 0090
Serial number: 00000532200021
Coding: 0003477
VCID: 1D31924BC42919AAC2-8048
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601160028
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 36
Mileage: 131072 km
Time Indication: 0
Date: 2014.08.10
Time: 11:59:07
Coding: 0000016
Coding: 0010111
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T13BT05
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 46297 000 1048576
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Coding: 0000002
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 181780 km
Time Indication: 0
Date: 2016.12.08
Time: 19:59:44
Freeze Frame:
Speed: 0.0 km/h
Temperature: 4.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0032364
Coding: 0201208
Coding: 0010900
End-------------------------(Elapsed Time: 03:43)--------------------------
www.Ross-Tech.com
Coding: 0007773
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181780 km
Time Indication: 0
Freeze Frame:
RPM: 680 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 28.0°C
Voltage: 13.462 V
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
Coding: 0004417
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 181779 km
Time Indication: 0
Freeze Frame:
Coding: 0532707
Coding: 0012141
Coding: 0048203
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
Coding: 0010210
Coding: 4071530
Coding: 0003477
Coding: 0032364
Coding: 0048702
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 36
Mileage: 131072 km
Time Indication: 0
Date: 2014.08.10
Time: 11:59:07
Coding: 0000016
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000532
Coding: 0000018
Coding: 0000002
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 181780 km
Time Indication: 0
Date: 2016.12.08
Time: 19:59:44
Freeze Frame:
Speed: 0.0 km/h
Temperature: 4.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0032364
Coding: 0201208
Coding: 0010900
#110
Looks like a normal scan to me. Plug in a new/used alarm horn and bob's your uncle.
But that wiring/relay junction panel might need some work. I have seen Porsche 928 CEP (Central panels) with issues. The relay connectors are typically crimped on F spade terminals, that are inserted into the plastic base for the M - pinouts.
I've pulled panels from parts cars with melted insulation etc. So don't rule that out as a potential issue.
What is the service history of the car?
