Sponsored by:
Sponsored by:
Rear back window sun shade
Old 09-02-2015, 08:48 AM
Billyb2's Avatar
Default Rear back window sun shade
I hear a click when I push the button but nothing happens. Has anybody experience this. Sorry 05 A8l. This car had sat for a while. Could it be stuck? How do you fix a stuck shade?
Old 09-02-2015, 04:47 PM
hellonwheels33's Avatar
I would have someone sit in front and push the button with you in the back with a trim stick to try and slip under the sunshade cover to see if with a little assistance it will come out. other than that I would check fuses and then start pulling apart interior or trunk panels in order to access the sunshade.
PS- I am an engineer for sunroofs/sunshades OEM and these are fairly simple mechanical devices. Generally speaking if they go bad you replace the entire unit.
Old 09-02-2015, 05:51 PM
Mister Bally's Avatar
Fairly low priced too. Except for Audi service parts.
Keep in mind service part prices to an end user are usually 5x what a component manufacturer sells them to an OEM for production use. That's whay most of the posters here try and repair these things when broken.
Are you by chance with Inteva?
Old 09-02-2015, 05:57 PM
No, I'm actually with GM. Webasto is a big supplier for us and Audi as well.
Old 09-02-2015, 06:02 PM
Darn, I was hoping we were coworkers, sort of.
Old 09-02-2015, 06:19 PM
yeah it would be nice to know a fellow co-worker where I am that drives an Audi. I am frowned upon for not having GM products. what makes it worse is that I have BMW also.
Old 09-03-2015, 10:24 AM
chokboywonda's Avatar
No need to sit in the front you can operate the rear shade from the rear via the button in the light cluster
Old 09-27-2015, 08:33 AM
RNtoNP's Avatar
Perhaps the folding flap is stuck and won't flip open?
Old 09-27-2015, 09:34 AM
2001 S8's Avatar
Hey Billyb2,
Check out my Roller Shade Fix link. My D2 shade had a similar issue. I'm guessing the difference between the D2 and D3 roller shade is minimal. Mine was an easy, no cost fix.
Good luck.
Old 09-28-2015, 06:36 PM
RNtoNP's Avatar
Hey 2001 S8, good info. I'm gonna have to try and fix my rear shade. The arms lift up properly but the shade itself isn't attached to the arms. I hope it's easy. Dealer wanted ~ $1200.00 to fix it couple years ago.. Err.. No thanks!
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
Sandito8e
New Member Welcome Area
09-02-2015 08:47 PM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
awdinut
09-02-2015 04:03 AM
Quick Reply: Rear back window sun shade
