Rear brake light issue
This may of been covered before but could not find any info my rear brake lights and are on permanently iv replaced the switch in the pedal but still not solved the issue does anyone else help hear
Unplug the switch to verify if they go out or not. If not, there is a control module that is bad. VCDS component scan will verify this as well. If the switch is at fault, you will need another one and must follow the install instructions (on the paper that comes with it ) exactly. You get one shot. If you mess up, the switch is unuseable.
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
