Rear brake pad replacement - AudiWorld Forums
Old 04-11-2014, 11:05 AM   #1
snatchman's Avatar
Default Rear brake pad replacement
I used vcds to open the piston, but know I can not move the caliper in to replace the pads.
Any ideas?
snatchman is offline   Reply With Quote
Old 04-11-2014, 11:11 AM   #2
snapdragon's Avatar
It only winds in the EPB, it doesn't PULL the pison back.
You may now have to lever against the carrier and pad or some such to push it back hydraulically as with conventional brakes. You may also need to use a wind back tool in non-rotating mode or G clamp to get it back enough to install new pads.
snapdragon is offline   Reply With Quote
Old 04-11-2014, 11:19 AM   #3
snatchman's Avatar
I applied a-lot of pressure to the piston and no movement. It's a 2006 A8L, I'm not sure if I would need a tool to wind the piston back in.
Old 04-11-2014, 11:24 AM   #4
ltooz_a6_a8_q7's Avatar
Default Please shoot some pictures - I'm going to do mine soon
Hope you get the job done without any problems.
Cheers,
Louis
ltooz_a6_a8_q7 is online now   Reply With Quote
Old 04-11-2014, 11:30 AM   #5
snatchman's Avatar
Old 04-11-2014, 11:31 AM   #6
Senior Member
MP4.2+6.0's Avatar
Default Something is wrong--it should wind it back in and fully release pads...
I have had my pads (2006) out to change at least three time now. When I use VAG COM/VCDS, it definitely winds everything to full open on mine, piston absolutely included, and the new pads slip right in. No prying, no turning, no special tricks.
Having owned the C5 and C4 with the auto parking brake adjust rear calipers when they still used manual cables, I definitely know about the "old" need to wind things in, but the D3 set up isn't like that. Sounds like something isn't working as designed.
MP4.2+6.0 is offline   Reply With Quote
Old 04-11-2014, 11:45 AM   #7
Default This is nice to know... But
Quote:
Everyone seems to have different problems with pistons retracting. Did anyone did a write up with pictures and videos on these eBrakes? For some reasons, my rear brakes haven't thrown a warning yet, I'd replaced the front already - both of the brakes were replaced at 55k miles and now it's 90k miles.
Cheers,
Louis
Old 04-11-2014, 12:02 PM   #8
VDCS should retract pads. BUT on my 2004 I was able to turn the piston to make it retract. BUT don't turn the rubber seal just the piston.
parkrog is offline   Reply With Quote
Old 04-11-2014, 12:04 PM   #9
snatchman's Avatar
I agree, there is definitely something wrong. I can here the motors retracting the brake, but the piston barely comes of the disc.
Old 04-11-2014, 12:54 PM   #10
snatchman's Avatar
Side note! The parking brake malfunction light was on before I started. The EPB would set and release but the light stayed on.
Thread Thread Starter Forum Replies Last Post
Brakes: Cost Pads Rotors ebod0000 A6 (C7 Platform) Discussion 137 Yesterday 06:38 PM
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Audi A4 2002 S4 6spd 98k rsixxer23 Vehicles For Sale 4 01-06-2016 04:25 AM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 12:39 PM
Brake Sensor Confusion C6Silver Q7 Discussion 4 09-01-2015 09:46 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
