Rear brake pad replacement
#12
2005 won't retract electrically. After VCDS retracting I have to push them in using C-clamp.
#13
Are you sure that both sides are working? One may be seized or have a loose contact. Do you have problem with retracting pistons on both sides, or may be just on that seized side?
#17
Thanks all for your help. I completed my first rear brake job on my 06 A8l. During my second attempt the passenger piston went in fairly easy with a C-clamp, the driver side was a little bit more difficult. I had to apply pressure with the C-clamp and turn the caliper slightly with channel locks, then the piston retracted with just the C-clamp.
The Ross Tech tool has officially paid for itself.
Andrewbens
07-14-2009 05:57 AM
