Sponsored by:
Sponsored by:
Control Arm & Axle Torque
Old 07-24-2014, 06:15 PM
Crash Craddock's Avatar
Default Control Arm & Axle Torque
Does anyone have the torque spec for the axle bolt and the upper control arms?
Old 07-24-2014, 06:22 PM
Mister Bally's Avatar
The axle bolt is a one time use stretch bolt with a specific installation procedure. See the Bently or Elsa manual.
Old 07-24-2014, 08:34 PM
mishar's Avatar
Control arm: 50 Nm + 90° turn
Drive axle: 200 Nm + 180° turn
Old 07-25-2014, 09:58 AM
MP4.2+6.0's Avatar
Default You have the right technical answers already. But, be prepared...
1. On control arms, lots of posts now w/ issues with that bolt. Read if you aren't familiar w/ it.
2. Mishar states the correct torque and process. But in the real world, that is probably 500 foot pounds or so at final torque with the 180 degree turn. As in, you either need a torque multiplier tool or a five foot or more lever arm. Probably the highest torque item on modern Audi's. Also be prepared for a good chance you will snap some part of a socket drive (breaker bar joint, extension, etc.) if you use half inch drive tools, and that you may not be able to break it even with a decent sized impact gun.
Old 07-25-2014, 10:28 AM
mishar's Avatar
A8 is a heavy car but 200 Nm (148 foot pounds) + 180° is definitely heavy truck domain. Tools including. You will probably need engine running in order to achieve enough braking power. Wheel shouldn't be under load with that bolt loose. It would damage the bearing.
ThaboTheWuff
04-26-2015 01:43 PM
PSUEng
09-23-2006 06:10 PM
FishMan
09-19-2004 06:53 PM
mechaman
08-12-2004 09:24 PM
blocko
04-21-2003 03:37 PM
Quick Reply: Control Arm & Axle Torque
