Sponsored by:
Sponsored by:
S8 5.2 Coolant leak - where do i start looking?
Old 06-29-2016, 10:16 AM
ori793's Avatar
Default S8 5.2 Coolant leak - where do i start looking?
Hello friends,
my s8 is losing coolant about 1 liter per 100km with no visible coolant leaks.
my mechanic could not find any leak.
we also pressurized the system, need your experienced advice,
where do i start looking? any known common leaks for this engine?
Old 06-29-2016, 11:04 AM
the_duke's Avatar
Have you replaced the coolant cap? My passat developed a leak I couldn't find and it turned out the be a bad cap that wouldn't hold pressure.
Old 06-29-2016, 11:12 AM
mishar's Avatar
If there are bubbles in your coolant reservoir it is cylinder head gasket. Also check the oil. If it is milky there is coolant in it. Cylinder gasket again.
Old 06-29-2016, 11:38 AM
Jack88's Avatar
Can you smell any coolant in the engine bay after driving it for a bit? Check to see if there are any signs of coolant leaking and burning off on the exhaust. And with these, also check the reservoir for any leaks or cracks, particularly around where hose connects.
Old 06-29-2016, 12:04 PM
Giovanni Giovino 6.0+6.0TT's Avatar
Look for pink residue left behind from burning off of coolant, also check all the small black plastic tubes under the hood.
my pics of W12 leaks...
Attached Thumbnails S8 5.2 Coolant leak - where do i start looking?-2011-12-21_21-49-25_963.jpg   S8 5.2 Coolant leak - where do i start looking?-2011-12-21_21-48-57_518.jpg   S8 5.2 Coolant leak - where do i start looking?-2013-05-06_22-24-54_385.jpg
cordoba quattro
03-25-2005 05:17 PM
jherm
12-12-2004 07:22 PM
t0adman2.8
12v V6 Discussion
02-21-2004 10:08 PM
SugarRushAudi
08-04-2003 12:28 PM
0gravity
06-21-2001 09:22 AM
Quick Reply: S8 5.2 Coolant leak - where do i start looking?
