S8 OWNERS, TRANSMISSION SERVICE ?
Hellow, how many of the S8 in this fórum had done the ZF Tiptronic service ?. At what milleage ?. Lifeguard 6 or 8 ?
When i bought my S8 2008 the first thing i want to do was the Tiptronic service ( drain and refill + new filter ). But it is very complicated to put down the pan, the 2 lines of the exhaust are there, and a few mechanical parts that make a big job ( a lot of hours of work ) to get out the pan.
My ZF dealer said to me to only drain and refill without touching the pan when the car has over 90.000 Milles or 83.000 Milles. Actually my S8 is over 73.000 Milles.
The tiptronic it goes perfect, very smooth in cold and warm.
Thanks all for your responses.
Regards
EISENMANN
Regards
EISENMANN
Mine S8 have 90k on it and I will pay Audi to change filter and fluid. It will run about $500 and 3h of labor. I guess Audi have some special way to remove the pan without removing exhaust. Lifeguard grade depends from your vin number so I would contact Europa parts they gave me right fluid with a gasket (vin sensitive as well).
Good luck.
Good luck.
I have 99k on mine (2006) and changed the oil and filter. No issues. The old oil looked good. I used whatever oil the dealer said I needed. Cost for gasket, filter and oil was about $400.
Gasket sells for about $100, the filter is about the same. The oil is $26 per quart. I got 8 quarts.
And here, Audi dealer do not make Tiptronic Service.
The problem is not about authority!!!!.
Regards!!!
EISENMANN
I changed my fluid/filter at about 50K miles. The fluid was perfect and it was a PITA to perform, had to take the exhaust apart. I used Schaeffer All-Trans Supreme:
Schaeffer Oil | ALL-Trans Supreme® Transmission Fluid for Dexron III and Mercon fluids
OMG, the car still works 15K miles later! I think the fluid was about $140 for a case of 12. Bought it on ebay.
AudiWorld Wiseguy
Putin/ZF's internet trolls will be along in a minute to set this straight.
